Old 01-05-2015, 10:43 AM   #7726
Stogie's Avatar
Originally Posted by hanulec View Post
i'll be putting together one of my Evo kits for USVTA at Snowbirds later this month...
The use of an EVO in USVTA kinda seems contrary to the spirit of that class... but hey, why not... anything goes these days.
Now, on the other hand - a mod-caliber driver such as yourself running USVTA... that's just a shame!
☆☆☆ Chad Stowe ☆ ready to run some Mod TC again, finally ☆☆☆
Stogie is offline   Reply With Quote
Old 01-05-2015, 06:20 PM   #7727
hanulec's Avatar
Trader Rating: 23 (100%+)
Mod caliber... Lol
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 01-05-2015, 06:29 PM   #7728
Xpress's Avatar
Mike do you have any build tips for the new dampers?
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 01-05-2015, 08:39 PM   #7729
hanulec's Avatar
goto http://www.awesomatixusa.com/p/parts.html
click on Rebuildable Damper Set
http://www.awesomatixusa.com/p/rebuildable-damper.html
Old 01-05-2015, 08:44 PM   #7730
bkspeedo's Avatar
Here's instructions on the new D2 damper build Mike put together.
Tips for building
1. Instead of 3 .1mm spacers on the top of the B85 bearing, place 1 .1mm on top of the O ring OR15 and 1 .1mm shim on top of the B85 bearing. This will insure the bearing will turn without binding on the o-ring and apply even pressure on the o-ring which should provide a better seal.
2. You must sand the end (all sides) of SPR02 that inserts into the slot of AT41 as the tolerance is very tight and it won't assembly very easily.
So far I think 350, 425, 500, 575 CST have been tested. I personally feel 500 cst has the closest feel to original friction disk dampers.
I'm running 575 in Mod and like the feel with a F/R 3/2mm damper setting . My son Kyle was running 13.5 this past weekend, he started with 475 but felt the car was loosing some mid corner steering and felt lazy. He tried various dampening settings nothing brought it back to where it was with the original dampers. So he went to 350 and the same damper settings he's been running F/R 3/1 and the car was back to how he liked the feel and the lap times showed it.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 01-05-2015, 08:57 PM   #7731
Xpress's Avatar
Tips for building
I gather from Kyle going down to 375 that either the dampers he had been running had gone soft or the initial thought that the DL/R6 dampers were fillled with 500 is not correct?
-Espo
Old 01-05-2015, 09:24 PM   #7732
bkspeedo's Avatar
Your first guess is more accurate. The dampers in his car had gone soft so his setup worked better with lighter oil.
Brent Klingforth
Old 01-05-2015, 09:41 PM   #7733
hanulec's Avatar
Larry Fairtrace and I tried a few setups this weekend. From the dampener perspective an "A" gap of 2.0 seemed to work well. "B" gaps varied from 0 to 1.
I ran Evo II "kit" dampers. Larry ran D2 dampers with Associated 40WT (500cst)
Old 01-06-2015, 03:48 AM   #7734
The latest proven setups from our EU team drivers are here.
Max Machler was fast ( 2-nd place against very fast German drivers) during latest MCSS Open 2015 race in Germany with his setup.
The base carpet setup has been tested by Viljami Kutvonen in Finland.
It was very good and easy to drive according to Viljami report.
Oleg Babich is online now   Reply With Quote
Old 01-06-2015, 06:41 AM   #7735
Default Xtra bearings?
Mike I built both cars and have the 84 pkg. with two bearings left over in both kits. Did I miss something while building these cars?
TWILL is offline   Reply With Quote
Old 01-06-2015, 07:16 AM   #7736
hanulec's Avatar
probably not. those kits were Evo to L 'tear downs' to give you the kit you wanted, based upon what was available........
Old 01-06-2015, 10:55 AM   #7737
G-rem's Avatar
G-rem is offline   Reply With Quote
Old 01-06-2015, 02:12 PM   #7738
kerry's Avatar
when the new instructions are available, can someone please posk a link for download
kerry is offline   Reply With Quote
Old 01-06-2015, 06:38 PM   #7739
SLOWINSLOWOUT's Avatar
Trader Rating: 16 (100%+)
we will see. now at least i understand why the "A" gap is truly limited. my suspension is super light with the DR6 / DL6 for high grip carpet--
Front A=4; B=4.2 == 49.1
Rear A=4.2; B=3.0 == 55.6
i'm going to start at--
Front A=2; B=6.7 == 49.2
Rear A=2.4; B=5.8 == 55.4
i'll run my 17.5 stock car back to back w/ this new Evo II kit for the first time on Saturday. same motor type (Team Powers), battery (Aero Model 7600 90c), ESC (LRP Flow) to attempt to isolate some of the changes. i want to put A700-D2 into my 17.5 car later in the day.
i'll be building A700-D2 with Associated 80wt (1000 cst) tomorrow.
I am going to run the DR/L6 dampers on the new chassis. Was looking for a bit of help on trying to emulate the same feel as what I am currently running, car is working very well using Josh's set-up with a few changes.
My current damper/spring setting are;
Front A-5.0 B-6.0 = 64.7gf/mm
Rear A-5.4 B-5.6 = 69.1gf/mm
(car is working well, I like the way it feels, however, I do think it is on the edge of traction rolling-if I clip a dot, it rolls easily.)
_____________________________________
Earl Towson
KRC WCICS.ca club rep. http://www.krcracing.ca
SLOWINSLOWOUT is offline   Reply With Quote
Old 01-07-2015, 01:57 AM   #7740
Tof
Hello,
On the new lower deck C01AL-S2 the C04 and P12 rub it between.
Should we cut the plastic part P12?
Tof is offline   Reply With Quote
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
