Old 04-12-2012, 11:10 PM   #1966
erchn's Avatar
Originally Posted by TryHard View Post
Hi Mike,
The reason you point out is one reason why it's not defacto roll-centre, as it uses the outer face of the hex as reference (so no wheel offset), and assumes a set tyre dia of 62mm... Use it as a comparison tool only, to get an idea of what changes what, and a ball park.
Like I mention in the sheet, when I ran the Tamiya, the stock RC's out of that tool were F -2.6, R -5. When I ran the same tool on the Losi, I found the rear had the RC too low, so targeted a similar level of split to the tamiya... lo and behold, got my best result of the season after doing that!
MD I've got a TRF416 version, never bothered with the 417, as very little change between the cars (upper inner link really).
HiH
Ed
Sorry for the possibly obvious question, but is -.5 mean no spacers under the arm pivot balls?
Oh, also, nice work!
erchn is offline   Reply With Quote
Old 04-12-2012, 11:29 PM   #1967
TryHard's Avatar
Haha, no... it means using shorter ball studs, which is something I'm investigating at the mo, as means to lower the rc..
TryHard is online now   Reply With Quote
Old 04-12-2012, 11:53 PM   #1968
Velocitygt's Avatar
Originally Posted by Kensei View Post
Yep, perfect its all i run.
Scorpion Power Systems | Awesomatix | WTF Fans
Velocitygt is offline   Reply With Quote
Old 04-13-2012, 02:08 AM   #1969
TryHard's Avatar
Serpent offer a very very very similar version too (so similar I bet they come out of the same factory!)... work very well, and run nice and true.
Old 04-13-2012, 02:24 AM   #1970
Hi,
can i order this kit in GB?
And where?
rc-opa is offline   Reply With Quote
Old 04-13-2012, 03:43 AM   #1971
JayBee's Avatar
Trader Rating: 31 (100%+)
I can't open it
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 04-13-2012, 04:18 AM   #1972
Damon's Avatar
Great work Ed, thank you!
I had a TRF416X and I ran F -2.28 R -4.43 (calculated with your previous sheet )
Now in the same track with A700 I ran F +0.78 R +0.78....
Awesomatix A800
Awesomatix A800AH
Damon is offline   Reply With Quote
Old 04-13-2012, 08:38 AM   #1973
TryHard's Avatar
Originally Posted by JayBee View Post
I can't open it
Really? I put a .xls and .xlsx file in there. You have uncompressed the file, right? Need winzip or similar to do that.
HiH
Old 04-13-2012, 09:08 AM   #1974
TryHard's Avatar
That's kinda the idea I'm trying to understand about the car. I know what worked well on the tam, so I'm going to shoot for a similar F-R split, as, IMO, that's what deals with the balance. I'm not saying the numbers need to be the same, but I tend to use the split between F&R to help define the balance of the car.
A couple of things to remember about this car, firstly the CoG is lower, and secondly (certainly with the long car) the weight is more central. Both year point contribute to a car that doesn't use roll to generate grip. I'm not saying it does need to roll as much (the low CoG is a help, deffiently in traction roll conditions) but in low grip, roll helps to numb reaction, and generate grip, in my experience.
Obviously, there are a lot of other settings to change (setup is compromise after all!) but it gives an indication at least. And that's all it is really, a tool to help, doesn't replace testing stuff out
Old 04-14-2012, 07:42 AM   #1975
Trader Rating: 19 (100%+)
Nice to see the A700 growing in numbers at ETS~
http://www.myrcm.ch/de/ets/20120413_...ock/index.html
Good luck boys!
MDawson is offline   Reply With Quote
Old 04-14-2012, 10:36 AM   #1976
theatriks's Avatar
Hey anybody know how long it usually takes to get your parts after you paided for them .....im in canada
theatriks is offline   Reply With Quote
Old 04-14-2012, 02:13 PM   #1977
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Good luck boys!
Having set the pace in Q3 Freddy Südhoff suffered a spur gear failure in the fourth heat but goes into the final qualifier as the only driver who can deny Volker from starting tomorrow’s final on pole position. Setting the fastest lap for the round with a 12.743, Marc Rheinard was on a potential TQ run until a mistake on lap 8 cost him over 2 seconds, a further two mistakes meant the World Champion ended up with 19th for the round.
OVA is offline   Reply With Quote
Old 04-14-2012, 02:15 PM   #1978
OVA
OVA's Avatar
Good luck boys!
Ride Modified Qualifying Round 4
1. Ronald Volker (DE) – Yokomo – 24/5:11.316
2. Alexander Hagberg (SE) – Xray – 24/5:12.611
3. Magnus Vässmar (SE) – Xray – 23/5:00.913
4. Viktor Wilck (SE) – Tamiya – 23/5:01.794
5. Christopher Krapp (DE) – Kyosho – 23/5:02.530
6. Zdenko Kunak (SK) – Xray – 23/5:02.857
7. Andy Moore (GB) – HB – 23/5:03.539
8. Tim Wahl (DE) – Xray – 23/5:04.098
9. Steen Graversen (DK) – Awesomatix – 23/5:04.175
10.Niclas Nilsson (SE) – Xray – 23/5:04.693
Xray Pro-Stock Qualifying Round 4
1. Zdenko Kunak (SK) – Xray – 22/5:04.731
2. Martin Hofer (DE) – Schumacher – 22/5:05.456
3. Oliver Franke (DE) – HB – 22/5:05.531
4. Michal Orlowski (PL) – Tamiya – 22/5:07.524
5. Steffen Leinburger (DE) – HB – 22/5:07.613
6. Ivan Laptev (RU) – Awesomatix – 22/5:07.964
7. Marek Cerny (CZ) – Yokomo – 22/5:08.589
8. Rob Janssen (NL) – Tamiya – 22/5:09.056
9. Carsten Madsen (DK) – Awesomatix – 22/5:09.416
10.Daniel Wohlgemuth (DE) – HB – 22/5:09.516
Old 04-14-2012, 06:23 PM   #1979
JayBee's Avatar
How are u guys using the different lengths of turnbuckles (12-short/8-long)?
Old 04-14-2012, 10:44 PM   #1980
OVA
OVA's Avatar
Ride Modified A-Main Grid
1. Ronald Völker (DE) – 310pts – Yokomo
2. Freddy Südhoff (DE) – 307 – Awesomatix
3. Alexander Hagberg (SE) – 306 – Xray
4. Marc Rheinard (DE) – 305 – Tamiya
5. Magnus Vässmar (SE) – 305 – Xray
6. Viktor Wilck (SE) – 302 – Tamiya
7. Andy Moore (GB) – 301 – HB
8. Christopher Krapp (DE) – 300 – Kyosho
9. Zdenko Kunák (SK) – 298 – Xray
10.Marco Kaufmann (DE) – 296 – Xray
Xray Pro-Stock A-Main Grid
1. Oliver Franke (DE) – 310pts – HB
2. Zdenko Kunák (SK) – 310 – Xray
3. Martin Hofer (DE) – 306 – Schumacher
4. Ivan Laptev (RU) – 304 – Awesomatix
5. Steffen Leinburger (DE) – 304 – HB
6. Michal Orlowski (PL) – 303 – Tamiya
7. Tony Streit (DE) – 303 – Xray
8. Denis Zuykov (RU) – 300 – Awesomatix
9. Marek Cerny (CZ) – 298 – Yokomo
10.Rob Janssen (NL) – 297 – Tamiya
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17211 Yesterday 05:13 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
