Like Tree13Likes
Old 12-02-2012, 12:59 PM   #2701
theatriks's Avatar
If anybody wants a A700 but always thought it was too pricy ...well send me a pm because I'm ready to sell my original 1of 222 for a very affordable price ...let me know.
theatriks is offline   Reply With Quote
Old 12-02-2012, 05:05 PM   #2702
Thanks again Oleg for your reply of "Upper links" .
Now I must countinue with my stupid questions...-What do you guys do to make the car go straight?
-The ST21 part is jus a threaded rod , so only way to make this go straight is to use trim. I dont like that , always used to make everything go mechanically straight w/o any radio trims.
Ok, another way is to play with AT14 lenghts, but this would make left and right ones different lenght and that is not great eighter.
So is there a turnbuckle available for ST14 or something?
-Pate
fastvee is offline   Reply With Quote
Old 12-03-2012, 02:29 AM   #2703
hana166's Avatar
Set endpoints equal and trim to zero. Servo horn almost perfectly vertical, very very slightly to the inside. Jiggle between subtrim, link length and end points to fit steering rack lock stops so that end points are the same value at full lock.
Adjust subtrim and endpoints again on the track, can take a little while but I have trim at zero, a 4% subtrim and endpoints within 3% of each other.
Not the only way to do it but seems to work well
hana166 is offline   Reply With Quote
Old 12-04-2012, 09:12 PM   #2704
Default Front Body Posts too short on A700L?
All the body posts in my kit are all the same size. Is this correct, because when using a protoform Mazda speed 6, the front body posts are way too short...
I compared with my 417 and sure enough....
Anyone else experience this??
Thanks guys!!
mhavlena is offline   Reply With Quote
Old 12-05-2012, 01:32 AM   #2705
Thanks guys!!
2nd hole from top at front and 4th in the rear is where I mount Mazdaspeed6 LW body.
All the posts are same lenght and I cant see any problems .
If you are in the uk then maybe since they cut the shell off the lower lines.
If you want them longer just use washers under the posts and raise them that way.
-Pate
Old 12-05-2012, 09:43 AM   #2706
Nico''s Avatar
Hi,
with EX kit it comes both topdecks, C02 and C03?
Thanks,
Nico'
Nico' is offline   Reply With Quote
Old 12-06-2012, 02:17 AM   #2707
is there any video link this car againts the belt kit like TRF 417x or TCXX or Yokomo BD7?
is A700EX the latest kit, right?
uranghanyar is offline   Reply With Quote
Old 12-06-2012, 07:52 PM   #2708
Magnet Top's Avatar
If you go to the RedRC ETS race series coverage from the last year you'll see Freddy Sudhoff running his A700 and more recently I assume the EX in the finals against the worlds best of Marc Rheinhardt and Yokomo BD7 of Volker among many others. Red RC has links to the video of many of the races both mod and pro stock.
http://ets.redrc.net
Jake D.
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 12-07-2012, 05:54 AM   #2709
To all current owners of our #6 dampers ( DL6 and DR6 dampers):
We are introducing new output shaft sealing U-rings for our #6 and #3 dampers.
These U-rings have "almost zero" friction and it improves our dampers.
All new #3 and #6 dampers are produced with new U-rings from today.
You can easy replace your current standard O-rings by new U-rings also.
Please use a needle to take out old O-rings from #6 dampers.
You have possibility to get one free set of U-rings for each your current set of #6 dampers.
Please place an order on our web-shop shop.awesomatix.com
or contact to the distributor from whom you have purchased our dampers.
Shipping is not free and it will be cheaper for you to add these U-rings to one of your next order of spare or optional parts.
During placing of your order please add to "comments" field that you want to get free set o U-rings for your set of #6 dampers.
New U-rings have OR07 code in our web-shop:
http://shop.awesomatix.com/index.php?productID=915
Oleg Babich is offline   Reply With Quote
Old 12-07-2012, 03:18 PM   #2710
Hello Oleg:
Not too sure where is this O-ring located...would you happen to have a pic? (worth a thousand words), also what does this change solve?
Thanks!
Old 12-07-2012, 08:37 PM   #2711
Not too sure where is this O-ring located...would you happen to have a pic? (worth a thousand words), also what does this change solve?...
Please see the pictures.
New U-rings reduce harmful friction.
Awesomatix EP Touring Car (A700 Shaft Drive)-damper-o-ring.jpg   Awesomatix EP Touring Car (A700 Shaft Drive)-damper-u-ring.jpg
Old 12-07-2012, 09:50 PM   #2712
Nico''s Avatar
thanks Oleg, it's very clear now.
Old 12-10-2012, 01:48 AM   #2713
Hi,
Im looking for these spare-parts: AM19
Everywhere I search for them, they are out of stock. I need 4 pieces (2 in the front und 2 in the rear).
I dont want to use AM18(-1).
Who sells them? Or where are they still in stock?
Ronald
Driver and Manager of the Zwergenhaeuschen-Racing-Team, Germany
weber2406 is offline   Reply With Quote
Old 12-10-2012, 03:11 AM   #2714
Originally Posted by weber2406 View Post
Im looking for these spare-parts: AM19....
Please try this:
http://shop.awesomatix.com/index.php?productID=916
These carbon upper arms holders are good for old AM01.
For use with AM01-1 you should to trim the inner angles of C06 a bit.
Old 12-10-2012, 04:10 AM   #2715
Nico''s Avatar
Hi,
in which condition to use n3 dampers please? with low grip?
then, C07 carbon bumper is out of stock, is it the same as Tamiya TA-54089 please?
then the same question for AM16 out of stock, is it the same as Tamiya TA-84082 please?
Thanks,
Nico'
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17215 08-16-2017 11:12 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
