Old 11-11-2011, 07:06 PM   #811
Trader Rating: 18 (100%+)
Almost too nice to set on a track!
● AWESOMATIX USA ● ABSOLUTEHOBBYZ ● HEBIKI DESIGN WORKS ●
MDawson is offline   Reply With Quote
Old 11-11-2011, 07:23 PM   #812
Old 11-11-2011, 07:26 PM   #813
transplantlife's Avatar
Trader Rating: 43 (98%+)
Very nice
IM A SURVIOR OF A DOUBLE ORGAN TRANSPLANT KIDNEY/PANCREAS...PLEASE BE A ORGAN DONOR TO GIVE LIFE TO OTHERS!!
transplantlife is offline   Reply With Quote
Old 11-11-2011, 07:31 PM   #814
Old 11-11-2011, 10:14 PM   #815
Trader Rating: 26 (100%+)
Anyone know if the online shop on Awesomatix site is working or are parts to be ordered via email.
eddie10 is offline   Reply With Quote
Old 11-11-2011, 10:31 PM   #816
Team EAM
EAMotorsports's Avatar
Trader Rating: 73 (100%+)
Send a message via AIM to EAMotorsports
Mark thats just not right!!
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | ProSpec America | Killer Concepts | AVID | Futaba.
EAMotorsports is offline   Reply With Quote
Old 11-12-2011, 12:47 AM   #817
Infinite 12th's Avatar
Hey I thought perpendicular motor setup build was the one to have with no torque steer?
What gives
12th scale - The Jedi class...
Infinite 12th is offline   Reply With Quote
Old 11-12-2011, 06:36 AM   #818
Torque steer is probably not a issue in Stock classes.
You then want the motor straight with the spur to minimise friction.
MatsNorway is offline   Reply With Quote
Old 11-12-2011, 12:57 PM   #819
daleburr's Avatar
What gives
Torque steer is almost non-existant with brushless motors due to the lower rotating mass and smaller diameter of the rotor. Unless you're running mod I don't think you'll feel it.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is online now   Reply With Quote
Old 11-12-2011, 01:59 PM   #820
Originally Posted by John.C View Post
Oleg/Awesomatix team drivers - Do you have any photos/dimensions of the newly released IAS? Additional info on the following items would be greatly appreciated.
A700-AM20 AM20 IAS Steering Rod
A700-AM21 AM21 IAS Steering Plate
A700-AM22 AM22 IAS Steering Arm x 2
I'm interested to know how these compare to the stockers? I assume the team drivers have been testing the new setup. Any feedback?
Please see the picture attached.
At the same time combination of AM20 and AM21 delivers a bit less AM20 Steering Rod travel.
IAS set can provide more Ackermann value setting, more linear "steering feeling" near to max. steering angles but several degrees less max steering angle herewith.
Steen Graversen likes to use this steering system although Ivan Laptev prefers standard steering set.
So generally speaking it is a matter of personal preference and features of a particular driver.
Oleg Babich is online now   Reply With Quote
Old 11-12-2011, 07:14 PM   #821
Day one was promising. The drive-train is highly efficient - motors ran cooler and now have some opportunity to gearing up.
I need to spend some time looking at the dampening chart. I started with Steens IIC setup (found the car to be really 'tight', generated good grip but didnt pivot well on the 180s) and then decided to go with a 'softer' dampening using Laptev ETS and found the car to perform better on 'tight' carpet tracks such as ours in the US. Fast laps with Steens setup were in the 12.3's and by the end of the night with Laptevs setup I was in the low 11's.
To work on this week:
  • Dampening - need to get a better handle finding similar dampening to normal setups in the 16lbs/40wt/2hole fronts & 14lbs/40wt/3hole rear. I thought Laptevs settings were a good start but needed less spring and more dampening rate.
  • Equivalence to running short or long wheelbase - as our tracks in the US are extremely tight and higher bite - the better cars are the ones that can pivot in tight places - I can usually use wheelbase with softer springs to get the car to rotate and pivot .
Good work list for the week. The car was very responsive to changes.
Old 11-13-2011, 12:06 PM   #822
hana166's Avatar
Laptev settings use longer links right? and different ackermann hole in steering block. Its extremely different from Steen setting. If I make the camber link 1.5mm longer on my Xray its massive. The difference here is like 4mm.
With the long links they are longer than the wishbone, so camber gain is...opposite way of every other TC. Can't imagine what that would be like. Also no stabiliser bars.
Got a feeling I've bitten off more than I can chew. Could easily get lost in the set up, its like a different language. Took me a long, long time to find my basic set up which works for me.
Will start with Steen basic carpet set up on Tuesday, I have no idea what to expect
hana166 is offline   Reply With Quote
Old 11-13-2011, 12:36 PM   #823
I tried Steens IIC set up with both the long and short links The longer links made the car really stable on carpet - will add this to my notes to try outdoors. The stock ackerman positions - outside link made the car wash out initial to mid. The inside link provided more initial of the two.
Old 11-13-2011, 01:55 PM   #824
Laptev settings use longer links right? and different ackermann hole in steering block...
Steen have informed me that he uses AM22 steering arms at this his setup.
Old 11-13-2011, 03:50 PM   #825
hanulec's Avatar
Trader Rating: 23 (100%+)
I suspect you are not alone. Just remember to not bang up the car that bad as you could probably buy a new top/tamiya/xray/associated (+ parts) for your used ride. I think in the right hands this car will be deadly -- killing it out on the track..
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
