Old 12-20-2014, 09:31 AM   #7606
RC Professor's Avatar
I realize not many have run the new dampers, but are there any initial impressions on both variables of oil thickness and damper position on the car used at the same time? In other words, is it more likely that as testing goes on, the dampers will find a sweet spot location where all you do is play with oil and keep the dampers in one fixed spot? Or play with oil while at the same time trying different damper locations?
Should be interesting to see what surfaces either way.
RC Professor is offline   Reply With Quote
Old 12-21-2014, 04:47 AM   #7607
Trader Rating: 54 (100%+)
Unfortunately this is keeping me from preorder. I like the old dampers just fine. The car is a rocket in stock. I'm assuming the new car will be better in mod form. Looks like the old evo and I will patiently await results of the new car. Any word if it will be here in time for snowbirds?
Jamison R is offline   Reply With Quote
Old 12-21-2014, 08:53 AM   #7608
hanulec's Avatar
Trader Rating: 23 (100%+)
Come on Jaimson - where is your sense of adventure? We will figure it out... Just like we did with the A700EX/L series...
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-21-2014, 11:31 AM   #7609
Xpress's Avatar
When are the new chassis due to ship?
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 12-21-2014, 12:31 PM   #7610
Moderator
Clegg's Avatar
One of the perks of the amtx overall was not dealing with oil changes in the dampers. While I dig this tuning option, I would think you would still use the damper position for most of your adjustments and just use the oil changes as bigger overall changes.
It looks like these new dampers are only symmetric in their dampening. Does no one really use the asymetric dampening of the current dampers?
Also is there any ideas on a kind of damper dyno or tester to evaluate the consistency between the 4 corners?
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 12-21-2014, 01:21 PM   #7611
hanulec's Avatar
I agree Joe.
Difference between the four corners is one of the major things to be on the look out for today. And today the only fix is a new $25 shock. The new shocks allow for end user fixing. That has to be a plus.
Trust me -- the last thing I have time to do is rebuild shocks. Every setup I will come up with won't involve massive maintenance like that... Just for my own success and mental well being.
Oleg has discussed was various measurement tool ideas... And will make one in 2015. Just need to get the car shipping first!
Old 12-21-2014, 03:37 PM   #7612
JayL's Avatar
What is the best FFG rod for 17.5? mine has a crack
I run ffg1.1 on a raceberry chassis, usually run the may 24/2014 Jackson setup, dialed on my track
Just installed AT04-2 and 2 am50 instead of am48
Just get a new c31?
A800 HW XR10Pro HW G2 4.5T|||B5MFL HW StockSpec Team Powers 17.5|||VTA: Awesomatix EVO 1.1 Orca VX3 |||F1:
Xray X1 2016, HW V3.1, Ride XR Tires, D4SS 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 12-21-2014, 06:47 PM   #7613
hanulec's Avatar
c31 (if you can still find em) or the at31 (late '14 Evo spec) FFG rod...
Old 12-21-2014, 07:00 PM   #7614
ThrottleKing's Avatar
Trader Rating: 16 (100%+)
I have a question on a couple of the carbon rods I have. Both of them are the same OD but they are different ID. The larger ID/thinner wall carbon rod seems to be firmer than the smaller ID/thicker wall carbon rod. Well when I tugged at each end they seemed that way. I don't know which one is which and I was hoping someone could help me out.
Acts 2:21- And it shall come to pass, that whosoever shall call on the name of the Lord shall be saved.
ThrottleKing is offline   Reply With Quote
Old 12-21-2014, 07:07 PM   #7615
hanulec's Avatar
the first few dozen Evo kits had the C31S "soft" rod. ive never measured the difference between C31S and C31.... so i cannot say which one is which.
the more flexible rod should be limited to stock racing.
Old 12-22-2014, 08:19 AM   #7616
SLOWINSLOWOUT's Avatar
Any thought on putting together an upgrade kit for existing cars to the new spec.?
_____________________________________
Earl Towson
KRC WCICS.ca club rep. http://www.krcracing.ca
SLOWINSLOWOUT is offline   Reply With Quote
Old 12-22-2014, 11:53 AM   #7617
daktulos's Avatar
Hi, I receive the new chassis and floating motor mount this weekend and just want to share some pictures...
Everything go smoothly the only one thing that need to take care is to check that the screw is not protruding in the AM73-3.
To be certain everything is straight only fully tighten the accessible screws once everything is on the chassis. Just the AM73-3 and AM73-4 need to be tighten prior.
I use the DT03 bearing spacer in the "no flex" position.
Don't take my assembly as granted we will need the confirmation that everything is OK especially shimming and flex options.
By the way the set screw for the motor adjustment is very clever.
daktulos is offline   Reply With Quote
Old 12-22-2014, 12:31 PM   #7618
Like the floating,sliding motor mount
Old 12-23-2014, 01:36 AM   #7619
G-rem's Avatar
D2-S have only just been released that new parts are coming...
So, the difference between AT41 damper vane and new AT41-0 damper vane is there are no holes in the blades anymore for AT41-0.
But how does it influence the damper's behaviour in comparison to AT41 with holes in the blades? In which tracks conditions are they better suited than normal AT41?
Thanks in advance,
G-rem
G-rem is offline   Reply With Quote
Old 12-23-2014, 03:19 AM   #7620
Maybe it's just so you can drill your own holes?
-Mike
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
