Old 01-15-2012, 09:23 PM   #1381
TryHard's Avatar
Originally Posted by jake95 View Post
hi,
thanks for fast reply ill go with priority list 1 ive only broke a hub all year in the xray in mod so that stuff should be alright then.also does it come with the tunning options with the kit
thanks,
jake
The main option I would get would be Marks above list, and the First Aid kit, and the LA1 kit.
I also picked up the IAS (increased Ackerman set) but haven't had a chance to run it yet.
Nothing else needed!
HiH
Ed
Old 01-15-2012, 09:36 PM   #1382
jake95's Avatar
Trader Rating: 27 (100%+)
okay thanks cant wait to get it
XRAY✯NOSRAM✯SANWA
jake95 is offline   Reply With Quote
Old 01-15-2012, 11:00 PM   #1383
@ Mark
I just pushed the holder as much inside as possible. So distance B is around 5mm. Same for distance A. The shock is inside so distance A=0.
LRP - Awesomatix
FreddySudhoff is offline   Reply With Quote
Old 01-16-2012, 12:43 AM   #1384
jake95's Avatar
i was wondering how you guys found it in turn in and in mid corner because i want something that has steering i have tried everything on xray and still not 100%
XRAY✯NOSRAM✯SANWA
Old 01-16-2012, 12:49 AM   #1385
Originally Posted by John Doucakis View Post
trying to speed up the chance of testing, today I installed the electronics.
Unfortunatelly weather forecast is rain and very cold, so first taste will be postponed to a later date.
as usual, a few more here:
JD & RACING BLOG
I was in the track to see the car in action, freezing my nuts off, and now I read this?
Negative:
*--- I received the kit for presentation purposes only but now I want to keep it and not return it so I'm in trouble!
YES, YOU ARE IN TROUBLE...
On a serious note though, this is the only car that makes me consider changing my xray T3 2012. Your presentation just made me even more anxious to see the car up close and who knows what will happen then? I may have to hire some muscle to beat you up John and steal the car...
Excellent work Oleg for the car and you John for the presentation.
PS: You should have come, aside from the cold the track was in good condition and the cold weather allowed for some really interesting settings in the ESC
taz00 is offline   Reply With Quote
Old 01-16-2012, 01:17 AM   #1386
John Doucakis's Avatar
haha.. Ψαράκη εσύ είσαι?
It may have not rained, but still it was way too cold for me. Anything below 10 degrees outdoors is just not enjoyable and my hands are not functional.
Test will come soon, on the 28th I think is a realistic goal.
Thanks for the good comments, and yes, Oleg has created an absolute stunner!
John Doucakis is offline   Reply With Quote
Old 01-16-2012, 01:28 AM   #1387
I don't think I'd change my xray for one, the xray is too good for most applications, it is pretty much the perfect club car. However, as an absolute racing machine the a700 I believe just beats it! Do what I did, keep your xray and get a a700 as well!
Mb3195 is offline   Reply With Quote
Old 01-16-2012, 01:46 AM   #1388
Εγώ είμαι.
True about the cold. I could hardly drive and even the plastics of the car seem to suffer from brittle fracture at these temperatures. I snapped a plastic front spool outdrive for the first time, too much power I guess
Since you use a stick I could have given you my heated transmitter glove I use for flying if that meant I would get to see the car in action.
@ Mb3195
You are probably right...
Old 01-16-2012, 02:04 AM   #1389
nassosff-3's Avatar
nice presentation πατριώτη!
For sure a very interesting and innovating model-not for the mass of course but this is not always bad...
we're waitin' this machine to prove all expectations!!!
Ferro noscentius aurum
nassosff-3 is offline   Reply With Quote
Old 01-16-2012, 03:25 AM   #1390
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
HiH
Ed
What about this???
Top Racing Photon EX / Mugen MTX-5 / Tamiya M05 / 3 Racing FGX & F113 / Kyosho RB5
Western Zydney Racers (Mini-Z Racing in the west)
http://www.rctech.net/forum/australian-racing/658918-1-28-scale-sydney-racing.html
danjoy25 is offline   Reply With Quote
Old 01-16-2012, 04:14 AM   #1391
mazmo's Avatar
Originally Posted by danjoy25 View Post
What about this???
Looks good Dan, will be in touch to pick up soon.
Team TOP Australia www.topracing.net.au
TOP Photon EX 17.5 + TOP Photon EX 21.5 + TOP Rebel F1 21.5
ORCA | Tekin RS Pro | Tekin Gen 2 RPM | Ko Pro-Po | EPIC Trinity
mazmo is offline   Reply With Quote
Old 01-16-2012, 06:17 AM   #1392
Trader Rating: 18 (100%+)
Originally Posted by FreddySudhoff View Post
@ Mark
Thanks. Good stuff. With the IAS - your set up has really good steering. A lot of body roll - I might have to add sway bars. Had a little chassis drag but an interesting approach.
● AWESOMATIX USA ● ABSOLUTEHOBBYZ ● HEBIKI DESIGN WORKS ●
MDawson is offline   Reply With Quote
Old 01-16-2012, 06:43 AM   #1393
Good to see that it worked for you What for tires do you use? I use
LRP CPX which have a very small diameter and less bite than maybe sorex. So maybe with tires they have more bite try to use distance A= 1-2mm so the car will not have to much bite in front.
Freddy
LRP - Awesomatix
Old 01-16-2012, 07:06 AM   #1394
Freddy
Just testing setups for Snowbirds using the JACO Blues on Prism Wheels. The Jacos tend to push more than the Solaris (M) tires we normally use or even the Sweep tires.
I asked about your track to get a sense of the layout and size. Should be close. If you havent, try a gear diff with putty with your setup. A good balance between the spool and diff.
Old 01-16-2012, 07:49 AM   #1395
The track is about 29x12 m.
I use the ball diff complete tight in front so there should be no slipper effect.
LRP - Awesomatix
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
