Old 04-20-2009, 03:17 AM   #121
yzf-r1's Avatar
wow...
RLM, LRP, Thunderpower, Ko propo, Checkpoint, Hacker, Muchmore, FFE
Cyclone, Sf501, KP09e, 25.5 mono, 26 mono no step, GPV-1,HOR, teamwalbern promods, 5Bss...list goes on
yzf-r1 is offline   Reply With Quote
Old 04-20-2009, 11:50 AM   #122
jhwnissan's Avatar
I really love the idea of this car but as a novice rc car designer, one thing I definitely know is the money is made in the accessories. The car does look exceptionally fast stock, but are there any plans in the pipeline for an inexpensive starter car later down the line? Also, this may sound odd, but what bodies do you typically run? It's a great looking chassis and deserves to have a beautiful body put on top.
Josh
jhwnissan is offline   Reply With Quote
Old 04-20-2009, 04:04 PM   #123
Suspended
Cool
I believe they should make a RTR version with maybe a flux 5700kv type brushless system for under $330 , but I think that it will be hard to find cheap materials strong enough to support the thin design , not to mention frequent crashes. If they can make it work it will be a revolution for bashers and club racers $$$$$$$$ By the way OLEG , WILL THE MAIN SHAFT BE MADE OF HOLLOW TITANIUM ??????????????
bertran is offline   Reply With Quote
Old 04-20-2009, 09:43 PM   #124
Originally Posted by bertran View Post
....By the way OLEG , WILL THE MAIN SHAFT BE MADE OF HOLLOW TITANIUM ??????????????
The main shaft is made of A7075 T6 alloy and holds loadings perfectly now. Insist you on the titanium in this case?
Oleg Babich is offline   Reply With Quote
Old 04-20-2009, 10:12 PM   #125
Airflow's Avatar
Hello Mr. Oleg,
I am a follower of this thread and have high hopes for this car.
I also understand that the car is designed for high level of racing.
But is there any chance that you'll be coming up with a street version
of that car? A touring kit that can withstand the rigors of street
racing. It's ok if it will be made in composite plastics as long as
it has upper deck and enclosed drivetrain.
-Airflow
Airflow is offline   Reply With Quote
Old 04-20-2009, 10:57 PM   #126
Airflow,
The street version assumes considerably bigger expenses for us (moulds for plastic). But we investigate it now.
Old 04-20-2009, 11:23 PM   #127
decibels's Avatar
Originally Posted by Oleg Babich View Post
Airflow,
The street version assumes considerably biggger expenses for us (moulds for plastic). But we investigate it now.
You have to remember that it might be expensive to start with having molds but when you reuse them over and over again it becomes cheaper. Plus probably the most important thing to remember is that us racers support the cars that we like to drive. but we are only few in comparison to the whole market! i would say that over 50% of buyers are impulse buyers and if they see something cheap and quick they will buy it. But us racers understand about the high end and want to have high end cars that really perform. And if you want a company to survive you also have to compensate for the average club racer which just wants the cheap version of everything that handles or i should say is planted and parts are readily available for them to get whenever they like!! but this is my 2 cents worth. feel free to agree or disagree and remember i'm not having a dig at you as i like the car!!
Team Wave Speedies
Thunder power lipo's
flying fox rc
!!And an idiot with a controller!!
decibels is offline   Reply With Quote
Old 04-21-2009, 01:50 AM   #128
decibels,
I completely agree with you in this.
Josh,
We typically run well known 1/10 Touring cars competition bodies.
Old 04-21-2009, 07:32 AM   #129
lutach's Avatar
In my shaft car, I have a carbon fiber shaft and it's been holding up to a lot of abuse. The aluminum one bent.
http://www.youtube.com/watch?v=BikJALhTd8s
http://www.rc-monster.com/forum/showthread.php?t=8651
http://www.cnn.com/2008/HEALTH/conditions/04/01/autism.ireports/index.html (My daughter's video is the last one)
lutach is offline   Reply With Quote
Old 04-21-2009, 08:42 AM   #130
lutach,
There is special main shaft spring defence unit on our car.
The shaft has possibility of moving into a forward gearbox without bending and damage.
It saves a shaft in most cases.
Certainly at very severe accidents when the frame collapses, titanium or carbon shaft do not maintain too .
Old 04-21-2009, 09:24 AM   #131
Trader Rating: 38 (100%+)
I'd like to see more cars include ceramic bearings. Esp with the cost of the cars going up. In bulk I can't imagine they cost that much more then steel bearings. Any thoughts on that?
or8ital is offline   Reply With Quote
Old 04-21-2009, 12:27 PM   #132
over gear's Avatar
Trader Rating: 15 (100%+)
got a pictures of the "special main shaft spring defence unit" . i worry about shafts bending too...
over gear is offline   Reply With Quote
Old 04-21-2009, 02:31 PM   #133
lutach's Avatar
lutach,
Oleg,
Seems like a very nice feature you have in the car. You have certainly done your homework on this awesome machine. I'll be just watching the thread from now on.
Old 04-21-2009, 11:17 PM   #134
Suspended
Cool
Oleg I do agree that a A7075 shaft is very good, but it will all depend on the length of your shaft : TC3 AND TC4 use a 175mm A6061 main shaft that bends a lot when I put a NOVAK 3.5R ON IT (let alone the HV4.5R THAT HAVE ONE OF MY TC4's running); the NTC3 USE a A6061 162mm main shaft that somewhat bends if you put a .12 Picco tuned in there. If the A7075 shaft you use is less than 140mm and hollow(very important) than it will be good for whatever motor you put in ,including a 2.5R at 7.4V(40C). Precisely how long is the shaft? If so, is it hollow?
Old 04-22-2009, 04:18 AM   #135
bertran and over gear,
What damages of a shaft are you worried about - twisting under peak loads from the motor and other transmission components? Or a transversal bending from impacts during collisions?
Or is it due resonant oscillations of a shaft at high RPM?
We have taken measures for prevention of this too.
As it is known A7075 T6 alloy Tensile Strength is almost twice more than 6061 T6 one.
Our shaft is 193mm and not hollow now.
It is the truth that we have not broken any shaft still.
Main shaft protection unit:
This feature allows also to take a shaft out easily without removal of other parts.
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 Yesterday 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
