Old 01-21-2013, 01:28 PM   #2926
hanulec's Avatar
Trader Rating: 23 (100%+)
the only things that make 'stock' cars good (assuming the car handles excellent -- because that is always step #0 -- and can make up for both #1 and #2) are-
#1 efficient motors
#2 amazing batteries
#3 perfect lines
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 01-21-2013, 01:33 PM   #2927
Magnet Top's Avatar
Originally Posted by Oleg Babich View Post
The question for 13.5T blinky mode drivers:
What throttle settings in transmitter are you using to be faster?
1. Exponentials
2. ARC - Adjustable Rate Control
3. Sub-trim
4. Anything else?
( edit : looks like Manu already said this... but I'll second the point ! )
Tricking the esc to maintain 100% full throttle is always important in "blinky" classes. So calibrating the transmitter to the esc at 100% but after calibration setting the end point to 110 % is important. You lose a bit of "feel" but getting to 100% reliably is more important.
Jake D.
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 01-21-2013, 09:23 PM   #2928
I do the same as magnet top, but I go from 100% to 120%....
With a good setup in 13.5t shaft cars, I overgear a bit 0.4fdr under what the belt cars' fdr, but make up for infield punch with 50+% positive expo and 80+% throttle acceleration with a slight forward trim(+20%) that keeps my Car going when I'm Off throttle...
As fas the Esc, I run the highest drive frequency, the highest minimum throttle and no drag brakes at all....
It made my Novak system pull a few d3.5's down the straight....
bertrandsv87 is offline   Reply With Quote
Old 01-22-2013, 03:27 PM   #2929
You can find the latest Viljami Kutvonen ETS MOD setup here:
http://awesomatix.com/download/
Please see the picture of roll centers/camber gain also.
Please note that ETS tires (Ride 32) have bigger diameter ( ~64mm).
Oleg Babich is offline   Reply With Quote
Old 01-22-2013, 03:33 PM   #2930
frank b's Avatar
Oleg I agree with jake radio's settings for 13.5 blinky. The most important is that you get the gearing just right as all motors are different. In my case I run a higher gearing than everybody else in stock and my motor run excellent in that gearing.
Reedy / Awesomatix / AVID / Gravity rc / Go Go hobbies / RC Tagz
frank b is offline   Reply With Quote
Old 01-22-2013, 10:33 PM   #2931
Originally Posted by MDawson View Post
What are you solving for?
The ETS Pro-Stock 13.5T rules limit the gearing to FDR 4.5 for indoor and 4.0 for outdoor.
I think we can find up to 0.2sec per lap with good non-linear throttle transmitter settings at these conditions, especially if the driver is very good mod. driver usually trained of course for very smooth throttle's finger operation.
For example Viljami Kutvonen tried in third A-main of ETS Rd2 Pro-Stock +40%exp in throttle and it was like a different motor for him.
The 5min result and the best laps were improved.
Old 01-22-2013, 10:42 PM   #2932
Trader Rating: 19 (100%+)
I think we can find up to 0.2sec per lap with good non-linear throttle transmitter settings at these conditions, especially if the driver is very good mod. driver usually trained of course for very smooth throttle operation.
For example Viljami Kutvonen tried in last final of ETS Rd2 Pro-Stock +40%exp in throttle and it was like a different motor for him.
I had this discussion with Reto some years back - he equated the increase expo as effectively moving throttle curve relative to the trigger position. In other words less input of the trigger resulted in reaching the throttle endpoint sooner. Makes the car feel like it has more rip independent of changing other ESC based settings. There is some point however where the acceleration 'feel' will go quickly from crisp snap to softer spool up. Think of it as Expo advance fade. Track conditions however can quickly make this feel unsettling. The value of +40 is a unique feel. Too much of a light switch and difficult to modulate.
This does change the drivability of 13.5 motor. When all things are equal and spec, ESC & Motor, this can be a good advantage.
I have some other thoughts that I will email later.
MDawson is offline   Reply With Quote
Old 01-22-2013, 11:31 PM   #2933
Dawson, I agree it's a light switch, but if you also have your throttle forward trim up 20% it won't be so difficult to modulate... I find the 40% expo too soft, and I have to add 80% throttle acceleration to it to get the 10.5t feeling, but that's just me trying to match the punch of d3.5's with my Novak...lol....
Old 01-23-2013, 02:17 AM   #2934
Concerning Viljami's setup:
To accomodate Viljami's setup for normal 63mm tires
you should remove 0.5mm shims from all inner upper and lower balls and reduce all downstops on 0.5mm also.
Please note that Viljami measures all upper inner AT21 balls from top deck level.
So you should remove 2mm to get the correct shims value in case of using AM18-1 over the top deck.
Old 01-23-2013, 04:10 AM   #2935
Damon's Avatar
you should remove 0.5mm shims from all inner upper and lower balls...
one question about shims under lower balls: in the Viljami's setup there is 0.5 mm, but is this the total thickness under AT21 or I have to add 0.5 mm because of the milled areas? (so 1.0 mm total under balls)
thanks
Awesomatix A800
Awesomatix A800AH
Damon is offline   Reply With Quote
Old 01-23-2013, 05:04 AM   #2936
hana166's Avatar
I wonder about this also but I notice in the 'comments/impressions' section it says 'Shims under suspension arms measured from milled level'
hana166 is offline   Reply With Quote
Old 01-23-2013, 05:18 AM   #2937
Damon's Avatar
it was also written.....
perfect, it's all clear now
Awesomatix A800
Awesomatix A800AH
Old 01-23-2013, 09:38 AM   #2938
So Sorex are 6.75mm, Rides 64mm, CPX 5.25mm, am I right?
markova is offline   Reply With Quote
Old 01-23-2013, 11:44 AM   #2939
heretic's Avatar
Jake D.
http://www.youtube.com/watch?v=UeOXsA8sp_E
On a serious note, I never tried this 110% or 120 or 140% trick. I could understand a few more clicks " just to be sure ", but more sounds like losing too much trigger travel across the power band. Anyway I'll try when I get the chance. That and the + expo thing.
I love wedge bodies. I love dish wheels.
heretic is offline   Reply With Quote
Old 01-23-2013, 12:55 PM   #2940
Sorex and LRP CPX have ~ 63mm diameter for calculation of roll centers.
So remove 0.5mm shims from under all inner AT21.
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 Today 07:05 AM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17196 Yesterday 01:50 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
