Old 01-09-2015, 05:18 PM   #7771
Much appreciated!
damo is offline   Reply With Quote
Old 01-09-2015, 06:52 PM   #7772
hanulec's Avatar
Trader Rating: 23 (100%+)
JD - you should use the ST24 on the steering block...
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 01-10-2015, 03:40 AM   #7773
John Doucakis's Avatar
Here are two galleries with Awesomatix A700 - Evo - Evo II parts & options.
Soon all these photos will be named and included in the Awesomatix website.
Anyone feel free to use them. They are available for everyone's convenience.
Album 1
Album 2
John Doucakis is offline   Reply With Quote
Old 01-10-2015, 06:39 AM   #7774
hanulec's Avatar
Very nice John. Perfect timing...
Old 01-10-2015, 11:29 AM   #7775
Is the first picture in album 1 the new carbon chassis? Is the new carbon chassis as narrow as the new aluminum chassis?
malkiy is offline   Reply With Quote
Old 01-10-2015, 11:42 AM   #7776
Yes it's a new carbon chassis and it is of the same dimensions as the aluminum one.
79.5 mm wide
2.5 mm thick
John
Old 01-10-2015, 04:34 PM   #7777
and so I did.
Blog updated. I will follow the latest set up submitted to me by Oleg as a standard for carpet with short upper links.
Old 01-11-2015, 03:49 AM   #7778
Dan
Dan's Avatar
Trader Rating: 40 (100%+)
When will Awesomatix USA get some more P13 ball connectors in stock?
Dan is offline   Reply With Quote
Old 01-11-2015, 06:12 AM   #7779
hanulec's Avatar
Awesomatix isn't stocking the P13 anymore in favor of the new P13-4. The P13-4 are really good once-
#1 you pre-thread the ends (i just used a normal screw, even of the left threaded sides)
#2 you grease the tie-rods (white or black grease works.. i've also heard people use chap stick)
If you want the P13 you'll have to buy them from Kyosoho-
Kyosho (#UM112H) 4.8mm Ball End (Hard /Gunmetal) [UM112H]
Old 01-11-2015, 11:10 AM   #7780
Location: El Pueblo de Nuestra Señora La Reina de Los Ángeles del Río de Porciúncula
Trader Rating: 29 (100%+)
I thought I read this was a Russian made car, so I'm wondering if they are better priced now with the tumbling ruble? I'd have to buy direct from Russia I'd think.
lagcisco is offline   Reply With Quote
Old 01-11-2015, 12:25 PM   #7781
Dan
Dan's Avatar
The P13-4 is what I meant. I had saw them in stock not too long ago but when I went to place my order, they were all out. Going to place a 2nd order sometime soon, but would like to know when they are expected to come in. Thanks!
Old 01-11-2015, 01:46 PM   #7782
ZeroDown7169's Avatar
Trader Rating: 53 (100%+)
I juzt picked up a 700ex. And i cant get the diffs to seal on the out drives. I took the apart and the oring is pretty danm hard, is there another oring or xseal out there that will work on there to get these things to seal?
ZeroDown7169 is offline   Reply With Quote
Old 01-11-2015, 02:49 PM   #7783
geeunit1014's Avatar
Someone asked before. The price is based on the euro, not the ruble. Oleg is russian, but the parts are made in europe, england of im not mistaken
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 01-11-2015, 03:31 PM   #7784
Default Need a little help.
I just came from the track and all is good. I have a LITTLE off power a$$ loose. I am trying to work with adjusting the droop so it will transfer less weight to the front of the car but if anyone has a suggestion please let me know. THANKS
TWILL is offline   Reply With Quote
Old 01-11-2015, 04:27 PM   #7785
AwesomatixUSA's Avatar
P13-4 are on order, but haven't shipped. ApexRC in Hawaii cleaned us out..
Get the OR05S -- they are softer. Use a lot of green slime.
other things that help-
stiffer front springs (smaller B #)
softer rear springs (larger B #)
less negative front camber
more front dampening (larger A #)
less rear dampening (smaller A #)
less rear droop
Official North American Distributor of Awesomatix, Wild Turbo Fan & Mon-Tech Racing
shop.awesomatixusa.com / www.awesomatixusa.com
#winning - 6x ROAR Nationals, 2x Reedy Race, 2x Snowbirds, 1x IIC, 5x Halloween Classic, 4x US Indoor Champs, 2x Mile High Champs
AwesomatixUSA is offline   Reply With Quote
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10911 11-28-2016 07:09 AM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
