Old 03-12-2012, 01:30 PM   #1771
erchn's Avatar
Originally Posted by Kensei View Post
On what other parts do I have to use the dry wax lube?
Only on the pinion or all other cogwheels too?
What "ring" do you mean?
all gears.
erchn is offline   Reply With Quote
Old 03-12-2012, 03:09 PM   #1772
Originally Posted by erchn View Post
all gears.
OKIDOKI
How to apply the dry wax lube the right way? With a tool, or a brush, or something...?
How much to apply? Or how do I now enough is applied?
How to clean all the gears? With some kind of fluid?
How many times or when to clean the gears and put new dry wax lube on?
Sorry, but I've never used this stuff and the car is new to me.
Kensei is offline   Reply With Quote
Old 03-12-2012, 03:43 PM   #1773
Velocitygt's Avatar
Yes, perfect fit.
I use dry wax lube on all universal joints (as it does not attract dirt) and use Magnalube teflon grease in gearboxes, that is the only lubraction needed.
Also it is good to spray the outdrive bushings with WD40 then dry off, just to ensure they dont cease on the pin, as if they do it will wear out the outdrives very quickly.
Scorpion Power Systems | Awesomatix | WTF Fans
Velocitygt is offline   Reply With Quote
Old 03-13-2012, 05:02 AM   #1774
Velocitygt's Avatar
If anyone is having issues with the CVD cage popping apart in a hit, simply push the center of a kit bearing out (B106RS) and use a dremel to grind the center of the ring flat. You will then be able to slide this ring over the cage to stop it popping apart. It is a nice tight fit so no heat shrink is required. Since doing this I have not had one come apart.
Also, a small cable tie around the double ball cups helps to keep them popping apart in a hit.
These are both being updated by Awesomatix in the future although for now these small modifications work just fine.
Old 03-13-2012, 06:08 AM   #1775
hana166's Avatar
Default Tyre temps
What methods are people using to get the correct amount of heat into the tyres during a race?
Different tracks evolve differently during the course of a meeting so I'm looking for a way to run the tyre cooler, or hotter, without changing the entire balance of the car, to get the optimum grip for 5 minutes.
Interested to hear opinions particularly on how chassis flex, suspension stiffness and roll affect temps
hana166 is offline   Reply With Quote
Old 03-13-2012, 11:58 AM   #1776
SO NO JOINT GREASE AS SUGGESTED IN THE MANUAL?
THE BEARING RING IS ONLY APPLICABLE FOR THE FRONT UNIVERSALS?
Old 03-13-2012, 01:40 PM   #1777
Company Representative
Trader Rating: 15 (100%+)
Originally Posted by chrisman View Post
Thanks Oleg for the heads up.
Chris,
Check with Lou in Toronto, I think he might have one or he will put you in contact with someone that would be willing to sell one..
Hope you find one
Korgae is offline   Reply With Quote
Old 03-13-2012, 01:43 PM   #1778
Yes, you still need "joint grease" I personally use Hudy graphite grease. Just a bit on the friction points, You do not need much but it has to be there. Every time you service the car, get in the habit of checking this area, you do not want to run them dry.
The sleeve is a safety thing that helps the completed assembly stay together during a crash. ( Heat shrink performs the same function)
Hope this helps
Old 03-16-2012, 02:30 PM   #1779
abe-racing's Avatar
Default A700 Tool
Can I buy one now?!
What does it cost?
You can now get them from Bryan, sales@silverstonerc.com not sure of the price.
ABE-Racing,Team Orion, Blakey Designs, Xray RcDisco,T-Shox
abe-racing is offline   Reply With Quote
Old 03-16-2012, 06:05 PM   #1780
Trader Rating: 19 (100%+)
Default MD Stealth Edition
My A700 Stealth Edition
MDawson is offline   Reply With Quote
Old 03-16-2012, 06:22 PM   #1781
Trader Rating: 22 (100%+)
Black spur needed
bjspinner is offline   Reply With Quote
Old 03-16-2012, 06:26 PM   #1782
Originally Posted by bjspinner View Post
Black spur needed
just to remind people it is a shaft car
Old 03-16-2012, 06:30 PM   #1783
cannon's Avatar
Trader Rating: 35 (100%+)
http://www.youtube.com/watch?v=aPqao...feature=fvwrel
www.feralbatteries.com ........... new website
cannon is offline   Reply With Quote
Old 03-16-2012, 07:24 PM   #1784
hanulec's Avatar
Trader Rating: 23 (100%+)
those setup wheels gotta go
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 03-16-2012, 07:36 PM   #1785
olhipster1's Avatar
Trader Rating: 90 (100%+)
Send a message via Yahoo to olhipster1
I knight you Sir Stealth....
Very nice job
everything is Cause and effect
every Action has a reaction.
"I drank too much wine - I must take a p!ss"
CAUSE and EFFECT
olhipster1 is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17210 Yesterday 03:16 AM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
J. Kłapacz, josecarlo1129
