Like Tree21Likes
Old 10-29-2012, 09:59 AM   #2536
Hey,
I haven't raced my A700 for 5 months and now i saw that a quite significant amount of oil has leaked out of the dampers.
Is this a common problem and does it affect the handling in any way?
Regards David
niemand is offline   Reply With Quote
Old 10-29-2012, 10:11 AM   #2537
sprintcarracer's Avatar
Trader Rating: 25 (100%+)
Originally Posted by niemand View Post
Hey,
Regards David
I emailed Oleg about that issue as my car had the same deal. He said that theres so much residual oil in the dampers from assembly that it will leak for about 5 months. I did acually have a bad damper on my car, I'm just waiting for new ones.
I would say as long as they all fell the same you are OK.
sprintcarracer is offline   Reply With Quote
Old 10-29-2012, 10:16 AM   #2538
I have some tips for the metall gears.
Please try to use only two of the small gears instead of four. This will make the diff more smooth. Just go up with the oil, around 2000-3000cst.
After the first assembling, run in the diff, open it again, clean it with brake cleaner and refill it.
This will help to get all the dust and maybe some small metall parts from production out.
Freddy
LRP - Awesomatix
FreddySudhoff is offline   Reply With Quote
Old 10-29-2012, 11:46 AM   #2539
OK, thanks for the info.
Is there a conversion kit or a list of parts neccessary to convert an A700 to an A700L?
Regards David
Old 10-30-2012, 08:08 AM   #2540
G-rem's Avatar
Hello,
what are the parts and options needed to have on the car and in his box to prevent crashes,...?
Thanks,
G-rem
G-rem is offline   Reply With Quote
Old 10-30-2012, 08:21 AM   #2541
Boomer's Avatar
R/C Tech Charter Subscriber
Send a message via ICQ to Boomer Send a message via AIM to Boomer
to "prevent crashes"? LOL
RC10L2.5W - RC12.4 - RCNTC3(bmi) - TC4 (modded) - B44.2 - plus rent-a-rides! :D
Boomer is offline   Reply With Quote
Old 10-30-2012, 09:51 AM   #2542
Nico''s Avatar
Originally Posted by G-rem View Post
Hello,
Thanks,
G-rem
fingers ;-)
Nico' is offline   Reply With Quote
Old 10-30-2012, 10:25 AM   #2543
G-rem's Avatar
Yeah, but a transplant costs tooooo much ;-)
I mean by "prevent crashes", what parts do I have to get if ever ;-)
Old 10-31-2012, 08:18 AM   #2544
hana166's Avatar
A700L in stock on awesomatix website
Nearly finished my build
hana166 is offline   Reply With Quote
Old 10-31-2012, 08:43 AM   #2545
theatriks's Avatar
I have never broken one part on my a700 the parts are very well engineered the issue is when you do tap a board the arm pops off the ball studs....you need to be a very good wheel to race this car and benefit from it.....if your tapping boards a lot you will never finish a race with this car
theatriks is offline   Reply With Quote
Old 10-31-2012, 08:45 AM   #2546
yumlailai's Avatar
what is the difference between a A700, A700EX and A700L?
yumlailai is offline   Reply With Quote
Old 10-31-2012, 08:58 AM   #2547
Ray k's Avatar
Trader Rating: 46 (98%+)
A post from Freddy a couple pages back,
Both are working well. The L chassis is the narrow one, with the new flex option but you can only run std. Motor layout north/ south. It has little bit more steering and change of load is perfekt.
The EX chassis is little bit wider, has also the new flex options but you can use the transverse motor kit. The chassis has a lot traction and is very easy to drive.
So, L has less rear traction, but good and very fast reaction and EX chassis is maximum easy to drive and very smooth.
All the stock guys at ETS used the L chassis with soft flex settings.
Ray k is offline   Reply With Quote
Old 10-31-2012, 10:06 AM   #2548
Company Representative
Trader Rating: 15 (100%+)
Have you tried glueing the outer joint together? Oleg suggested this to me, and I am very surprised how good it works... Before I glued them a tap with the board was a 50/50 chance of popping it off... with glue, I have had zero issues.. It has built my confidence in the durability of the car.
P.S. full range of adjustment is still possilbe.
WCICS- Competition Director
Korgae is offline   Reply With Quote
Old 10-31-2012, 12:16 PM   #2549
theatriks's Avatar
Glueing the outer joint ? Are you talking about the plastic ball end that goes together up top to adjust camber? I'm talking the lower carbon fiber arm snaps onto ball studs that are mounted on the chassis ....I'm not sure how glue would help the arm from popping off the chassis ball studs?....I don't think there's a solution for that yet ....but you need a weak point and awesomatix I think came up with a good design where the arm pops rather then something breaking...like I said wicked car in the hands of a really good driver.......night mare for guys who are tapping boards.
Old 10-31-2012, 12:52 PM   #2550
erchn's Avatar
There is a bit of flashing, left from the injection mold, on P04 at the bottom where it mates with the graphite arm. Make sure that's cut/sanded/filed down, and it sits nice and square in the graphite arm. You should be able to tighten it down until it binds the bottom ball from the upright then back it off just a touch. I also put a drop of oil in there so that it could be slightly more snug but still move freely. Since that time, I never popped an upright out of the arm.
erchn is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17218 09-15-2017 02:00 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9064 06-14-2017 12:46 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 06:05 AM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 09:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 10:52 AM
Tags
yokomo
