Old 01-26-2015, 02:23 PM   #7921
kgombe's Avatar
Originally Posted by daktulos View Post
Hi, if you don't find the Awesomatix the Tamiya part number 51253 fit well on the front of an Awesomatix... Probably other manufacturer also fit.
are the body posts the same distance apart?..
Kijana Crichton
kgombe is offline   Reply With Quote
Old 01-26-2015, 03:12 PM   #7922
cmunro's Avatar
Just wanted to say thanks to oleg , he has been very helpful with every question i have had. great customer service thank you oleg!!!!
REFLEX RACING/TRINITY/HOBBYWING/AIRTRONICS
cmunro is offline   Reply With Quote
Old 01-26-2015, 05:13 PM   #7923
daktulos's Avatar
Yes exact fit!
daktulos is offline   Reply With Quote
Old 01-26-2015, 05:19 PM   #7924
kgombe's Avatar
Yes exact fit!
thanks bro only finding it on Ebay.. gonna order now... appreciate it
Kijana Crichton
Old 01-26-2015, 05:53 PM   #7925
Hi, until Oleg found the time to "update" the manual read John Doucakis presentation to have an overall idea how parts go together
http://www.rctech.net/forum/13790309-post7866.html
Personally I use the DT03 in the "no flex" position (the recess on the side of the spur) to act as a bearing spacer.
John doesn't have it in his build either. I used his blog as my go to during the entire build.
damo is offline   Reply With Quote
Old 01-26-2015, 06:52 PM   #7926
daktulos's Avatar
Ya he made a correction right after the SD2 presentation!
Old 01-26-2015, 09:12 PM   #7927
Cadman1981's Avatar
My shaft does not look like this pic at all
The package shows AT04-2 but the one i have does not taper as far back as in the picture, but about 1mm after the "T-ball" part on both ends, and it looks like it's touching my steering guide. Anyone else have a shaft like this?
Awesomatix A700L
Tamiya Exotek F104v2
HPI Vorza HP 2.4ghz
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 01-26-2015, 09:44 PM   #7928
The drive shaft I have is the lower one in the picture. I haven't had any issues with it touching the steering guide.
AL
www.carcar.ca / www.karz.ca
ALBOP is offline   Reply With Quote
Old 01-27-2015, 12:50 AM   #7929
josecarlo1129's Avatar
Hi Oleg/Mike,
Can you confirm if these are the complete set of parts needed for the A700-C01AL-S2 Upgrade?
- A700-C01AL-S2
- A700-P06-1
- A700-AM33-5
- A700-AM49-3
Plus, when will be the FCB - Flexible Caster Block Set will be available at your good site?
Best regards,
JC
Nitro: On-road 1/8: Motonica P81-RS2/Vox/Savox
Off-road 1/8: JQ TheCar/Vox/Savox
Electric: On-road 1/10 TC: Awesomatix A700 EVO/AE BD/Team Orion/Ko Propo
On-road 1/10 F1: 3Racing FGX + RC9394 Carbon Conversion AE BD/Team Orion/Ko Propo
josecarlo1129 is offline   Reply With Quote
Old 01-27-2015, 12:59 AM   #7930
Originally Posted by josecarlo1129 View Post
Hi Oleg/Mike,
- A700-C01AL-S2
- A700-P06-1
- A700-AM33-5
- A700-AM49-3
Best regards,
JC
Hi JC,
This list is correct.
You will need also few SF3x5 or SF3x6 and one SB3x6 screw for mounting of AM33-5 and AM49-3 but I hope that you have enough such screws in your pit box already.
Oleg Babich is offline   Reply With Quote
Old 01-27-2015, 01:10 AM   #7931
arn671's Avatar
Trader Rating: 14 (100%+)
Default Oleg pm with ???
Hi Oleg, I sent you an email through here with some questions. Thanks!
arn671 is offline   Reply With Quote
Old 01-27-2015, 01:20 AM   #7932
Cheers, Oleg!
Will be placing them soon. I am just waiting for the FCB set so I'll get them altogether.
Thank you, once again, sir.
JC
Old 01-27-2015, 04:44 AM   #7933
have two of the type you're describing must be a AT04-2 RevA and the one in the photo is an AT04-2 RevB. Mine doesn't rub on the steering rack, it is very tight but after a few weekends of use I have no rub marks near the steering rack.
A700 17.5 Stock, USGT, CVTA, RCO Sportsman
WF D06 USVTA
trackout is offline   Reply With Quote
Old 01-27-2015, 06:44 AM   #7934
Stogie's Avatar
I noticed my AT04-2 was rubbing slightly on the steering rack upon initial installation, but this was easily rectified by adding .5mm shimming between the aluminum bulkhead and the AM10 steering plate. (Moves it down slightly).
Just be sure and double-check the shimming for your servo rod after doing this to make sure it's not rubbing on the drive shaft. You may need to shim the ball stud up .5mm to compensate.
☆☆☆ Chad Stowe ☆ ready to run some Mod TC again, finally ☆☆☆
Stogie is offline   Reply With Quote
Old 01-27-2015, 03:20 PM   #7935
Default back ordered
Does anyone know when the evo 2 will be back in stock in the usa hoping to get one before end of February
tbamsey is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17189 Yesterday 03:25 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
