Like Tree25Likes
Old 01-15-2013, 04:30 AM   #2896
Oleg,
Thanks for the positive feedback !
When will you release new chassis and square block and how to order ? I want to get the new parts ASAP as I am no good at that very delicated job.
Thanks again.
Navi is offline   Reply With Quote
Old 01-15-2013, 03:43 PM   #2897
zoomster's Avatar
Thanks hana166.
At present i just set the car to what i think is right and over the day have a look and feel what my friends cars damping is like and adjust my setup to feel the same then ask what oil and thats been working o.k but it would be good to know in number terms what it means.
Cya
Team Bust Out The Shorts Racing
zoomster is offline   Reply With Quote
Old 01-15-2013, 07:58 PM   #2898
Suspended
So which is it ??? Does it lower or raise the roll Center ??? I think it lowers it , but is it too far down and could require too much spring for the dampers ???
bertrandsv87 is offline   Reply With Quote
Old 01-16-2013, 01:09 PM   #2899
Hello, i have recieved las week my A700 EX, but i have a question, do you use some kind of grease (graphite, solicone, teflon) en the metal gears of the differential, spool with the shaft gears?
thanks
Christian
osorron is offline   Reply With Quote
Old 01-16-2013, 01:37 PM   #2900
erchn's Avatar
thanks
Christian
I used to use a dry wax, it's actually a liquid that dries and doesn't collect dust. I ran the covers on my diffs, and finally went to a thick thrust bearing grease that looks like peanut butter, it was made by much more I believe, worked nicely. That said, nothing is strictly needed.
erchn is offline   Reply With Quote
Old 01-17-2013, 07:39 AM   #2901
The sample ( setup) of AM26, AM06S, AM18-1 and ST24 using is attached here.
This setup should be good for high traction conditions.
The corresponding suspension geometry sizes pictures are attached also.
It will be useful for users of RCRollCentreV162 calculator and RCCrewChief2012 program.
Please note that the using of AM26+AM06S+ST24 combination on the rear suspension provides very big camber gain ( 0,91 deg) at relatively low roll center ( -9.05mm).
So the rear tires will save the good side grip to bigger side roll angles.
Awesomatix EP Touring Car (A700 Shaft Drive)-a700l-am26-am06s-st24.jpg   Awesomatix EP Touring Car (A700 Shaft Drive)-a700l-am26-am06s-st24-front-sizes.jpg   Awesomatix EP Touring Car (A700 Shaft Drive)-a700l-am26-am06s-st24-rear-sizes.jpg
Oleg Babich is offline   Reply With Quote
Old 01-17-2013, 08:12 AM   #2902
Suspended
So the Am26S does lower the roll Center... I'll stick with the original version for now....
Old 01-17-2013, 08:46 AM   #2903
The sample of very low (-13,5mm) roll centers setup is attached here.
This setup should be popular.
For reducing of side roll in case of you will need it:
1. Use a bit stiffer stabilizers on front and rear;
2. Use a bit stiffer springs setting on front and rear;
3. Remove 0.5mm shims under inner upper balls on front and rear.
Old 01-17-2013, 08:53 AM   #2904
Not AM26 !
AM06S and 0.0mm inner lower shims make the roll center lower.
AM26 provides bigger camber gain at the moderate low rear roll center.
Old 01-17-2013, 11:44 AM   #2905
OVA
OVA's Avatar
Trader Rating: 78 (100%+)
Thanks Oleg
OVA is offline   Reply With Quote
Old 01-17-2013, 01:57 PM   #2906
Lowest roll centers setup at all standard A700L kit parts.
-12,3 mm of the roll centers is possible for setting.
Awesomatix EP Touring Car (A700 Shaft Drive)-a700l-std-lowrc.jpg   Awesomatix EP Touring Car (A700 Shaft Drive)-a700l-std-lowrc-front-sizes.jpg   Awesomatix EP Touring Car (A700 Shaft Drive)-a700l-std-lowrc-rear-sizes.jpg
Old 01-17-2013, 03:43 PM   #2907
Suspended
Thanks for the correction Oleg ! I measured the distance between the wheel axis and the hinge pin in my tc4 , and it's about 15mm, the same as the standard AM06 , which should lower the roll Center far enough to start...
Old 01-19-2013, 07:47 AM   #2908
Trader Rating: 23 (100%+)
Great news starting to come from ETS.
http://ets.redrc.net/
http://ets.redrc.net/2013/01/awesoma...zech-republic/
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 01-19-2013, 09:35 AM   #2909
hana166's Avatar
Yeah been following this with interest, only a second in it over 5 min and outright fastest lap. Will be interesting to see how the guys got the car on the pace with the mod set ups.
hana166 is offline   Reply With Quote
Old 01-19-2013, 10:40 PM   #2910
Freddy wins A1 at ETS. http://ets.redrc.net/ Great stuff.
+ YouTube Video
TEAMORCA.SHOP
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 10:31 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 01:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
