Old 05-21-2012, 12:13 PM   #2146
hana166's Avatar
I had also some minor problems with the steering rack
I made a collar from brass which goes all the way through the rear bearing, making direct contact with AM10, unlike the original part, with two flats so you can grip it with a 5.5mm spanner. Now I can tighten so the collar does not slip, but the bearing itself is not under tension
Sanded the upper bearing surfaces on AM10 with 400 grit (upside down on paper) to help prevent slippage
Did you try one extra black outer spring on Tamiya servo saver? (4 springs). Saver is very rigid, feels like there isn't one, but all good in crashes, so simple to do, there is no need for even another brand of saver
Nothing has moved since I did this, not once has it needed further adjustment, and this was more than 5 months ago. 100% reliable now
Here is a photo of the added saver spring and brass collar
Forgot to say I lowered AM10 by adding 0.5mm shims under bulkhead to allow a thicker top on the collar for reliability, I snapped top of the original in 3 days from mew
hana166 is offline   Reply With Quote
Old 05-24-2012, 01:18 PM   #2147
theatriks's Avatar
awesomatix thread belongs on the front page bump
theatriks is offline   Reply With Quote
Old 05-26-2012, 10:18 AM   #2148
theatriks's Avatar
Hey i bought a ball diff and the manual calls for 5 bearings to be used and i only got four .....soooo am i on my own for this bearing or did i get screwed from the factory.
Old 05-26-2012, 01:15 PM   #2149
Ball diff set BD1 includes 3 ball bearings and 1 thrust bearing:
B85 - 1pcs
B74RS - 2 pcs
TB38M - 1 pcs
It assumes than you must take two B106RS bearings from your gear diff.
Oleg Babich is offline   Reply With Quote
Old 05-26-2012, 01:43 PM   #2150
Trader Rating: 19 (100%+)
Beyond watching the A700s at the Reedy Race International Race of Champions on LIVERC.com - you should check out the invite and mod class. LIVE video and race info. Just started the first day of qualifying.
I have met all of the A700 drivers - guys are working with their cars well. Hoping to see a few in the top 10 in several of the classes.
My car is starting to come in. Had a little issue with traffic in 17.5 but confident that I can keep putting in solid runs.
Currently 12th in 17.5 and 15th in 13.5.
Fingers crossed. Thanks to Oleg and Freddy for the email support.
MDawson is offline   Reply With Quote
Old 05-26-2012, 01:59 PM   #2151
Good luck, guys!
Old 05-26-2012, 03:49 PM   #2152
theatriks's Avatar
B85 - 1pcs
B74RS - 2 pcs
TB38M - 1 pcs
Gotcha thanks oleg ......mine came with 2-7 x 4 bearings ....2-8x5 and a thrust bearing
Old 05-26-2012, 04:08 PM   #2153
John Doucakis's Avatar
Default Ball diff
Today I tried the ball diff.
I am actually quite impressed by the performance.
Car had a tad more grip coming out of the corners, did not show any lack of bite exiting the corners and remained consistant through the run.
It is now nicely broken-in and it feels even smoother than freshly built.
Stil no signs of slippage.
John
John Doucakis is offline   Reply With Quote
Old 05-27-2012, 08:26 AM   #2154
hana166's Avatar
I too was impressed with it. But my lap time says something else. What is your experience ?
Old 05-28-2012, 04:54 AM   #2155
ropezz's Avatar
Raced yesterday in 10.5 stock class, with foam tyres on asphalt outdoor track.
Brilliant handling of the car supported by awesome motor power and great feel with ESC.
TQ, fastest lap of the day and won all three of the finals.
I'd like to post my set up for anyone who is interested at this configuration.
Race link: http://www.automodelli.it/forum/topi...22&whichpage=8
ropezz is offline   Reply With Quote
Old 05-29-2012, 05:36 PM   #2156
DS Motorsport's Avatar
Does anyone know whether a 77T 64 pitch spur gear is made which fits the Awesomatix car?
For the class I'm going to run we need to gear the car to a 4.0 FDR.
I'm trying to come as close as possible to this and keeping the motor moved to the center as much as possible.
A 40/77 ratio will give a an exact 4.0 FDR and has the motor moved inboard as much as possible.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 05-30-2012, 03:20 AM   #2157
hana166's Avatar
I ran 4.07 last year with 86/44
I suggest calling Neil at RW Racing +44 23 9258 8001
http://www.rwracing.co.uk/contact.html
Standard spur fits perfectly, black or white
Spurs are machined delrin, great quality
Hope he can help
Old 05-31-2012, 05:23 AM   #2158
Hope he can help
Thanks for the tip, I will contact them.
P1-RC.com
Old 05-31-2012, 12:31 PM   #2159
erchn's Avatar
Oleg,
Is there a wider hex version of AT13, something to add width to the car? I know I can use wheel spacers, I'm asking for another reason.
Thanks,
Ethan
erchn is offline   Reply With Quote
Old 05-31-2012, 01:43 PM   #2160
Originally Posted by erchn View Post
Oleg,
Thanks,
Ethan
Ethan,
There isn't wider version of AT13 hex now.
Do you have any reasons for it instead of wheel spacers?
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17196 Yesterday 01:50 AM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
