Old 12-29-2011, 06:00 PM   #1186
OVA
OVA's Avatar
Trader Rating: 66 (100%+)
Originally Posted by danjoy25 View Post
Can you guys confirm which is the BSB Number and Account Number from:
IBAN[USD] CY80 0030 0158 0000 0158 3200 8047
My incompetent bank is asking for it and they won't process the transfer as my initial order was via Western Union so not sure what the go is.
I used the pay pal. instead the banking hassles
OVA is offline   Reply With Quote
Old 12-30-2011, 01:32 PM   #1187
ran my car for the first time today using the laptev ats setup.
Initial impressions are incredibly positive, 2/10ths quicker than I had managed with my t'12 earlier in the day
As the car is totally new to me, I'm pretty stuck on what to do to get the car to go a bit quicker, I could however do with a tad more steering.
I'm using ride 25 tyres, i reduced the front toe out to around 1 degree and also reduced the front width back to standard, other than that it was as in the setup, any suggestions??
Mb3195 is offline   Reply With Quote
Old 12-30-2011, 01:50 PM   #1188
Originally Posted by John.C View Post
Hi guys,
Thanks for the feedback. Please find attached my START and END setup sheets from this past Monday. I had cut the top deck on my 3rd outing right after my first qual.
Starting setup
Attachment 854206
Final setup (much better but still loose in the rear)
Attachment 854209
Have you definitely used SRS/RHS ARR I ?
At this case your suspension stiffness is much higher than recommended (front and rear).
If your actual SRS/RHS ARR is II then rear stiffness is too low.
Oleg Babich is offline   Reply With Quote
Old 12-30-2011, 02:10 PM   #1189
Try to move closer to Tom Maquel's setups - add 0.5mm shims under rear lower balls and remove these shims from front.
Sometimes 2.5 deg rear toe is better also.
Old 12-30-2011, 02:39 PM   #1190
speedyfowler's Avatar
Finished my build yesterday, this kit has amazing parts fit/quality.
Get my first run with it tomorrow! I'll be trying to get a similar feel to my 417.
Thanks Oleg for such a great kit, I can't wait to see how it compares to my current fast lap/6 Minute run !
Steve Fowler
Team Serious Business
Outlaw RC Motorsports / Protoform
Lou's Speedway/Much Hobby/RC Niagara Indoor
speedyfowler is offline   Reply With Quote
Old 12-30-2011, 03:58 PM   #1191
Steve,
Concerning upper arms length for any setup - I need more time to calculate it.
But all estimates are always approximate.
The final adjustment - only at the setup station.
Old 12-30-2011, 04:07 PM   #1192
Okay no worries, I'll have to borrow a friends for the time being, until I can pick one up.
thanks for getting back to me
Steve Fowler
Old 12-30-2011, 04:23 PM   #1193
John.C's Avatar
Trader Rating: 36 (100%+)
I'm at SRS/RHS I and I think this may be part of my problem. As you've already mentioned I noticed that my current spring/dampening setting are higher than what's been posted. I'll make this change at my next outing. What would you recommend for 17.5 blinky?
BTW are folks running as much as 2* toe out in the front? If it'll help prevent traction roll I'm willing to try it out. Thanks Tbone, Oleg, and everyone!!!
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Old 12-30-2011, 10:01 PM   #1194
TryHard's Avatar
Well, my car is complete, and I have to say, it's been a top notch and quality build. All the fit and finish is excellent, and any concerns I've had about some of the smaller parts (driveshaft clips etc) have been completely removed. Even the plastic quality is great, the ball cups being way easier to thread than some 3Racing ones I've recently had to do.
I've spent the last few evenings exploring/fiddling with how to adjust the settings, as well as working out a methodology of what to adjust first.. the two top links are new to me, but at the moment I'm going with setting camber first, then setting castor. Then setting toe-in when the other settings are sorted. Shocks wise, A first, then B.. And I've also managed to get my head round quickly assesing if a shock setting is soft or hard from the numbers...
At the moment, I've built the car up with Ivan's ATS settings, mainly as the track I'm currently running my 417 ATS setting is working quite well, although I might need to change the spring and damping rate a little. Won't be able to get it ontrack for at least a week though, as I'm still waiting on some electrics to arrive.
Can't wait to try it, and start working through a load of options!
Cheers
Ed
Old 12-30-2011, 10:36 PM   #1195
Trader Rating: 18 (100%+)
Cheers
Ed
Well done! Hopefully it was worth the wait. Curious to hear your thoughts as you came from an excellent TC already. It will feel like you went from a 7 series BMW to a M6!
Time to start a new section of your website!
● AWESOMATIX USA ● ABSOLUTEHOBBYZ ● HEBIKI DESIGN WORKS ●
MDawson is offline   Reply With Quote
Old 12-31-2011, 08:12 PM   #1196
TryHard's Avatar
already done
Old 12-31-2011, 08:22 PM   #1197
Magnet Top's Avatar
Thumbs up
Happy New Year to all my A700 mates !
I'm wishing you all Awesome cornerspeed and all the active caster you can handle !!!
Jake D.
Magnet Top is offline   Reply With Quote
Old 12-31-2011, 08:40 PM   #1198
Happy New Year to all the members of this forum. Looking forward to big strides from the Awesomatrix camp. Thanks to Oleg and team for delivering a top tier product. Cheers!
Old 01-01-2012, 09:10 AM   #1199
Well, I had my first outing with the A700 yesterday, and all I can say is WOW!
I started off with Tom Maquel's high traction carpet setup, except I ran the dampers with the symmetrical setting, 1.3mm sway bar on the front and 1.2mm in the rear, the battery in the R1 position, and 800cst in the gear diff. Within the first battery pack in practice, I was within 2 tenths of my fast lap on this layout that I had set with my 417. Near the end of practice, I was feeling more comfortable with the car, but made a big mistake and broke a ball cup (P01). I also made an error in a fairly high speed chicane and the car tumbled end over end, and was still fine (some setting had been tweaked, but nothing broke).
In my first qualifier, the car felt really good. I managed to beat both my personal records (best 6 min race and fast lap), and managed to get TQ by a second which at our local track isn't easy. Racing against top drivers like Martin Crisp (team Serpent), and Andrew Hardman (many sponsors, although he wasn't there this week). In the final, Martin managed to get in front of me on the 3rd corner and hold me off, but I'm really impressed that I was able to stay as close as I did to him.
Here's a video of the main (my car is orange/blue/white)
http://www.youtube.com/watch?v=7ZeNbNmBgkc
With the same Tekin RS settings, motor timing, and gearing as I ran in my 417 (coming off at 170-180*F), the motor was coming off closer to 140-150 thanks to the super efficient drive-train. It was also quieter then I expected based on prior experiences with shaft drive cars.
For minimum weight we run 1380 grams, and the car out of the box with my electronics (picture below)and the body, it weighed 1325. It was nice to be able to add all the weight to the center line of the car under the shaft.
All in all, a very promising first outing with the car. Next week I plan on trying some thicker oil in the gear diff (1000cst), running with less rear toe (2.5*), and some different shock settings (although I was very happy with the setup today, I just want to get a better idea on how to use these dampers over the conventional TC dampers). Can't wait to get back on the track with this car!
Steve Fowler
Last edited by speedyfowler; 01-01-2012 at 02:28 PM. Reason: forgot to mention different battery position
Old 01-01-2012, 09:41 AM   #1200
Great Thanks to all current owners of A700!
It is with you we can evolve now.
Happy New Year!
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
