Old 10-27-2014, 08:32 PM   #7336
hanulec's Avatar
Trader Rating: 23 (100%+)
Originally Posted by SavageCanadian View Post
Has anyone had this happen? It came from my mod car, was just driving thru the infield and the car locked up. Looks to be a bad piece of aluminum most likely, this was only the second run on the brand new car.
i've only ever seen this from a Spool that was shimmed at the b10rs / dt02. it applied too much presume on the G03.
Ya I took the cover off earlier as it was just not letting everything move free enough for me, have run my other cars with the covers since new, must have just been a fluke screw or something picked up from the track
depending upon your link configuration, installing a flat head screw + cone washer can be used to prevent excess FFG movement.
Mainly because it's faster and cheaper from the eu. I get my order in 4 days and it's $18 in shipping, from the USA they want $40 and it's almost 2 weeks.
its a shame you've made up your mind from one order in Nov 2013.
there is also a new dealer coming to eastern Canada soon. hope they will help greatly in supporting the cause..
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 10-27-2014, 08:37 PM   #7337
hanulec's Avatar
Originally Posted by trackout View Post
Medium to low traction running Stock classes I would go with the stock kit. It is an amazing vehicle and the current kit comes with a lot of what was previously upgrades. If you were going to run in higher traction environment I would look at AT21-S, the CO1AL-S chassis, AM33-5 spine, and the C21-2 topdeck.
these are some great suggestions.
i'd also recommend-
p20 or 2x st17-1-s
hard front bumper
titanium tie rods - survive crashes much better than the stock aluminum
at21s - work great on low grip too
am19 - for the rear of evo, or front and rear on a700l (requires shorter links)
am24 - floating servo mount or as-700l awesomatix servo
st21s - shorter steering tie rod
Old 10-27-2014, 08:58 PM   #7338
hanulec's Avatar
Any of the setup sheets from IIC available yet from the Awesomatix gods?
Also I was looking at Hanulec's sheet from the IIC warm-up at Horsham, any chance those spring/damper settings are reversed on the sheet? Trying to make sense of why it works but it looks like a very soft setup with only 40.xgF/mm stiffness front and back.
IIC Setups from Kyle Klingforth and Mike Gee posted. Josh ran his Mile High Mod setup. I ran my Horsham IIC Warmup setup
http://www.awesomatixusa.com/p/setup-sheets.html
My 17.5 is really that soft. It helped a TON with the Gravity Tire's want to traction roll.
Old 10-27-2014, 09:06 PM   #7339
Cadman1981's Avatar
Can you elaborate!?
Awesomatix A700L
Tamiya Exotek F104v2
HPI Vorza HP 2.4ghz
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 10-27-2014, 09:15 PM   #7340
hanulec's Avatar
Originally Posted by Cadman1981 View Post
Can you elaborate!?
everyone perfers dealers to speak for themselves
Old 10-28-2014, 02:42 AM   #7341
Does anybody have a good starting 17.5 carpet setup for the Evo using Solaris medium tires?
Thank you,
Patrick
XCELL is offline   Reply With Quote
Old 10-28-2014, 05:39 AM   #7342
hanulec's Avatar
Thank you,
Patrick
please look at any of the setups from Horsham RC. Solaris Medium is our spec tire. Setups from Middle River will also be VERY close (as we race with these guys many times a year -- and are always very fast at our local track)
You'll see a few "flavors" of setups-
1. mike hanulec/larry fairtrace style
2. gee style
most racers who run Solaris tires week over week have one of these types of setups. i'd also recommend taking a look at either Kyle Klingforth/Bill Sydor/Art Scrimo from Mile High Race in 2014.
Old 10-28-2014, 06:01 AM   #7343
Thanks Mike,
I will look them all over.
Patrick
Old 10-28-2014, 06:29 AM   #7344
Trader Rating: 30 (100%+)
Patrick,
I have had four local racers use the Hanulec/Fairtrace set up (snowbirds regardless of chassis type) and had success right off the bat. In all fairness to Gee and the Klingforths of course.
The two adjustments I make for my track is a softer rear bar (1.0) and currently swapping dampeners and in asymmetrical for the rear only. Some reports from the iic stated the track got to bumpy for this so maybe it only works on smoother tracks?
Monti
Monti is offline   Reply With Quote
Old 10-28-2014, 07:15 AM   #7345
Thats awesome, glad to here that interest is growing and there is the sales volume to justify a new dealer. Any chance you can at least name the province?
A700 17.5 Stock, USGT, CVTA, RCO Sportsman
WF D06 USVTA
trackout is offline   Reply With Quote
Old 10-28-2014, 07:33 AM   #7346
SavageCanadian's Avatar
Trader Rating: 58 (100%+)
Send a message via MSN to SavageCanadian
Its nothing against you guys its just the shipping prices are quite out there. Ive been told this from other drivers that i know here as well, that coupled with the duty and brokerage fees it make it super expensive to get some things from the states.
Colin Roussel
PRCC
2013/2014 WCICS CTA Champ
Awesomatix | Roche | Trinity/Revtech | SANWA | ORCA
SavageCanadian is offline   Reply With Quote
Old 10-28-2014, 07:39 AM   #7347
kgombe's Avatar
same here and I'm in TO
Kijana Crichton
kgombe is offline   Reply With Quote
Old 10-28-2014, 08:09 AM   #7348
i'd also recommend-
p20 or 2x st17-1-s
hard front bumper
Thank you for the response fellas. That helps a lot!
rcdepot.us
nxgraphics.ca
Kane-o is offline   Reply With Quote
Old 10-28-2014, 11:01 AM   #7349
Is there a setup sheet for low grip carpet kicking around I could use as a starting point that has the AT21S and the CO1AL-S chassis? I would love to not have to change chassis plates when I go back and forth between event and club racing but we have really low grip carpet since it is a temporary ozite track we layout every two weeks. The stock chassis and AT21 works great on the club track but I haven't found a formula yet that sticks well enough with the AT21S and CO1AL-S in those conditions.
WF D06 USVTA
Old 10-28-2014, 06:13 PM   #7350
hanulec's Avatar
i think changing dampener/spring and sway bar setups could be enough to switch between low and high grip. removing top deck or some am33-5 screws should also help.
another option is to add some shims under the at21s. like 1.0mm.
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
