Old 02-29-2012, 09:34 AM   #1681
Originally Posted by method699 View Post
I've tried Freddy setup from the warmup and found that my chassis is rubbing on the carpet too much, think that the dampening is too soft for me..
i've tried it with Ride32 asphalt tires..don't have a choice we have to drive with it..
i know from the setup it was the CPX.
his someone tried it and what did you change to get it work for u..
thanks
As I remember Ride's diameter is 1.5-2mm bigger than on CPX.
I case if it true, your roll centers are too low at Freddy's setup ( shims ) and your car rolls too much at Freddy's springs.
To compensate it and to get Freddy's roll centers height you must add to Freddy's shimming 0.75-1mm shims under all inner lower balls and remove the same under all outer upper balls.
Oleg Babich is offline   Reply With Quote
Old 02-29-2012, 12:10 PM   #1682
Thanks Oleg,
if i understand i need less roll for the tires with higher sidewalls so a higher roll center.
by going around 1.5mm under inner lower balls, remove some 1mm on outer upper balls, maybe remove some shims on inner upper balls..
maybe do i have to try antiroll bars around 1.3 on front and 1mm on rear.
should i have to try less droop? 6 front and 5 rear?
try around 90kgf/cm² for dampening on rear and little less on front..
little harder on springs..
if you have any suggestions i'll take it..
thanks to all, need some help cause those tires are a pain to drive on..
method699 is offline   Reply With Quote
Old 02-29-2012, 03:21 PM   #1683
MrGidi123's Avatar
AWESOMATIX Picture Just with out the motor ^^
MrGidi123 is offline   Reply With Quote
Old 02-29-2012, 09:55 PM   #1684
TryHard's Avatar
Hi all,
Just wanted to add in the final setup I used at TITC last week. There were three Awesomatix's in the pits, generated plenty of interest. As mentioned before, car was really good (my driving less so), and both Tom and myself made the D in mod, he finished 2nd, myself 5th. Pretty happy with that given the short amount of time with the car, and struggling a little earlier in the week on settings.
In the end ended up with a car that was pretty nicely balanced with no hint of traction roll... I think for sure will be using this setting as my base for now.
Did need a bit more steering, but can find that by softer front spring. Got some other things to try as well, but taking a weekend off I think
Regards
Ed
File Type: pdf EC - TITC12 Final settings (260212).pdf (238.6 KB, 266 views)
Old 03-01-2012, 06:27 PM   #1685
good that the A700 drivers getting good results...
can we have a setup from the Driver if possible mr Oleg..
thanks
Setup from Viljami Kutvonen on this page now:
http://awesomatix.com/download/
Setup from John Doucakis for low traction, bumpy, high speed track was published there also.
Old 03-02-2012, 01:19 AM   #1686
just want it to share pic of my green A700
ddd2k is offline   Reply With Quote
Old 03-02-2012, 01:56 AM   #1687
frank b's Avatar
Was there any issues with parts going back together with the anodizing ?
And did you have any problems with bearing going back in ?
Looks sweet I was going to do mine in orange or black but wasn't sure if it would work.....
RCamerica Xray/ Reedy / AVID / Gravity rc / Go Go hobbies / RCtagz
frank b is offline   Reply With Quote
Old 03-02-2012, 02:26 AM   #1688
hana166's Avatar
Looks great, good that you chose an unusual colour.
Been tempted to de-anodise the coloured parts and polish them to have it all silver, I'll get around to it eventally
hana166 is offline   Reply With Quote
Old 03-02-2012, 05:50 AM   #1689
Trader Rating: 19 (100%+)
Looks great. Where did you have the anodize work done?
MDawson is offline   Reply With Quote
Old 03-02-2012, 05:51 AM   #1690
Mb3195 is offline   Reply With Quote
Old 03-02-2012, 09:05 AM   #1691
Company Representative
Trader Rating: 15 (100%+)
Cool
[QUOTE=frank b;10409827
Looks sweet I was going to do mine in orange or black ..[/QUOTE]
BLACK
Korgae is offline   Reply With Quote
Old 03-02-2012, 09:09 AM   #1692
OVA
OVA's Avatar
Trader Rating: 74 (100%+)
Originally Posted by Korgae View Post
BLACK
Blue for me or maybe red
OVA is offline   Reply With Quote
Old 03-02-2012, 09:11 AM   #1693
OVA
OVA's Avatar
BLACK
Oh Korage
btw congrat's your win ( kamploops)
Old 03-02-2012, 10:54 AM   #1694
Originally Posted by OVA View Post
Oh Korage
Thanks Franko, two bad stock went the way it did ( did you see the video?) .. But in SS it was the perfect weekend. That trophy race was the 1st run for the A700 and I could not have been happier.. Coming from my old car (T3 12's) I was amazed I picked up time with the A700 1st time out... The car makes so much more natural rear grip that I really have to get use to having a planted car.. lots to learn but it's but is only going to get faster
Old 03-02-2012, 12:01 PM   #1695
OVA
OVA's Avatar
Hey Korage
I just saw the video and All I can say it is sad...
Yes the A700 is a great car...Don't hit any hard pipes...
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17210 02-19-2017 03:16 AM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10913 01-18-2017 07:05 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
