Old 01-14-2015, 06:18 PM   #7831
kerry's Avatar
Originally Posted by imprsme View Post
Mike posted that set up on the AwesomatixUSA web site.
I hope it works as well for others, as it has for myself.
This set up is for a lower to medium traction track.
I ran it with a Mazda Speed6 mainly. But did try a Dart this past weekend and felt like it was just as good.
how did you like the car running soft springs compared to the standard kit ones that come with the evo 2
kerry is offline   Reply With Quote
Old 01-14-2015, 07:01 PM   #7832
imprsme's Avatar
Trader Rating: 70 (99%+)
I have never ran anything but the soft springs. Those were what came in the Evo kits and seemed to be what everyone was using.
AwesomatixUSA
eXpress Motorsports
imprsme is offline   Reply With Quote
Old 01-15-2015, 05:18 AM   #7833
Default Alloy chassis?
I have two 700L cars, want to try a alloy chassis, what is the part # I should be looking at?
TWILL is offline   Reply With Quote
Old 01-15-2015, 06:45 AM   #7834
hanulec's Avatar
Trader Rating: 23 (100%+)
you're best option is probably the C01AL-S2 (from Evo II kit) or the C01AL-S
both are being produced still
C01AL-S2 is more narrow, but the narrowness limits how far out you can run your dampers. 3.6mm for an 'A' gap is the maximum on C01AL-S2 vs 6-7mm on the C01AL-S
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 01-15-2015, 07:50 AM   #7835
Trader Rating: 54 (100%+)
Either of these chassis in stock? Would prefer v2
Jamison R is offline   Reply With Quote
Old 01-15-2015, 08:29 AM   #7836
SLOWINSLOWOUT's Avatar
Trader Rating: 16 (100%+)
I have an A700EVO for sale if anyone is looking for one.
_____________________________________
Earl Towson
KRC WCICS.ca club rep. http://www.krcracing.ca
SLOWINSLOWOUT is offline   Reply With Quote
Old 01-15-2015, 08:43 AM   #7837
I ended up running with 'A' gaps 4.0 in the front, 4.4mm in the rear on the new chassis with no ill effects. Just got to make sure the dampers are straight and tighten the clamping screw firmly.
Earl Towson
Old 01-15-2015, 11:18 AM   #7838
RC Professor's Avatar
One thing to keep in mind is that the one piece motor mount you probably have on your cars may not work on the C01AL-S2 chassis. I believe a hole or two needed for that mount don't exist on the newest chassis (someone correct me if I'm wrong). I think you'll need the new motor mount if you go with this one.
The C01AL-S chassis, however, works fine with the one piece mount.
RC Professor is offline   Reply With Quote
Old 01-16-2015, 09:38 AM   #7839
cmunro's Avatar
Hey guys lets see if anyone can help me I have been running my evo1 in 17.5 on carpet for less than a month I have broken 3 spools the gear cracks between the teeth and comes off of the aluminum part , 2 of them were the at03 I guess and one was the at03m-s 2 of them broke with a traction roll and the other one just seemed to fail with no big impact , what iam I doing wrong? Do I need a spur damper? Is my ffg set up wrong? also dont know if it has any effect on the part but each time i have broken one it has been pretty cold ,mid to high 30'f
REFLEX RACING/TRINITY/HOBBYWING/AIRTRONICS
cmunro is offline   Reply With Quote
Old 01-16-2015, 09:54 AM   #7840
hanulec's Avatar
charlie - you should provide the additional context about the cold (near 0 C) warehouse that you are racing within...
Old 01-16-2015, 09:58 AM   #7841
Xpress's Avatar
Originally Posted by cmunro View Post
Hey guys lets see if anyone can help me I have been running my evo1 in 17.5 on carpet for less than a month I have broken 3 spools the gear cracks between the teeth and comes off of the aluminum part , 2 of them were the at03 I guess and one was the at03m-s 2 of them broke with a traction roll and the other one just seemed to fail with no big impact , what iam I doing wrong? Do I need a spur damper? Is my ffg set up wrong? I just don't know
Wow....I've been on same spool for 6 months with no issues. Have you been going thru front axles also? do you have the lock stop screws the "knuckles"? Wondering if your hitting boards and having the axles over actuated and locking up the front end? Usually when I have a good hit the FFG twists. on the rod...I think kind of like a shear pin.
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 01-16-2015, 10:10 AM   #7842
cmunro's Avatar
no bent or broken axles i havent ever had a turnbuckle pop off i do have the stop screws in the knuckles not really hiting anything but i guess when you traction roll you are hitting the ground
Old 01-16-2015, 10:19 AM   #7843
cmunro's Avatar
not quite 0*c but 2.5-5*c the coldest i think has been 36-38*f , it is only cold for about a month or here in houston but hot as hell the rest of the year
Old 01-16-2015, 03:15 PM   #7844
Default The package has arrived...
Now to begin the painstakingly fun part of this hobby..... building a new kit.
damo is offline   Reply With Quote
Old 01-16-2015, 03:33 PM   #7845
John Doucakis's Avatar
Default presentation done
So I am done with the assembly of the new kit.
click on the photos for more.
Here is the entire process
and here is a photo album for your eyes only :-)
John Doucakis is offline   Reply With Quote
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10911 11-28-2016 07:09 AM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
