Old 12-18-2014, 05:19 PM   #7591
haywood's Avatar
Trader Rating: 47 (100%+)
Default Evo 2
Originally Posted by AwesomatixUSA View Post
Fresh news from Oleg. 4 kits available in 2015. Here are all of the juicy details--
A700 Evo II - Updated, Alloy Chassis Version of the A700 Evo
Availability - ASAP
  1. Floating Front Gearbox - A700-FFG1.1
  2. New Motor Mount - A700-MM2 - instead of AM03-1
  3. Four new rebuildable dampers - A700-D2 - instead of DL6 and DR6
  4. New Alloy Chassis - A700-C01AL-S2
  5. Latest Alloy Chassis Brace and FFG Tower - A700-AM33-5 and A700-AM49-3
  6. Floating Servo Mount - A700-AM24 - now included instead of AM07L/R
  7. Latest Diff - A700-GD2-S - included instead of GD1
  8. Latest Spool - A700-AT03M-S - included instead of AT03
  9. Short Steering Link - A700-ST21S - included instead of ST21
  10. Standard height ball studs - A700-AT21 - included just for lower arm mounts
  11. New C04M carbon arms (much stronger material)
  12. New Ball Studs included for upper camber links and all steering linkages - A700-ST24 and A700-ST24L - instead of AT21
  13. Open ended ball cups - A700-P13-4 - included instead of P13
  14. Various screw count changes
A700 Evo IIC - Updated, Carbon Chassis Version of the A700 Evo
Parts list similar to Evo II, but swaps in a new carbon chassis and removes alloy braces
Availability - 2-3 weeks (awaiting new carbon chassis)
  4. New Carbon Chassis - A700-C01L2
  5. Floating Servo Mount - A700-AM24 - now included instead of AM07L/R
  6. Latest Diff - A700-GD2-S - included instead of GD1
  7. Latest Spool - A700-AT03M-S - included instead of AT03
  8. Short Steering Link - A700-ST21S - included instead of ST21
  9. Standard height ball studs - A700-AT21 - included just for lower arm mounts
  10. New C04M carbon arms (much stronger material)
  11. New Ball Studs included for upper camber links and all steering linkages - A700-ST24 and A700-ST24L - instead of AT21
  12. Open ended ball cups - A700-P13-4 - included instead of P13
  13. Various screw count changes
A700L2 - Updated, Carbon Chassis Version of the A700L
Parts list similar to Evo IIC, but without FFG
  1. New Motor Mount - A700-MM2 - instead of AM03-1
  2. Four new rebuildable dampers - A700-D2 - instead of DL6 and DR6
  3. New Carbon Chassis - A700-C01L2
  4. Floating Servo Mount - A700-AM24 - now included instead of AM07L/R
  5. Latest Diff - A700-GD2-S - included instead of GD1
  6. Latest Spool - A700-AT03M-S - included instead of AT03
  7. Short Steering Link - A700-ST21S - included instead of ST21
  8. Standard height ball studs - A700-AT21 - included just for lower arm mounts
  9. New C04M carbon arms (much stronger material)
  10. New Ball Studs included for upper camber links and all steering linkages - A700-ST24 and A700-ST24L - instead of AT21
  11. Open ended ball cups - A700-P13-4 - included instead of P13
  12. Various screw count changes
A700EX2 - Updated, Carbon Chassis Version of the A700EX
Parts list similar to A700EX, but with updated motor mount. Supports transverse and longitudinal motor layouts
Availability - ASAP
  1. Existing Transverse Motor Mounting system
  4. Existing Carbon Chassis - A700-C01EX
  5. Floating Servo Mount - A700-AM24 (was always standard on A700EX)
A700-C01L2 Chassis
* 2.5mm carbon
* Will additionally support the mounting of shorty lipo batteries
/ Roche Rapida 2015-2016 / Hobbywing / Team Scream / Rc Painting By Mikey / Ko Propo / MMR / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 12-18-2014, 05:19 PM   #7592
hanulec's Avatar
Trader Rating: 23 (100%+)
Originally Posted by geeunit1014 View Post
Upgrades
1. Lunsford turbuckles
2. Better front bumper, bsr or xray hard
3. Am19 for rear/short links
Spares, one of everything from the awesomatix usa suspension spares bundle
i like lowered arm balls - at21s - too!
if folks have suggestions on better ways to share this info please speak up. the racerlog wiki pg is close, but not perfect. the AwesomatixUSA parts bundles try to help folks decide things too.
for 2015 i think the parts at AwesomatixUSA will get "categorized" by a given car model "standard parts" and "optional parts". the existing Awesomatix site lumps a lot of the new stuff under "optional parts".
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-18-2014, 10:13 PM   #7593
Talking
Originally Posted by haywood View Post
That's gold!!
Gtr r34 m-spec is offline   Reply With Quote
Old 12-19-2014, 08:24 AM   #7594
cmunro's Avatar
why the titanium turnbuckles? do you recomend a top deck for the evo on carpet ?
REFLEX RACING/TRINITY/HOBBYWING/AIRTRONICS
cmunro is offline   Reply With Quote
Old 12-19-2014, 11:23 AM   #7595
Stogie's Avatar
Aluminum tends to bend a little more on impact vs. titanium.
Unless it's a fresh layout and traction is extremely low, I always run a topdeck on my Evo... but I'm still running a carbon chassis. Those running aluminum chassis may beg to differ.
☆☆☆ Chad Stowe ☆ ready to run some Mod TC again, finally ☆☆☆
Stogie is offline   Reply With Quote
Old 12-19-2014, 11:36 AM   #7596
hanulec's Avatar
Top deck helps improve corner speed -- carbon or alloy chassis
Old 12-19-2014, 02:13 PM   #7597
Moderator
Clegg's Avatar
Are there any pictures of the new dampers?
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 12-19-2014, 03:56 PM   #7598
There are no detailed pictures yet, but the link below has the images from round 1 ETS. You really can not tell much, but the screws on the back of the dampers are gone.
http://ets.redrc.net/2014/12/chassis...mi-kutvonen-2/
Patrick
XCELL is offline   Reply With Quote
Old 12-19-2014, 06:21 PM   #7599
hanulec's Avatar
An assembly diagram, and initial build information for the A700-D2-S can be found here-
http://www.awesomatixusa.com/p/rebuildable-damper.html
Old 12-19-2014, 07:19 PM   #7600
Mike,
Thanks for the diagram, it will be interesting to see what the consensus among racers will be on silicone oil weights and SPR01/SPR01S springs for carpet/asphalt.
Patrick
Old 12-19-2014, 07:29 PM   #7601
hanulec's Avatar
Originally Posted by XCELL View Post
Mike,
Patrick
This is the big question. Hope we can all try soon....
Old 12-20-2014, 12:51 AM   #7602
500 with hard spring.
Team Awesomatix - WTF - Thunder Power - Mikovic Body Painting - ToniSport - PRT Electronics
Manu_05' is offline   Reply With Quote
Old 12-20-2014, 04:57 AM   #7603
hanulec's Avatar
But in what class...
We've tried some very different settings with the existing dampers and found some cool results. I was never able to get the spr01 to work.
I'd describe my current stock tc settings has having more pack/dampening (big A gaps) and very light spring (type 2 spr01s with big B gaps).
Old 12-20-2014, 07:47 AM   #7604
Mike,
Patrick
We will use 500 cst oil in the car kit's dampers.
This is a good initial point to keep A-size settings within 0..3,5mm range at most conditions. It corresponds to ~350...500 cst oil range for traditional TC shocks.
Full 0...7mm range for A-size settings of our dampers (with 500 oil inside) corresponds to ~350...650 cst oil of traditional TC shocks.
Oleg Babich is offline   Reply With Quote
Old 12-20-2014, 08:03 AM   #7605
Stock and modified class.
Hard spring are always faster than the soft (more cornerspeed)
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17189 Yesterday 03:25 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
gavaust
SEO by vBSEO 3.5.0
