Old 12-16-2014, 08:17 AM   #7576
daktulos's Avatar
Just go see the new kits at the Awesomatix USA website!
Does the two new kits come with the GD2, ST24 and P13-4?
To be more vague "The version 2 gear diff, newer ball stud and newer open ball end?"
daktulos is offline   Reply With Quote
Old 12-16-2014, 04:46 PM   #7577
hanulec's Avatar
Trader Rating: 23 (100%+)
Evo v1 kits had gd2 and p13-4 towards the end of the year. St24. TBD. Only Oleg knows right now.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-16-2014, 05:45 PM   #7578
Does the collapse of the Russian currency mean the price of this fabulous car may go down?
croz is offline   Reply With Quote
Old 12-16-2014, 05:47 PM   #7579
geeunit1014's Avatar
I believe the price of the car is set by the price of the euro
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 12-16-2014, 11:04 PM   #7580
A700 Evo II and A700L2 will be with P13-4, GD2 diff, AT03M-S spool and ST24/ST24L ball studs for top links and steering links.
Evo II with alloy chassis also includes AM33-5 Long Stiffener and AM49-3 Short FFG Tower.
Oleg Babich is online now   Reply With Quote
Old 12-17-2014, 03:35 AM   #7581
hanulec's Avatar
I assume once Oleg has a minute to breath/sleep more info will come out
Carbon version of Evo II, the Evo IIC, was posted today too. Once more details are out they will be shared...
Old 12-17-2014, 05:15 AM   #7582
AwesomatixUSA's Avatar
Default 2015 Kit Details
Fresh news from Oleg. 4 kits available in 2015. Here are all of the juicy details--
A700 Evo II - Updated, Alloy Chassis Version of the A700 Evo
Availability - ASAP
  1. Floating Front Gearbox - A700-FFG1.1
  2. New Motor Mount - A700-MM2 - instead of AM03-1
  3. Four new rebuildable dampers - A700-D2 - instead of DL6 and DR6
  4. New Alloy Chassis - A700-C01AL-S2
  5. Latest Alloy Chassis Brace and FFG Tower - A700-AM33-5 and A700-AM49-3
  6. Floating Servo Mount - A700-AM24 - now included instead of AM07L/R
  7. Latest Diff - A700-GD2-S - included instead of GD1
  8. Latest Spool - A700-AT03M-S - included instead of AT03
  9. Short Steering Link - A700-ST21S - included instead of ST21
  10. Standard height ball studs - A700-AT21 - included just for lower arm mounts
  11. New C04M carbon arms (much stronger material)
  12. New Ball Studs included for upper camber links and all steering linkages - A700-ST24 and A700-ST24L - instead of AT21
  13. Open ended ball cups - A700-P13-4 - included instead of P13
  14. Various screw count changes
A700 Evo IIC - Updated, Carbon Chassis Version of the A700 Evo
Parts list similar to Evo II, but swaps in a new carbon chassis and removes alloy braces
Availability - 2-3 weeks (awaiting new carbon chassis)
  4. New Carbon Chassis - A700-C01L2
  5. Floating Servo Mount - A700-AM24 - now included instead of AM07L/R
  6. Latest Diff - A700-GD2-S - included instead of GD1
  7. Latest Spool - A700-AT03M-S - included instead of AT03
  8. Short Steering Link - A700-ST21S - included instead of ST21
  9. Standard height ball studs - A700-AT21 - included just for lower arm mounts
  10. New C04M carbon arms (much stronger material)
  11. New Ball Studs included for upper camber links and all steering linkages - A700-ST24 and A700-ST24L - instead of AT21
  12. Open ended ball cups - A700-P13-4 - included instead of P13
  13. Various screw count changes
A700L2 - Updated, Carbon Chassis Version of the A700L
Parts list similar to Evo IIC, but without FFG
  1. New Motor Mount - A700-MM2 - instead of AM03-1
  2. Four new rebuildable dampers - A700-D2 - instead of DL6 and DR6
  3. New Carbon Chassis - A700-C01L2
  4. Floating Servo Mount - A700-AM24 - now included instead of AM07L/R
  5. Latest Diff - A700-GD2-S - included instead of GD1
  6. Latest Spool - A700-AT03M-S - included instead of AT03
  7. Short Steering Link - A700-ST21S - included instead of ST21
  8. Standard height ball studs - A700-AT21 - included just for lower arm mounts
  9. New C04M carbon arms (much stronger material)
  10. New Ball Studs included for upper camber links and all steering linkages - A700-ST24 and A700-ST24L - instead of AT21
  11. Open ended ball cups - A700-P13-4 - included instead of P13
  12. Various screw count changes
A700EX2 - Updated, Carbon Chassis Version of the A700EX
Parts list similar to A700EX, but with updated motor mount. Supports transverse and longitudinal motor layouts
Availability - ASAP
  1. Existing Transverse Motor Mounting system
  4. Existing Carbon Chassis - A700-C01EX
  5. Floating Servo Mount - A700-AM24 (was always standard on A700EX)
A700-C01L2 Chassis
* 2.5mm carbon
* Will additionally support the mounting of shorty lipo batteries
Official North American Distributor of Awesomatix, Wild Turbo Fan & Mon-Tech Racing
shop.awesomatixusa.com / www.awesomatixusa.com
#winning - 6x ROAR Nationals, 2x Reedy Race, 2x Snowbirds, 1x IIC, 5x Halloween Classic, 4x US Indoor Champs, 2x Mile High Champs
Last edited by AwesomatixUSA; 12-17-2014 at 01:26 PM. Reason: carbon part number.. duh
AwesomatixUSA is offline   Reply With Quote
Old 12-17-2014, 08:28 AM   #7583
G-rem's Avatar
Oleg,
can we have if not the new manual for the Evo II, at least an exploded view of parts to know exactly what parts we need to convert our "old" Evo into Evo II as they are now available in store? (especially for floating motor mount and new damper)
Or maybe you can tell us which part number and qty we need?
Thanks in advance,
G-rem
G-rem is offline   Reply With Quote
Old 12-17-2014, 08:47 AM   #7584
Take a look on the awesomatixusa site. They list all the major parts needed for each upgrade.
New Dampeners
http://shop.awesomatixusa.com/upgrad...g24rb1lmairft3
New aluminum chassis
New flex motor mount
Originally Posted by G-rem View Post
Oleg,
Thanks in advance,
G-rem
malkiy is offline   Reply With Quote
Old 12-17-2014, 09:44 AM   #7585
G-rem's Avatar
Thanks dude, I did'nt see it
Question about SD2: do I still need to put P11 (gear tube) between the gear and SPR06?
Thanks,
G-rem
Old 12-17-2014, 10:45 AM   #7586
Thanks,
G-rem
I did not on mine, since the pin it covers up has been eliminated.
Mike Gee
Old 12-17-2014, 12:34 PM   #7587
G-rem's Avatar
Ok Mike, thank you very much
Old 12-17-2014, 06:23 PM   #7588
Thanks,
G-rem
There is no pin to pop out, therefore no need.
rcpinky is offline   Reply With Quote
Old 12-18-2014, 03:26 PM   #7589
cmunro's Avatar
hey guys just got a new evo ,what are the must have upgrades and spares ? i will be running 17.5 on carpet
REFLEX RACING/TRINITY/HOBBYWING/AIRTRONICS
cmunro is offline   Reply With Quote
Old 12-18-2014, 04:04 PM   #7590
Upgrades
1. Lunsford turbuckles
2. Better front bumper, bsr or xray hard
3. Am19 for rear/short links
Spares, one of everything from the awesomatix usa suspension spares bundle
Mike Gee
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
