Old 01-04-2015, 05:50 AM   #7711
Originally Posted by hanulec View Post
shock tower (funny name for an amtx driver..) - i'll let you know tonight. haven't built up some all "fresh" new tie rods in a LONG time.
Got the nick name from when I started RC with an Traxxas E-max and thiught it was a proff buggy, and therefore broke several of shock towers....
Shock Tower is offline   Reply With Quote
Old 01-04-2015, 08:33 AM   #7712
imprsme's Avatar
Trader Rating: 70 (99%+)
Originally Posted by Xpress View Post
My gd2 leaks out of only one side? I'm not sure if it's thru the seal or the setscrew? I pulled the diff apart and put a wrench thru the output shaft so I could crank the setscrew. I'll know shortly if that fixed the leakage....
Please post if you find a fix. Mine leaks out the right side out drive only. I have tried all I know to stop it and nothing's has done so,so far
AwesomatixUSA
eXpress Motorsports
imprsme is offline   Reply With Quote
Old 01-04-2015, 10:20 AM   #7713
cmunro's Avatar
Mine is the right side as well
REFLEX RACING/TRINITY/HOBBYWING/AIRTRONICS
cmunro is offline   Reply With Quote
Old 01-04-2015, 10:42 AM   #7714
daktulos's Avatar
I blow a GD2 outdrive oring lately on one side in a big race and my theory is that the oring was scratched by the carpet fiber... The carpet was new and the fiber get around all the rotating parts.
I try a few things even try chemically because I didn't have any spare.
Once I replaced the oring (OR05S) + green slime everything come back to normal. If you don't like to use green slime at least lubricate the oring when you assemble the diff.
Also take great care when filling the diff to let escape some excess oil with the set screw.
Your mileage may vary.
daktulos is offline   Reply With Quote
Old 01-04-2015, 12:45 PM   #7715
Default WOW!!!!!!
I just took two brand new A700l cars to The Gate (carpet track) for the first time. I run USGT and VTA. I used setups from off line and both cars were drivable right out of the box. I'm sure that I need setup help! There are really no setup sheets for this chassis and these classes. If anyone has a setup for this chassis in these classes please PM me. thanks a lot
TWILL is offline   Reply With Quote
Old 01-04-2015, 02:47 PM   #7716
hanulec's Avatar
Trader Rating: 23 (100%+)
Twill - most 17.5 tc setups work well in these two classes. You can get away with higher roll centers and longer links with less fear of grip roll.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 01-04-2015, 02:50 PM   #7717
I had to thread lock the grub screw in the diff out drives to stop mine leaking.
Gtr r34 m-spec is offline   Reply With Quote
Old 01-04-2015, 03:30 PM   #7718
cmunro's Avatar
I will try that ,thanks
Old 01-04-2015, 03:36 PM   #7719
imprsme's Avatar
Thanks. I will try that also. Cars getting a complete rebuild tonight/tomorrow anyway.
AwesomatixUSA
eXpress Motorsports
Old 01-04-2015, 05:54 PM   #7720
DS Motorsport's Avatar
Would like to let you guys know that I'm selling my Awesomatix A700 Evo
I'm pretty sure this is the only one in the world which has been converted to be 200mm wide.
I bought the car to reverse engineer it and see if it was a viable option to use the suspension for a 200mm nitro car.
It has been run for 3 days of practice.
Comes with quite a few parts, new carbon chassis etc.
Next coming days I will rebuild it, clean it and make a proper sale ad.
If someone is already interested please contact me.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 01-04-2015, 07:03 PM   #7721
Default Thanks.
I have a 17.5 setup on the cars right now and will just work on making adjustments until I am comfortable with them. Thanks for the help THE CAR IS GREAT!!!!!
Old 01-04-2015, 07:58 PM   #7722
hanulec's Avatar
if you can explain what you'd like the car to do better -- along w/ posting the setup Tony we will be able to help you.
i'll be putting together one of my Evo kits for USVTA at Snowbirds later this month...
Old 01-05-2015, 05:36 AM   #7723
Default I may have built the suspention Wrong?
When building the shocks the instructions (step 9 finished) shows two lefts and two rights. The problem is if I build it like that I have to criss cross the shocks to get them in the car. Is this wrong because I have a L6 on the front right side of the car and R6 on the left hand side???? Are the instructions wrong or am I and will just swapping the dampers fix this ? Other than that I think just working with the droop and spring rate will get the car to where I want it to be...Thanks for the help.
Old 01-05-2015, 06:45 AM   #7724
geeunit1014's Avatar
No, it is correct. It is like that so that if you want to run asymmetric damping, the dampers will all have the soft stroke for compression.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 01-05-2015, 07:21 AM   #7725
Hi all
Im new to this forum and have pre ordered the new A700 Evo IIC. Until now i drive conventional TC.
Never seen the car live but im very interested to setup this car fo an indoor asphalt track with foam tire.
To have a basic setup can anyone help me to setup the car basically for foam tire? The track are very tight and technical. Only a few corner like 180 degrees and one long corner. The driving is like full brake and full power so i need good initial steering and a planted rear to bring the power to the straight.
I planned to use the basic setup but if anyone have recommendations for foam tire and very tight track it would be help to start with this new journey.
Thank you for your support
Rgds Dani
cdani is offline   Reply With Quote
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
SEO by vBSEO 3.5.0
