Old 12-01-2011, 12:51 PM   #991
Trader Rating: 19 (100%+)
Originally Posted by vlad_vy View Post
Thanks Vlad.
Separately, what is the status of the orders? Have sent a couple of emails through - no replies yet.
MDawson is offline   Reply With Quote
Old 12-01-2011, 02:12 PM   #992
Seriously, does anyone actually want to sell this car?? I've sent about 5 emails over he past week and have not had a single reply!!
Mb3195 is offline   Reply With Quote
Old 12-01-2011, 02:17 PM   #993
Luke Hobson's Avatar
Send a message via MSN to Luke Hobson
Same position for me... Im ready to order
Luke Hobson
Awesomatix - Xenon - Godzilla Paint - Moorespeed - ToniSport - MBmodels
http://luke-hobson.blogspot.com/
Luke Hobson is offline   Reply With Quote
Old 12-01-2011, 03:26 PM   #994
Your a brave man Luke you already own about the most fagile car there is, and you want to buy THE most fagile car there is, save your money and get some spares for your 417
Bb
bucketboy is offline   Reply With Quote
Old 12-01-2011, 03:57 PM   #995
Bb
Fagile.... twice lol. I have to say the car is far from FRAGILE, looks like you have been misinformed mate! In all seriousness though no one here has been complaining about major breakages or inherent design faults, yes the car may look a bit different, but the engineering is top notch, I think you'll agree once you see Lukes car in the flesh
MarkMcC is offline   Reply With Quote
Old 12-01-2011, 04:07 PM   #996
Yeah, yeah, speeling is not my srtong point I think the car looks great, but the wishbones on ball studs and those CVJ's look like trouble to me
Hope I'm wrong.
Bb
Old 12-01-2011, 04:22 PM   #997
Velocitygt's Avatar
Oleg adds cars to the website as they are available to be sold, if their are no cars in stock on the site, then there are no cars available to be sold. At this point in time emailing him will not speed up the process. Just keep checking the website to see if stock has been added.
There had been a slight delay in the manufacturing process last week as the wrong carbon was delivered to the factory. This would have impacted availability.
Stock should be flowing again soon!
Scorpion Power Systems | Awesomatix | WTF Fans
Velocitygt is offline   Reply With Quote
Old 12-01-2011, 04:32 PM   #998
I think it'll be just fine
Luke
Luke Hobson
Old 12-01-2011, 04:45 PM   #999
Hope I'm wrong.
Bb
Sorry no offence meant mate, just taking the piss. I have to admit I was worried about the durabilty also at first and ordered quite a few spares just incase, I'm no Pro and have had a few crashes, some my fault and others "racing incidents", so far only a turnbuckle has bent. The driveshafts look to be made of hi-tensile steel with ECS style in the front and a unique design in the rear, no signs of wear/bending yet. The wishbones are a beefy 3mm carbon, theres more chance of the balljoint popping off before it would break, touch wood. Have you seen one in the flesh yet?
Old 12-01-2011, 08:39 PM   #1000
Right now may be some delay in responses from Oleg, he is at business trip in Taiwan.
vlad_vy is offline   Reply With Quote
Old 12-01-2011, 09:04 PM   #1001
Thanks Vlad.
Old 12-01-2011, 10:08 PM   #1002
I have received a couple of emails/PMs for a quick list of nice-to-have-parts. My suggestions are:
PRIORITY 1 - GOOD TO HAVE DAY 1
1. A single complete universal (Page 5) - haven’t worn one out or had any failures – typically like to have spares for essential drivetrain components.
2. 1 set of either bronze, round or c-clip bushings (Page 5)
3. SPR07 – E-ring. Very tiny and critical to keeping the clips/bushings in place
4. QTY 1 – C04 Arm – haven’t broken one to date but a good just-in-case
5. QTY 1 – P04 Lower Hub Mount - could elongate on serious crash
6. QTY 1 – P01/P02 – Specialized to the A700 and critical to front/rear suspension
7. QTY 1 –Ball End Set – Not specialized for the A700, Kyosho offer similar and upgrade HARD ends.
8. QTY 1 – Long Turnbuckle – the suspension has to have some place to absorb collision. Have bent/broken one of these.
9. QTY 1 – Short Turnbuckle – same as above.
PRIORITY 2 - UNLIKELY YOU WILL NEED RIGHT AWAY – BUT IF IT GOES BAD, YOU ARE PREPARED
1. QTY 2 – B106RS Bearings - haven’t worn one out or had any failures – typically like to have spares for essential drivetrain components.
2. QTY 1 – SPR01 – haven’t bent one – could potential straighten if needed
3. QTY 1 – SPR02 - haven’t bent one – could potential straighten if needed
4. QTY 1 – P09 – frequent changes to suspension might wear plastic part
5. QTY 1 – Gear Diff Rebuild Kit – follow Olegs modification instructions. Surely may not have to rebuild a rear-installed gear diff. But if you run a front gear diff with putty – it might wear faster than the rear.
6. QTY 1 – Extra Spool - haven’t worn one out or had any failures – typically like to have spares for essential drivetrain components.
7. QTY 1 – AT04 – Drive Shaft - - haven’t worn one out or had any failures – typically like to have spares for essential drivetrain components.
Good luck!
Old 12-02-2011, 04:10 AM   #1003
Velocitygt's Avatar
Great list Mike. Agree on all parts.
Thought I might add that the gear diff gears are Spec R and I highly recommend upgrading them to the black carbon type as well as doing Olegs modification.
Old 12-02-2011, 10:09 AM   #1004
erchn's Avatar
I hadn't heard this before, not that I'm doubting but, can anyone confirm this?
Thanks,
Ethan
erchn is offline   Reply With Quote
Old 12-02-2011, 12:36 PM   #1005
hanulec's Avatar
Trader Rating: 23 (100%+)
Hey Dawson - maybe you could post up more stuff here:
http://racerlog.com/wiki/Awesomatix_A700
I just copied your above data... might be easier to find for folks starting out with this ride...
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17195 01-10-2017 05:04 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
