Like Tree21Likes
Old 01-01-2013, 11:57 PM   #2806
Conversion kits for all owners of our A700 cars:
http://shop.awesomatix.com/index.php?productID=919
http://shop.awesomatix.com/index.php?productID=918
Oleg Babich is offline   Reply With Quote
Old 01-02-2013, 12:25 AM   #2807
29TC's Avatar
Send a message via ICQ to 29TC
How about going from A700L to tranverse motor layout? Can u put up a list of parts required?
29TC is offline   Reply With Quote
Old 01-02-2013, 03:51 AM   #2808
columbia-mk2's Avatar
No one has got an answer? I guess that i´m not the only one who whant´s to know this.
Originally Posted by columbia-mk2 View Post
Hi all,
I would like to know about the handling characteristics between the L and EXL version.
Is one version better for carpet and the other for tarmac? One better for more technical and twisty outline, and the other one better for faster and straighter outline?...
Thanks in advance!!
Awesomatix A700EX
Hobbywing Justock / LRP SXX V2 TC
Hobbywing Xerun 10.5 / LRP X12 5.0 Octa Wind
columbia-mk2 is offline   Reply With Quote
Old 01-02-2013, 11:03 AM   #2809
From A700L to transverse motor layout:
AM02 Rear Bar
AM04 Motor Mount T
AM13 Spur Holder
ST06 Gear Axle
C01EX Lower Deck EX
C03-1 Top Deck T
G01 22T Bevel Gear
G02 27T Bevel Gear
B84RS MR84RS Bearing x 2
Old 01-02-2013, 11:15 AM   #2810
From FreddySudhoff:
Both are working well. The L chassis is the narrow one, with the new flex option but you can only run std. Motor layout north/ south. It has little bit more steering and change of load is perfekt.
The EX chassis is little bit wider, has also the new flex options but you can use the transverse motor kit. The chassis has a lot traction and is very easy to drive.
So, L has less rear traction, but good and very fast reaction and EX chassis is maximum easy to drive and very smooth.
All the stock guys at ETS used the L chassis with soft flex settings.
Old 01-02-2013, 10:26 PM   #2811
I hope to get my kit soon... I'm crossing my fingers....
bertrandsv87 is offline   Reply With Quote
Old 01-05-2013, 12:43 PM   #2812
Hello, I'm new in the forum and in awesomatix, I have a problem with AT03 and AT24
crowns were initially misaligned and after a few batteries with the modified I saw a slip of the same, what do you recommend
jonni.jp is offline   Reply With Quote
Old 01-05-2013, 01:31 PM   #2813
I saw now that in the previous page we talk about this defect
Old 01-05-2013, 01:48 PM   #2814
Originally Posted by jonni.jp View Post
.. I have a problem with AT03 and AT24
Please send this message to [email protected]
Our team will solve the problem with your AT03 and AT24.
Old 01-05-2013, 04:34 PM   #2815
John Doucakis's Avatar
Default Setting wheels
Hi guys,
Happy New Year to all!
Did a small update in my blog. Found and installed this set of wheels which I think look quite nice.
High Res photos in my blog
John
JD RACING BLOG
John Doucakis is offline   Reply With Quote
Old 01-05-2013, 10:40 PM   #2816
hanulec's Avatar
Trader Rating: 27 (100%+)
anyone have some tricks on making the front double jointed drive shafts a bit more bullet proof? i had one fly out after an AMAZING day of racing!! will shrink wrap help? or do folks have some better ideas. i found all of the pieces, and then put it back together again (a few times... that axle then continued to have some issues). we will see if all is well next week.
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 01-05-2013, 10:43 PM   #2817
hanulec's Avatar
i found a prior post from Dawson on using heat shrink. Awesomatix EP Touring Car (A700 Shaft Drive)
is that still the best idea?
Old 01-05-2013, 10:44 PM   #2818
erchn's Avatar
Look at the option parts, the Delrin collars work great.
erchn is offline   Reply With Quote
Old 01-05-2013, 10:54 PM   #2819
hanulec's Avatar
P20?
http://shop.awesomatix.com/index.php?productID=853
Old 01-05-2013, 10:55 PM   #2820
erchn's Avatar
Yes sir. They were made to battle what you are talking about.
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17218 09-15-2017 02:00 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
