Like Tree11Likes
Old 01-25-2013, 09:25 AM   #2956
hana166's Avatar
Thanks for this Oleg.
I measured the car already and found almost the same numbers but better to be accurate
Now I can make some settings to alter camber gain whilst keeping a similar roll centre, or vice-versa, to investigate the effect of each, separately, on the track
Of course it is a little more complex because the rc migrates once the car leans into the bend but I am sure this will help me understand more about tuning the A700.
hana166 is offline   Reply With Quote
Old 01-25-2013, 11:52 AM   #2957
hello , does any body knows if the metalic diff gears also need shims?
thanks
osorron is offline   Reply With Quote
Old 01-25-2013, 12:29 PM   #2958
Hello,
Is there a setup from Viljamis ETS Stock Class Awesomatix or a picture from the Car what he drives in the ETS Stock Class??
Best greets Dirk
lauti33 is offline   Reply With Quote
Old 01-25-2013, 06:45 PM   #2959
Yokomo_Ant3's Avatar
Trader Rating: 29 (100%+)
Originally Posted by lauti33 View Post
Hello,
Best greets Dirk
http://www.petitrc.com/reglages/awes...ice2013011920/
Antoni Caretti
Team Yokomo - Racing Performer - Sweep Racing
Yokomo_Ant3 is offline   Reply With Quote
Old 01-26-2013, 01:28 AM   #2960
Hi,
This Is the Modified Setup and not the Stock Setup
Old 01-26-2013, 01:28 AM   #2961
Hi,
Old 01-26-2013, 04:04 AM   #2962
Geberit's Avatar
Hey guys can some one point me to online shops in Europe that carry Awesomatix?
Thanks!
Geberit is offline   Reply With Quote
Old 01-26-2013, 04:27 AM   #2963
Robert_K's Avatar
Thanks!
Shepherd BeneLux:
http://www.team-shepherd.nl/index.ph...d=69&Itemid=90
Regards Robert
Sponsored by: Schumacher Racing and Dualsky
Supported by: Shepherd Benelux and Thunder Tiger.
Robert_K is offline   Reply With Quote
Old 01-26-2013, 04:40 AM   #2964
Damon's Avatar
Thanks!
http://www.awesomatix.eu
Awesomatix A800
Awesomatix A800X
Damon is offline   Reply With Quote
Old 01-26-2013, 04:55 AM   #2965
Geberit's Avatar
Originally Posted by Damon View Post
But this shop is in Swiss not EU! Whats with the tax when I order from an EU country?
Old 01-26-2013, 07:15 AM   #2966
Dominic Vogl has used AM19 during ETS.
Dominic's ETS Rd2 setup corrected for AM18-1 instead of AM19 ( with the same roll centers and camber gains) is attached here.
Oleg Babich is offline   Reply With Quote
Old 01-26-2013, 01:27 PM   #2967
Originally Posted by Oleg Babich View Post
You can find the latest Viljami Kutvonen ETS MOD setup here:
http://awesomatix.com/download/
We should to do the corrections of Viljami's Mod setup.
Viljami has used the floating top deck with 6pcs of ST09 collars installed.
The revised setup is on our site already.
Pro-Stock setup from Viljami Kutvonen was added also.
Old 01-27-2013, 12:38 PM   #2968
Originally Posted by Navi View Post
Hi all,
I just purchased this car (A700L) and finished the assembly. It is more expensive than those EP touring in the market but it worth for the extra for its quality and innovative design. I love it very much. But since it is quite different from those conventional belt drive cars, I have doubts on some areas and needing some helps.
1) The manual default setup is for carpet. Is there a default setup for asphalt ?
2) The rear damper is suggested to be harder than front. Is it ok to set up in that way ? Most touring cars have front damper harder instead.
3) In my local track I used to use HPI silver springs with AE 40 cst. oil. How can it be converted to the damper set up (distance A and B as described in the manual).
Thanks for the help !
1. Please try this setup on your track first.
2. Almost all touring cars have front suspension actually softer than rear.
Harder springs and oil are compensated by the shorter operating
leverage force application for the shocks on the front suspension of all others touring
cars.
3. Please use our standard setup as initial.
hello, i read this threat, i am in the same sitation but with the exl chasis, i will ran in asphalt, so i understand try first with the same setup that the manual says(carpet) even i f im going to run in asphalt?
thanks
Old 01-28-2013, 12:13 AM   #2969
Damon's Avatar
Please contact directly them to know how it works
Awesomatix A800
Awesomatix A800X
Old 01-29-2013, 01:50 AM   #2970
Is there any low/extreme low grip carpet setups out there?
-Last 10.5t race was so bad for me, the car was sliding and understeering bad.
Only when I asked Viljami´s help I got the car ~ok to drive but it still was really slow.(and he was racing mod the same day so I did not harass him too long asking setup tips)
I guess the main issue is that I have only driven 10.5t on high grip carpet and low grip tracks I have driven only vta (17.5t) so my driving style needs attention also but if I would get the car to handle well maybe I can adjust my hands to match.
I have the stock A700L
fastvee is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17212 03-22-2017 02:55 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9055 02-23-2017 03:26 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
