Old 01-23-2013, 02:38 PM   #2941
Why Viljami use a lot of shims on inner rear upper link ?
Manu_05' is offline   Reply With Quote
Old 01-23-2013, 09:19 PM   #2942
With AM26 you need a lot of shims to get the desirable low roll center.
Oleg Babich is offline   Reply With Quote
Old 01-24-2013, 08:37 AM   #2943
Hellow,
I want to buy awesomatix car but before i have a question.
Can you guys please tell me which version is better for (stock, modified) and what are differences between ex, l and exl versions? Does anyone knows which chassis were used at ETS from freddy and viljami?
Thank you.
Likeslowww is offline   Reply With Quote
Old 01-24-2013, 08:52 AM   #2944
Originally Posted by Likeslowww View Post
Hellow,
Thank you.
Viljami for mod and Freddy have used wide EX chassis at longitudinal motor layout - this is exactly the same configuration as EXL version of kit.
Old 01-24-2013, 09:02 AM   #2945
Thank you Oleg. What about stock racing? Is there better to use L version? Can you explain what are advantages for all 3 versions?
Old 01-24-2013, 09:42 AM   #2946
It depends on the track/tires conditions.
In the real life the main difference is the lower deck only.
EX -wider and a bit stiffer in average but more flexible locally near to rear axis.
L - narrow and more flexible in average.
If only one of the decks has always been better, we would prefer to produce and sell only this single version.
The best solution is to have two cars - with L and with EX chassis.
Old 01-24-2013, 05:55 PM   #2947
hanulec's Avatar
Trader Rating: 23 (100%+)
Why was the longitudinal layout used in modified this time??
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 01-24-2013, 11:12 PM   #2948
This car is very good in longitudinal mode for modified also.
Setups from Dionys and Dominic are here: http://awesomatix.com/download/
The pictures of Dionys Stadler car:
Old 01-24-2013, 11:24 PM   #2949
Is he using the ball diff in the rear ???
bertrandsv87 is offline   Reply With Quote
Old 01-24-2013, 11:28 PM   #2950
From setup: plastic gears in gear diff.
Old 01-24-2013, 11:31 PM   #2951
Sorry Oleg, but my phone does not support the setup pdf files ...
Old 01-24-2013, 11:40 PM   #2952
What about jpg pictures?
Roll centers and camber gain of Dionys car:
Old 01-25-2013, 12:21 AM   #2953
I think so, but I've never tried before....
Old 01-25-2013, 03:23 AM   #2954
hana166's Avatar
Hi Oleg can you post these roll centre set ups as attachments so I can load them into my rcrollcentre v162?
I would like the exact numbers for the page 'model' and alternative inner camber link positions
hana166 is offline   Reply With Quote
Old 01-25-2013, 06:51 AM   #2955
OK.
All sizes are for 0.0mm shims all around and AM06.
Please see the inner camber link positions in my previous post.
Awesomatix EP Touring Car (A700 Shaft Drive)-a700ex-dionys-ets2-front-sizes.jpg   Awesomatix EP Touring Car (A700 Shaft Drive)-a700ex-dionys-ets2-rear-sizes.jpg
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 Today 07:05 AM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17196 Yesterday 01:50 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
