Old 11-29-2014, 05:54 PM   #7471
geeunit1014's Avatar
Originally Posted by bornox View Post
is there a spring in the front? mine doesnt have one.
He means the spring clip on the front input gear
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 11-29-2014, 07:51 PM   #7472
SPR06, it is from step 14 in the manual. Is there not one on your car?
A700 17.5 Stock, USGT, CVTA, RCO Sportsman
WF D06 USVTA
trackout is offline   Reply With Quote
Old 11-30-2014, 07:48 AM   #7473
Ron Goetter's Avatar
Trader Rating: 17 (95%+)
Send a message via AIM to Ron Goetter
Mike Gee takes 17.5 TQ at the Indoor Champs
Great job Gee.
The Goat... B-Mainer Fo' life
-Awesomatix USA-ROCHE USA-Team CRC-ORCA-SIDE PIECE RACING-TEAM DAK-EA Motorsports-VP Fuel-Trains and Lanes-CR Graphics-TQ Wire-Horsham RC-rugburn anyone?
Shut up and Race!!!!
Ron Goetter is offline   Reply With Quote
Old 11-30-2014, 12:29 PM   #7474
I am new to this increadibel TC car, and I have a lot to learn. The spring/damper is compleatly new to me, so I a looking for some help on this issue. I have tried to search in this forum for it, but has not been able to find it. Has anyone made a easy to understand guide for beginners, because then I would like to read it and learn from it.
Thanks in advance.
Shock Tower is offline   Reply With Quote
Old 11-30-2014, 01:19 PM   #7475
elee32's Avatar
Trader Rating: 18 (100%+)
Thanks in advance.
This is from the awesomatix USA site. Lots of other useful information there
Sliding the damper changes the springs leverage on the damper, and the leverage of the spring rate/ride height screws on the spring. Sliding the damper out (more gap) is more damping and a stiffer spring rate simultaneously. Changing the screws (B) only changes the spring rate.
Sliding the damper out would be like putting on a stiffer spring, and putting in thicker shock oil at the same time. Sliding the screws would be changing just the spring. You can use a combination of these 2 to change just the "shock oil". Hope that helps.
Eric Lee, sponsored by shipping and handling..
elee32 is offline   Reply With Quote
Old 11-30-2014, 03:11 PM   #7476
hanulec's Avatar
Trader Rating: 23 (100%+)
Awesomatix drivers take 3 for 5 touring car classes at US Indoor Champs in Cleveland, Ohio. 3 TQ & Wins!!!!
Mike Gee - 17.5 TC + four other Awesomatix drivers; 5 Awesomatix cars in 17.5 A-main!
Bill Sydor - 13.5 TC
Manny Flores - USGT
In Mod TC Mike Gee and Josh Cyrul qualified 3rd and 4th and finished in the same order behind Andrew Hardman who won over Keven Hebert
Great job guys!
Awesomatix touring cars have TQ + Won every major 17.5 TC carpet race in 2014. Thank you to all of the racers who have gotten behind this revolutionary car. Big thanks to Oleg for making this magical feat of engineering excellence.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 12-01-2014, 05:51 AM   #7477
Thank you from the support I got from your drivers at the champs this year. Brian Wynn and Josh Cyrul were big help to me. I had gotten me car Wedsenday the day before the champs. Never setting up or understanding what to do on the car they both took time to help me. I stared the vta main in 9th and drove to a 4th place finish just behind 3rd. Can't wait to see what this year brings!
tangtester is offline   Reply With Quote
Old 12-01-2014, 05:55 AM   #7478
Hi all
I'm building a brand new A700L and have run into an issue with regards to the rear unis.
It looks like both universals are binding where ST-16 pivots on the ST-02 axle. When the 10x6 bearing is removed they unbind and move freely so it looks like a tolerance issue. Initially thought it was the PIN01 causing it but there is clearance between the pin and the inside of the axle.
Have I missed something during assembly?
Awesomatix A700L (building) | VBC Wildfire D07 (building) |416WE/X Smokem | Hobbywing 120A v2.1 | Sanwa M11x
itchynads is offline   Reply With Quote
Old 12-01-2014, 06:45 AM   #7479
Yup, the Awesomatix team are awesome at supporting racers at events. Any chance of seeing you USVTA setup sheet for the A700?
WF D06 USVTA
Old 12-01-2014, 07:54 AM   #7480
Trader Rating: 31 (100%+)
Originally Posted by itchynads View Post
Hi all
Yes what you need to do is squeeze the st02 so that the bearing and at13 are not a snug fit (not loose either). You want to squeeze on the front side of st02 (part that sticks out towards the wheel). What happens is that it gets spread to far apart when first assembling or just production variance.
Let me know if this helps.
Monti
Monti is offline   Reply With Quote
Old 12-01-2014, 11:07 AM   #7481
-jacob-'s Avatar
Looking for a deal on a Awesomatix brushless servo.
www.teameamotorsports.com
www.seattlercracers.com
-jacob- is offline   Reply With Quote
Old 12-01-2014, 01:23 PM   #7482
What a great weekend for Awesomatix at the US Indoor Champs. TQ + win in 21.5, 17.5, and 13.5, plus a podium finish in modified. Cant thank hanulec enough for doing what he does to let us race the car here, I know I wouldnt want to be without one
I really hope this weekend shows people the preconceived notions they may have about the car are wrong. This track was a combination of everything that people think hold the car back, super high grip (it will traction roll) and the bumpiest track I have ever seen in my life (not good on bumps). The car dominated spec classes, and I was only a few seconds behind the super canadian duo in mod in qualifying, which for me is a win as I have nowhere near the experience level of those guys in modified. I can't wait to see what the future holds for Awesomatix
Mike Gee
Old 12-01-2014, 01:37 PM   #7483
-jacob-'s Avatar
Congrats!... Happy to see the team continue to dominate
Old 12-01-2014, 01:53 PM   #7484
Moderator
Clegg's Avatar
Hey guys, I was trying to figure out the difference that needs to be factored into setups when going to the XRay balls and cups to replace the stock Awesomatix AT21 and P31s.
I saw the ST24 come in at .7mm shorter than the AT21 setup. Is that the same for the Xray bits? Reason I ask is I had enough extra Xray ball cups and balls to fit 2 cars with them, and want to know what tweak I need to give to the setups to get the right roll center. The Xray balls look very similar to the ST24, but it is hard to tell how they match up for height.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 12-01-2014, 02:57 PM   #7485
If I remember correctly the xray balls are closer to 1mm shorter. I have been telling guys at my track to add 1mm shims for xray balls and it seems to work out well
Mike Gee
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
