Like Tree25Likes
Old 01-11-2013, 09:34 PM   #2866
Trader Rating: 23 (100%+)
Has anyone tested top decks on carpet?
  1. Solid top deck vs -
  2. Front cut top deck vs -
  3. Rear cut top deck vs -
  4. Full cut top deck?
I have forever only ran full cut top deck and have a solid top deck to try this weekend.
Curious about options 2 and 3 in red above.
TEAMORCA.SHOP
MDawson is offline   Reply With Quote
Old 01-11-2013, 09:34 PM   #2867
Default Symmetric or asymetric?
Would anyone happen to have any recommendations (track conditions) where one of the damper modes is preferred?
Thanks!
mhavlena is offline   Reply With Quote
Old 01-11-2013, 09:46 PM   #2868
OVA
OVA's Avatar
Trader Rating: 78 (100%+)
Originally Posted by gwhiz View Post
"~1mm shorter distance between wheel axis and the lower ST03 ball".
Check page 39 of the EXL manual.
you mean they milled off 1mm from the bottom of the hub or they change Dim. from the wheel axis closer to st03 ball? I don't have the manaul.. sorry thanks
OVA is offline   Reply With Quote
Old 01-11-2013, 09:58 PM   #2869
gwhiz's Avatar
Here ya go Franko:
Attachment 1016122
Picture is worth 1k words.
Edit: Found the post showing where to download the manual:
Awesomatix EP Touring Car (A700 Shaft Drive)
x
gwhiz is offline   Reply With Quote
Old 01-11-2013, 10:15 PM   #2870
OVA
OVA's Avatar
Here ya go Franko:
Attachment 1016122
hi Greg
I'm missing the X dim. it is the same as the stock
It could be the same other wise it would change the width
How does is lower the st03 ball?
Old 01-11-2013, 10:31 PM   #2871
gwhiz's Avatar
hi Greg
I am not 100% sure about this. Visually comparing them it looks like the angle was changed very slightly so that the width will stay the same.
x
Old 01-11-2013, 11:04 PM   #2872
OVA
OVA's Avatar
Well if they are the same config. as the stock hub, and they lower the center axles closer to the st03 ball, wouldn't that effect the CG
Old 01-12-2013, 03:39 AM   #2873
hana166's Avatar
Sorry Mark to respond with a question to a question but when was the last time you used the solid deck?
It seemed the best of all options for me on carpet
Oops my bad you're gonna try solid this weekend. Possibly the only option with new style cut chassis. Get ST27/ST28 and try them too. They make a huge difference in handling.
hana166 is offline   Reply With Quote
Old 01-13-2013, 10:46 AM   #2874
frank b's Avatar
Hi MDAWSON
You asked about the top deck cut out, it all depends on what configuration you have trans or long?
If in longitude myself and Korgae have Been running the top deck cut out only in the front but all the way through. So cut the three ribs and then keep going until you separate the front.
If pictures are needed let me know. I found it to work the best for me on carpet. It just gives me the right amount of flex I need to run on carpet.
Hope that helps
Frank b
RCamerica Xray/ Reedy / Gravity rc / Grip works RC / RCtagz
frank b is offline   Reply With Quote
Old 01-13-2013, 10:55 AM   #2875
Originally Posted by frank b View Post
Hi MDAWSON
Hope that helps
Frank b
Thanks Frank. I was referring to longitudinal layout on the L chassis.
I have a front cut top deck prepped. Starting with the solid deck this morning. So far the car feels more direct and reactive. Definitely feels like the car is in the carpet with less 'float'.
Thanks for the feedback.
TEAMORCA.SHOP
Old 01-13-2013, 11:40 AM   #2876
OVA
OVA's Avatar
Hi MDAWSON
Hope that helps
Frank b
Hi Frank
i got the A700EXL yesterday in the mail...Just waiting for more OPT parts back in stock...before I start to built...
Old 01-13-2013, 01:29 PM   #2877
frank b's Avatar
Franko good to see you getting back to running awesomatix again.
I would say just run the kit as is, I'm not running all the option parts except the servo centering holder ( am24 ) and L chassi.
My car is still the original a700 with the L chassi and the AM24 centering servo holder and that's it. I will in time get the option parts but don't Waite to build your kit and run it.
If you have any questions give me a call and I'll help you out or ask jake or Korgae and I think they'll help you out to.
I'm so happy with my car I can truly say its one of my best touring cars I've owned over the years of racing touring cars.
Any questions just give me a buz you have my number.
Frank b
Old 01-13-2013, 01:36 PM   #2878
OVA
OVA's Avatar
Frank b
hey Frank
Old 01-13-2013, 04:08 PM   #2879
Come on Frank ! Just say it's the best touring Car period !!!!! LOL !!!!
Is there another touring Car with optional drive layouts ???
I don't think so......ahahah....
bertrandsv87 is offline   Reply With Quote
Old 01-13-2013, 09:44 PM   #2880
hanulec's Avatar
Trader Rating: 27 (100%+)
hi oleg- any update on the AM06S availability? i need to buy some other spares to get the car rolling again, and i'd rather put just one order in. thanks in advance. mike
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17219 09-26-2017 10:31 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 01:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
