Awesomatix EP Touring Car (A700 Shaft Drive) >
Like Tree143Likes
Old 12-28-2010, 09:49 AM
  #271
Chrissy C's Avatar
The more i read and see the more i like your car Oleg. There seems to be some good intrest in the car, i hope it translates in to sales.
You mentioned previously that the production of the car would be relatively limited, can you tell us how many cars will be produced initially? Any further news on the release date?
As always we look forward to some latest pics, news etc, as dragonfire said an update to the web sections i.e option parts and the forum would be good, although i can imgaine your very busy right now!!
Thanks as usual for your time.
Chrissy C is offline
Old 12-28-2010, 01:31 PM
  #272
Thanks, Chrissy C
We had ~ 200 pre-orders earlier.
But as new pre-orders continue to arrive we make the first batch sufficient for some additional orders and for stock of spare parts.
I'll try to keep you informed.
Oleg Babich is offline
Old 12-28-2010, 03:33 PM
  #273
ark
Originally Posted by Oleg Babich
No, this is sealed ball diff.
But our gear diff ( optional) looks very similar.
Hi Oleg, sorry if i already missed it but how does the sealed ball diff work? Do you mean factory sealed or rebuildable sealed. cheers
ark is offline
Old 12-28-2010, 05:50 PM
  #274
Am I correct in assuming you have tie rods on the rear for adjusting rear toe? Have you tried angling the link to create "active" toe? I can imagine some practical uses for such a setting.
Dragonfire is offline
Old 12-29-2010, 01:43 AM
  #275
ark - Diff is fully rebuildable. It is possible to use this diff as a normal ball diff with diff lubes only or to fill inner space by silicone fluid ( 100-100000cpc) as a gear diff.
We use it now as fully filled by silicone fluid and have more than 30 runs without rebuilding. There are 16 ceramic balls inside of our diff.
It is possible to adjust diff spring tension of our filled diff without disassembling.
Dragonfire - Yes we have tried to create active rear toe. It seems useful.
Old 12-29-2010, 03:16 AM
  #276
That diff sounds seriously cool....
I would think that an active rear toe with more toe on power and less off would be very useful on the tracks I race on here in sydney.
Old 12-29-2010, 03:31 AM
  #277
Please don't forget about the additional rear steering in the turns in this case.
Old 12-29-2010, 07:05 AM
  #278
PitNamedGordie's Avatar
This car actually sounds like it's worth the $750.
PitNamedGordie is offline
Old 12-29-2010, 09:51 AM
  #279
JayBee's Avatar
Trader Rating: 31 (100%+)
Thanks Oleg!! This car is going to be a very cool addition indeed
JayBee is offline
Old 12-29-2010, 10:06 AM
  #280
MikeXray's Avatar
Trader Rating: 73 (100%+)
Agreed, you can get to $750 quick with a t2 '11 and ECS's and gear diffs
Part of me hopes this car isn't as good as it looks so I don't get killed by one, lol.
MikeXray is offline
Old 12-29-2010, 10:31 AM
  #281
Yep I know! I've got a 416x w/lipo chassis and a gear diff...$700+
Old 12-29-2010, 05:38 PM
  #282
Excatly! I normally find 3.5 rear toe works great for throttle but lacks a little off throttle and in the.middle of the turns. With this it sounds like you could set it to 3.0 and have up to.3.5 on power, 3.0 in the middle.o the turns and 2.5 off.power for.better turn in under brakes.
It sounds quite trick to.be.honest... Only thing that sucks is you need to use gauges to set up the rear toe instead of.just installing the right block or.spacer...
Old 12-30-2010, 01:18 AM
  #283
this car is looks cool... how can I pre-order one in USA? And when is the release date? thanks
ddd2k is offline
Old 12-31-2010, 06:17 AM
  #284
For pre-order please send message to me or to [email protected].
Old 01-01-2011, 03:32 AM
  #285
zoomster's Avatar
Hi Oleg,because this car have no normal coil over springs how do you adjust for tweak on the rotary shockers,and how do you adjust for tweak on the roll bars.
Thanks cya
zoomster is offline
