Old 11-02-2011, 01:08 PM   #751
Trader Rating: 19 (100%+)
THE BUILD
First off - It has been a while since I picked up a kit to build that continued to impress to the last settings.
Just wanted to provide some notes:
Step 1 - Page 4: be sure to watch SB3X5 on the top hub (outside) through the graphite. Easy to use the wrong hardware here.
Step 2 - Page 5: Install the ST11 Bushings from the start instead of the clips
Step 4 - Page 7: The P16 Lock Rings are actually clear/white plastic. Easy to look over these when you are building. Might be good to have the manual call out the color of the rings. I was looking for something metal like a c-clip
Step 6 - Page 9: The P06 did not work for me at all. I understand that they might work for others but 2 out of the 4 would not grab into the graphite with CA. End up using a T-nut that worked well.
Step 9 - Page 11: SPR01 - would be nice if there was a deeper anchor point on damper mount or some set screw. Mild issues later keeping the unit aligned during assembly.
Step 22 - Page 16: SB3X5 - dont forget about this screw. Speaking from experience.
Step 25 - Page 18: The manual calls out the trimming of the 'plastic cross' - be sure to trim a little at a time. I can see folks taking off too much material
Step 47 - Page 26: When assembling the rear body mount (AT22) - be sure the the pass-through screw is going through the untapped side first, then the threaded side. Otherwise, it might feel like the unit is not clamping the body post.
Shock Setting Technique - would be helpful to understand the effect that moving the Damper in-board or out-board has an effect on 'feel'. Would be good to get an idea how to measure the damper position for consistency.
IMPRESSIVE:
- The dampers are an incredibly simple idea and love that all of that weight is now low in the chassis
- Steering rack - screams high-quality.
- Spool - mechanical art. Like the steering rack - this is great work. Hope AWESOMATIX keeps up this quality.
- Gear Diff!
- Symmetric and Asymmetric Damper modes - nice touch. Could spend hours on this.
GOOD TO HAVE:
- Decent car-setup board and tools. The intricacy of the rod suspension really needs good use of set-board/gauges/calipers.
Looking forward to the first track passes.
MDawson is offline   Reply With Quote
Old 11-02-2011, 02:13 PM   #752
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Originally Posted by MDawson View Post
THE BUILD
IMPRESSIVE:
- Gear Diff!
GOOD TO HAVE:
You bringing this piece to Horsham on sat?
Cant wait to take a look at her and maybe even take er for a spin.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 11-02-2011, 02:33 PM   #753
You got it. Will have to be next Saturday though. At the mini race this weekend.
Old 11-02-2011, 02:47 PM   #754
THE BUILD
IMPRESSIVE:
- Gear Diff!
GOOD TO HAVE:
In full trim - 1388 grams
  • A700Long - steel screws, gear diff, spool
  • RadioPost Servo/Receiver
  • Protoform LTR Body - regular weight
  • 17.5 / ESC
  • 6500 Lipo
No diet needed
Old 11-03-2011, 02:45 AM   #755
Velocitygt's Avatar
Anyone looking for a quick easy way to check caster on this car, here it is. The way the manual describes works great although can take some time.
Awesomatix EP Touring Car-2011-11-03-14.35.28.jpg   Awesomatix EP Touring Car-2011-11-03-14.39.41.jpg
Velocitygt is offline   Reply With Quote
Old 11-03-2011, 03:42 AM   #756
Tbone13's Avatar
@velocity
looks great a quick fix like that ...
but first you have to determinate the highest point to have your 0degrees mark? cause when you move up or down your downstops this point will change ?
after that you can read on your scala the degrees ?
have you done this by yourself?
I don't have the car for a long time and used the caliber to adjust it ...
2.7mmdifference for 4degrees but normaly run 3mm difference so 4.5 degrees
kind regards Tom
supported by and thanks to:
Modelconcept / Absima Racing / TeamC / Hacker Brushless motors / Awesomatix
Tbone13 is offline   Reply With Quote
Old 11-03-2011, 07:58 AM   #757
OVA
OVA's Avatar
Trader Rating: 72 (100%+)
Originally Posted by Tbone13 View Post
@velocity
kind regards Tom
I don't think the degrees will change .as long the travel is 90deg. straight up and down ..you also have to move the protractor back away ,if you don't it will change the deg. reading and the protractor will not indexes flat c/t caster top block..
OVA is offline   Reply With Quote
Old 11-04-2011, 05:41 PM   #758
Trader Rating: 26 (100%+)
Is there a performance difference in using bushing r ,bushing s or a c drive
eddie10 is offline   Reply With Quote
Old 11-04-2011, 09:02 PM   #759
Anybody built their A700 with ceramic bearings yet ???
bertrandsv87 is online now   Reply With Quote
Old 11-04-2011, 11:47 PM   #760
Post #508
vlad_vy is offline   Reply With Quote
Old 11-05-2011, 10:26 AM   #761
Anybody in the UK order yet? And if so how long did the delivery take from confirmation of payment?
Cheers
MarkMcC is offline   Reply With Quote
Old 11-05-2011, 01:09 PM   #762
erchn's Avatar
Price increase? Did the kit change, or did the US dollar just get worse?
erchn is offline   Reply With Quote
Old 11-05-2011, 03:36 PM   #763
The Euro's pretty weak at the moment. Looks like the price is fixed at EU589 and the USD price is changing accordingly.
Old 11-05-2011, 06:27 PM   #764
KHoff7's Avatar
Saw Mark Dawson's car today. WOW this thing is beyond impressive, just wow.
Awesomatix USA / Middle River Hobbies / Sweep / Psycho Cells Racing
Karl Hoffmeister
KHoff7 is offline   Reply With Quote
Old 11-05-2011, 09:22 PM   #765
*fixed*. will hit some hot laps tomorrow.
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17195 01-10-2017 05:04 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
