Old 01-03-2012, 12:04 PM   #1231
Trader Rating: 18 (100%+)
JayBee - just a heads up. I now have over 1500 laps on the original drive shafts, universals, gears diffs and spool - no rebuild required. The axle bushings are perfect.
You can probably hold off on spares for universals if you need to.
● AWESOMATIX USA ● ABSOLUTEHOBBYZ ● HEBIKI DESIGN WORKS ●
MDawson is offline   Reply With Quote
Old 01-03-2012, 12:18 PM   #1232
JayBee's Avatar
Trader Rating: 31 (100%+)
Thanks Mark....I will be pickin' your brain soon.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 01-03-2012, 12:27 PM   #1233
Proper and regular greasing is very important for long life of these parts.
1500 laps is very good!
Mark, what lubricants are you using in A700 now?
Oleg Babich is offline   Reply With Quote
Old 01-03-2012, 12:55 PM   #1234
For bearings, universals & light thin applications - Tri-Flow
For drivetrain - input gears - Wax Lube (bicycle chain lube) or Teflon Dry Lube
For gear diffs - Losi or XRAY CST oils
Both applications provide good coverage and reduce build up of debris/dirt. Big fan of the dry lubes on the drivetrain. Runs quiet and frees up the main shaft and input gears.
Old 01-04-2012, 03:38 AM   #1235
Tbone13's Avatar
Morning Guys,
here is the Video of the last A Final from the GP
http://www.youtube.com/watch?v=edTGD...layer_embedded
my car is the second on the grid.
car was great but with the CPX it push a little to much end of the straight ...
it was a great competition with some of the best Stock racers.
regards Tom
supported by and thanks to:
Modelconcept / Absima Racing / TeamC / Hacker Brushless motors / Awesomatix
Tbone13 is offline   Reply With Quote
Old 01-04-2012, 03:47 AM   #1236
JayBee's Avatar
Nice run though.
Old 01-04-2012, 05:06 AM   #1237
hello Tom..
have a little question about the Ride32 tires set up..what do you suggest as setup cause i can get them work as the sorex..i can drive over 3tenths faster with the old sorex 32 compare to the Ride 32..the sorex sidewalls are a little bit rouded compare to Ride and the Ride need some runs before them start to give some results...
thanks.
i've also tried Ivan Laptev Mod setup and found it also nice and fast to drive with 1mm shim on rear end width and 0.5mm on front battery on R2 position gives more steering and also used his Max out A and Max in B dampers setup..
Did someone tried this out and some feedbacks will be welcome..
thanks to all and Happy new year 2012 with Health and some good results..
method699 is offline   Reply With Quote
Old 01-04-2012, 06:25 AM   #1238
Velocitygt's Avatar
Any of you guys going to be at the TITC (Thailand) in Feburary? Us A700 guys should all work together!
Scorpion Power Systems | Awesomatix | WTF Fans
Velocitygt is offline   Reply With Quote
Old 01-04-2012, 06:41 AM   #1239
Tbone13's Avatar
Originally Posted by method699 View Post
hello Tom..
Hy,
the ride 32 will never be so fast as a Sorex ... the Sorex is by far the fastest (and expensivest) tire on the market. If you are at a Competition where tires are open and guys start running on sorex you have to do the same to be competitiv but alot of races there are tires handout or in a rule so the ride is the best choice cause on handling they are pretty the same, the sorex has more sidebit and do not break in corners.
to make the Ride going well.
- always take of this little rib in the middle of the tire so it will not take 3 or 4 runs to make them work.
- always clean the ride very good after the runs cause often they take some rubber (graining) on the tires.
with these 2 little things the Ride is a great tires with an incredible lifetime...
regards Tom
Old 01-04-2012, 08:09 AM   #1240
TryHard's Avatar
I'll be there... once this weekends F1 race is out the way, I'm going to start concentrating on modified running again... but it's bloody cold in Shanghai atm, and I'm really not sure how representative running on the outdoor track will be, bar getting used to the feel of a modified again.
Still, I might be extending my stay in Thailand anyway, flying out a few days earlier as I've gained some holiday days, so should be able to nail something down before it gets too mental!!
Ed
Old 01-04-2012, 08:32 AM   #1241
Thanks Tom
I'll will try those 2 advices..
Old 01-04-2012, 10:13 AM   #1242
OVA
OVA's Avatar
Trader Rating: 66 (100%+)
Originally Posted by JayBee View Post
Nice run though.
Wecome to Awesomatix Jay Bee
wow there are three A700 in our home town track...that's awesome...
OVA is offline   Reply With Quote
Old 01-04-2012, 10:30 AM   #1243
Magnet Top's Avatar
Great to hear JB. I know you appreciate quality. Its a really nice experience when something lives up to the "hype". You won't be disappointed at all.
Ova, yup... three.... and counting .....
Jake D.
Magnet Top is offline   Reply With Quote
Old 01-04-2012, 10:44 AM   #1244
OVA
OVA's Avatar
Originally Posted by Tbone13 View Post
Morning Guys,
regards Tom
Hey Tom
Saw the video and that was a close battle....thanks for a head up tip
Old 01-04-2012, 10:47 AM   #1245
OVA
OVA's Avatar
Jake D.
Since Jay Bee getting one..also called SpareParts for nick names..we don't have to worry about running out of parts...lol
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
