Old 11-12-2014, 11:05 AM   #7396
magee's Avatar
Thanks, I'll try the C/A glue. got the hard bumper.
magee is offline   Reply With Quote
Old 11-12-2014, 11:56 AM   #7397
Magnet Top's Avatar
The original P01 and P02 had issues popping off but Oleg made a "running change" keeping the original part number but making them significantly more crash resistant. It's been a long time since I had that part pop off. So make sure you have the newer style that have been available for well over a year now. They are very difficult to pop together during assembly and with some tires require some trimming to clear the rim if shimmed at 2.75mm on ST03. ( specifically sweep QTS true blue spec tires )
Jake D.
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 11-12-2014, 11:57 AM   #7398
Hi all,
I'm selling an A700 Evo
PM me for more details and pics
Claude
toroloco is offline   Reply With Quote
Old 11-12-2014, 07:52 PM   #7399
magee's Avatar
thanks very good info.
Old 11-12-2014, 09:44 PM   #7400
Wazza22's Avatar
Trader Rating: 21 (100%+)
You may find the revised P01 & P02 still pop off in a big hit. The best solution we have found is still to put a small amount of glue in the joint.
Cheers
Old Yokomo's Rule!!
Wazza22 is offline   Reply With Quote
Old 11-13-2014, 07:41 AM   #7401
Cheers
Sorry for asking, but i'm new to the EVO700. Is it a small drop of CA on the ball stud, ore inside the ball cup you are applying ?
Shock Tower is offline   Reply With Quote
Old 11-13-2014, 08:20 AM   #7402
Neither, it is between P01 and P02 pieces where they snap together. Make sure they are at the angle that your setup is going to use before you glue them ie set camber, caster, etc and then glue them together. The ball stud on the hub and cup still need to move freely so don't glue those.
A700 17.5 Stock, USGT, CVTA, RCO Sportsman
WF D06 USVTA
trackout is offline   Reply With Quote
Old 11-13-2014, 10:05 AM   #7403
It is also good practice to try to pop the ball cup off as little as possible as each time you do it becomes looser. On the inside ball cups it is a good idea to replace the balls and rod ends with either t.o.p or xray parts.
Team Trinity/ReVtech - Awesomatix USA- Wild Turbo Fans-TQ wire-MRH Racing
sg1735 is offline   Reply With Quote
Old 11-13-2014, 10:48 AM   #7404
I didn't think to glue the ballstub and the ball cup togehter. I thought that applying a little CA on one of those, you would add a little material, and then the excess free play would be removed. I had a Schumacher Mi5, where there was a ball wishbone connector, that would get loos, and then the fix was a little CA to remove the play.
But my mistake, i get it now, thanks.
Old 11-13-2014, 12:57 PM   #7405
G-rem's Avatar
G-rem is offline   Reply With Quote
Old 11-13-2014, 01:09 PM   #7406
gijoe64's Avatar
Trader Rating: 25 (100%+)
Guys i'm selling my EVO, focusing on pan car for now, link below if interested.
FS Awesomatix A700L EVO
Raymon Robinson
ARC, LRP Go Blue!!
gijoe64 is offline   Reply With Quote
Old 11-14-2014, 07:54 AM   #7407
G-rem's Avatar
Nearly new Evo to sell with plenty of parts (a spare GD2, 2 spare GD1, parts for shafts,...), PM me for more info
Old 11-16-2014, 04:19 AM   #7408
Trader Rating: 54 (100%+)
Racing today on a bumpy track. Getting on brakes at one of the turns there are bumps making the car bounce in the back. Creating a spin if I don't set it up just right. The rest of the track the car handles great. I'm running stock 17.5 with L chassis and hanulec/fairtrace go to set up for carpet. Will the asymmetrical mod help?
Jamison R is offline   Reply With Quote
Old 11-16-2014, 06:17 AM   #7409
Trader Rating: 31 (100%+)
I think it may but some of the guys who ran IIC felt the bumps effected the car negitavly this way. Try asymmetrial first (will help some) but if it's not the total fix tray swapping and asymmetrical. I never was able to test this on the bumpy asphalt track in Dayton but regular asymmetrical did help there.
Not soilid advise but well worth your time in trying it.
Monti
Monti is offline   Reply With Quote
Old 11-16-2014, 08:44 AM   #7410
hanulec's Avatar
Trader Rating: 23 (100%+)
Which track Jamison? Do u have a pic of the corner?
Reverse assymetrical doesn't help on bumps (per iic mod tc with reverse assymetrical on rear)
Assymetrical could help.
Another idea is to further soften the suspension (dampening/springs) but run HUGE bars.
Maximum droop to keep tires on the road
Longer links (my setup uses short links)
Thankfully (?) I don't run bumpy tracks much. The bumpiest so far was the washboard straightaway at 2013 asphalt nats. It was my 3rd race with the car ever and tried #3 dampeners all around that weekend. Not recommending this as a solution to bumps.. Just a fact of were my setup was in attempts to combat other handling issues ... And eventually drove me to the base setup i run today.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
daktulos
SEO by vBSEO 3.5.0
