Old 01-11-2015, 07:34 PM   #7786
Trader Rating: 54 (100%+)
Awesomatix 1, 2 today at hob-max.
Jamison R is offline   Reply With Quote
Old 01-11-2015, 10:11 PM   #7787
Xpress's Avatar
And 1-2 at BRR!
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 01-12-2015, 01:08 AM   #7788
Default Thanks
Originally Posted by AwesomatixUSA View Post
P13-4 are on order, but haven't shipped. ApexRC in Hawaii cleaned us out..
Get the OR05S -- they are softer. Use a lot of green slime.
other things that help-
stiffer front springs (smaller B #)
softer rear springs (larger B #)
less negative front camber
more front dampening (larger A #)
less rear dampening (smaller A #)
less rear droop
Thanks for the help, I'm not Farr off of a good setup. This info will be VERY HELPFUL.
TWILL is offline   Reply With Quote
Old 01-12-2015, 04:40 AM   #7789
Wow 1 & 2 were VERY close, those 5-10-15 times are almost identical.
A700 17.5 Stock, USGT, CVTA, RCO Sportsman
WF D06 USVTA
trackout is offline   Reply With Quote
Old 01-12-2015, 05:08 AM   #7790
Was a great race to watch. Josh's first day with an awesomatix. Actually second battery on the car. He drove associated last 2 years. He doesn't want to drive that ever again his words.
Anthony's TQ run was pretty impressive as well. I believe he was the only person to do 34 laps all day.
Hanulec-how many orders out are you on Evo 2? I need to get one ordered asap if it's possible to have one before snowbirds. If not I will order after.
Old 01-12-2015, 05:22 AM   #7791
AwesomatixUSA's Avatar
Congrats in the win Josh.
In Western Canada I await photos from the 17.5 TC and VTA winners Jake D and Jacob R. The boys came up a little short in Mod, but had a great showing overall.
Mike Gee this past weekend TQ'd a small turnout at Horsham with his new EvoII in stock. Setup sheet should be available soon.
10 kits should be awaiting pickup at the PO. If the order is complete then 4 are unspoken for...
Official North American Distributor of Awesomatix, Wild Turbo Fan & Mon-Tech Racing
shop.awesomatixusa.com / www.awesomatixusa.com
#winning - 6x ROAR Nationals, 2x Reedy Race, 2x Snowbirds, 1x IIC, 5x Halloween Classic, 4x US Indoor Champs, 2x Mile High Champs
AwesomatixUSA is offline   Reply With Quote
Old 01-12-2015, 07:20 AM   #7792
I will take 1 of those 4. lmk when confirmed 4 unspoken for.
Old 01-12-2015, 09:19 AM   #7793
imprsme's Avatar
Trader Rating: 70 (99%+)
At our points series at HoB Max in NC.
I was able to Tq all six races. Won 4 of the six to take the overall points.
So with Josh's win that gave Awesomatix 5 wins in the series. The only lose was a dnf on my part after getting hit while leading the main and popping a ball cup off.
I was just glad to see someone that had never driven the car pick it up and wheel it like Josh did. Makes me feel better about the set up I've tried to share with the other guys. I thought it may end up only suiting my driving style.
Jamison- I say plan "B" worked! Lol
AwesomatixUSA
eXpress Motorsports
imprsme is offline   Reply With Quote
Old 01-12-2015, 10:27 AM   #7794
What is the defference between the C01AL-S2 and the new carbon chassis in terms of stiffness? Why/when would you choose the carbon over the aluminum or vice-versa?
WF D06 USVTA
Old 01-12-2015, 10:38 AM   #7795
Xpress's Avatar
Originally Posted by imprsme View Post
Please post if you find a fix. Mine leaks out the right side out drive only. I have tried all I know to stop it and nothing's has done so,so far
Originally Posted by cmunro View Post
Mine is the right side as well
Originally Posted by Gtr r34 m-spec View Post
I had to thread lock the grub screw in the diff out drives to stop mine leaking.
I re green slimed the O-rings and cranked on the setscrew and no sign of a leak. I'm not sure if cranking the setscrew or green slime fixed it? The diff was built with green slime on the O-rings so if the leak returns I'll know it is thru the seals.
-Espo
Old 01-12-2015, 11:05 AM   #7796
Indeed "Plan B" worked. Was fun watching that race.
Old 01-12-2015, 11:14 AM   #7797
hanulec's Avatar
Trader Rating: 23 (100%+)
Anthony - pls share you setup...
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 01-12-2015, 11:19 AM   #7798
Xpress's Avatar
Mike,
Will there be parts available in Florida?
-Espo
Old 01-12-2015, 12:03 PM   #7799
cmunro's Avatar
just wanted to say thanks to mike for the great customer service the past week i have been blowing up his inbox
REFLEX RACING/TRINITY/HOBBYWING/AIRTRONICS
cmunro is offline   Reply With Quote
Old 01-12-2015, 01:29 PM   #7800
Need some help.
I had a big race this weekend, and I had problems with my steering all weekend. The issue is, that if I set up the steering on the setup up bench, and everything is stright, then if I just hit a disc on the track, then my steering is off by some degrees ???
First I thought it was my servo allluminium horn, that was the problem, but changing it didn't make any diffrent. Changing the servo also didn't help anything.
I looked very careful at the link between the servo horn and the steering rack, but this does not change lenght at all. (I measured it, and checked it several times)
So my own thought goes to the floating servo mount. I think that it moves a little when the car has a small impact. I have tried to tighten the 2 screws in the chassie, but It seems that I can't get the so tight, so the servo mount is completly fixed.
On my previus Xray, there was a smalle guiding pin located in between the 2 fixing screws, just to hold it in place, but on the EVO700, there is only the 2 screws.
Does any has some other idears, or has anyone had the same issue with the floating servo mount.
Thanks in advance.
Shock Tower is offline   Reply With Quote
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 Yesterday 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
