Awesomatix EP Touring Car (A700 Shaft Drive)
#8401
Hi Mike that stuff is awesome. I soaked the originals in the the Dow55 and it was a huge improvement, I just thought I'd give the silicone O rings a try.
#8402
Hoping this will address my oil seepage issue enough to hold me over until I can get some D2.1 upgrade parts.
#8403
Going to pick up some Dow55 today since I'm going to be rebuilding my dampers with new O-rings this weekend. How long is a good amount of time to soak the O-rings before I do the install?
#8404
sorry for somewhat dated news -- congrats to the Awesomatix USA team at 2015 Mile High Champs -- http://www.awesomatixusa.com/2015/05...2015-mile.html
#8405
My A700s (EXL and Evo) has been pushing so much mid corner, I have to lift off throttle just to get the car pass the corner. I run at an outdoor asphalt track for 1/8 with wide bends and great traction. No matter I duplicate different posted settings on the cars or go by my own fiddled with the suspension and tried different tyres nothing changed the pushing persisted. It was so bad that I shelved them for some time now. Any clue on setting or things that I should try before I let them go?
#8406
R/C Tech Elite Member
I'd play with rear grip only because u say there is high grip. Normally on asphalt your hunting for rear grip.
Try each of these by themselves first-
Less Rear toe
Add more shims on the am23 toe link to reduce rear toe under suspension compression
Add shims (2mm+) to the inner rear camber link
Less rear camber
Thicker diff oil. 5k+
Please reply back with a filled out setup sheet so we can actually help. Please list the track, tires and traction compound too..
#8407
Thanks for the tip.
No the car is not traction rolling.
I don't know how to post my setup sheet, but I would put down my setting for the Evo with graphite chassis below:
Camberlinks: All on the outer holes. Shims: FF 4mm FR 2mm RF 2mm RR 2mm tip of a-arms on all corners 2mm
No shims under A arms
Bump steer shims F0.5mm R4mm
Camber on all corners: 1.5
Caster 4
Toe-out 1
Ride height F5.5mm R6mm
Shock setting F 2mm/3mm (79.5gf/mm) R2mm 4mm (86.3gf/mm)
10.5T motor FDR7.49
Rear diff GD2 with 2000 diff fluid
Tires Team Powers
Other things according to manual
The track is overseas. Outdoor asphalt smooth with wide bends and long straights designed for 1/8. Not technical and high speed, very easy track I must say. My other cars (BD7/TRF) would traction roll at times, but not the A700s. The problem is even with this non-technical track with wide bends my A700s push too much mid of the turn, so much so I had to let the car roll through the turn. The same is not with my BD7 nor my TRF419 at stock setting with the same tires and more powerful motors, and even my T4 won't be as pushy at the middle of the turn. Even stock setting A700EXL pushed, I thought the Evo might be different, but it very much feel the same as the EXL.
Thanks for any help
Caster 4
Toe-out 1
10.5T motor FDR7.49
Tires Team Powers
Thanks for any help
#8408
blackshark3 - you want short camber links. mounting camber links onto the bulkheads will make the car lazy
i'd add 0.5mm under the AT21 or 1mm under AT21s balls.
i'd also recommend either flat, or FF lower than FR on camber links.
are you shocks type 1 or type 2 config? i don't know which # u list above are the A and B values.
#8409
#8411
Thanks for the tip.
Caster 4
Toe-out 1
10.5T motor FDR7.49
Tires Team Powers
Thanks for any help
Caster 4
Toe-out 1
10.5T motor FDR7.49
Tires Team Powers
Thanks for any help
#8412
Quebec national this week-end !
The cars was great ! Very consistant and fast. My stock car (Evo2) was really money.
#8415
Aluminum chassis for carpet for sure. The stiffer chassis plus the lower cg make it better suited for carpet level traction. The aluminum chassis kit also includes the brace for the chassis so you can tune the flex for your traction level
