Old 10-21-2014, 08:26 PM   #7306
geeunit1014's Avatar
Originally Posted by SLOWINSLOWOUT View Post
If I want to run a bit of reactive caster in the front, would I remove say 0.5 from the front and add the same to the rear, to maintain the same roll center?
That is what I would do.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 10-21-2014, 09:23 PM   #7307
oldrcr's Avatar
Trader Rating: 43 (100%+)
Originally Posted by Stogie View Post
Seriously, though. How does something designed and produced in all metric measurements end up with this lone 3/8ths fitting? If it would have been too brittle slimmed down to 9mm, beefed up to 10mm would have worked. Grrrr.....
It had to be just right. Did you ever hear the story about Goldilocks and the three bears?
Alxd - Seattle RC Racers - AWESOMATIX - Having Fun :-)
oldrcr is offline   Reply With Quote
Old 10-21-2014, 10:02 PM   #7308
cmunro's Avatar
Is the a700L kit discontinued? I know it is still on the site , but I heard it was no more and only the evo moving forward
REFLEX RACING/TRINITY/HOBBYWING/AIRTRONICS
cmunro is offline   Reply With Quote
Old 10-24-2014, 03:10 AM   #7309
Default AM01-1
Does anybody have an extra AM01-1 gear box they are willing to sell?
Got one, thanks for the help.
Thank you,
Patrick
XCELL is offline   Reply With Quote
Old 10-24-2014, 03:27 AM   #7310
Wazza22's Avatar
Trader Rating: 21 (100%+)
Hi Patrick,
They are in stock at shop.awesomatix.com
http://shop.awesomatix.com/index.php...product&did=34
Cheers
Old Yokomo's Rule!!
Wazza22 is offline   Reply With Quote
Old 10-24-2014, 03:56 AM   #7311
The only issue with that site is I cannot put my correct address in. I live in Japan, but I have an APO address which is a military address. I ordered though that site when I lived in Germany and it was a pain in the A$$ and it took 2 weeks to receive my stuff. Hoping some one in the US has one they want to let go, but thank you.
Patrick
Old 10-24-2014, 09:10 AM   #7312
Mikkel_R's Avatar
Im after a little help.
I have an Evo and im struggling with lift off oversteer on fast sweepers. The setup up is the Stock carpet setup apart from the top links are one hole in (shorter top links) due to them being the mounting holes for the gearbox/bulkhead mounts and 3000 rear diff oil.
The class im running is 13.5 blinky on Ride REX30 tyres using LRP top grip 3 additive applied 25 minutes before the race with full additive on the rear and 3/4 on the front.
Any help would be great.
Cheers Michael
Mikkel_R is offline   Reply With Quote
Old 10-24-2014, 01:08 PM   #7313
!Mad Max!'s Avatar
Send a message via ICQ to !Mad Max! Send a message via Skype™ to !Mad Max!
Hi Michael ,
I recommend you the setup we used at ETS Pilot race !
Its for 13,5t blinky class with Ride Tires.
Best Regards Max
Best Regards Max Mächler
Team Manager Awesomatix Europe
Sponsored by: Awesomatix / LRP / LEESPEED / PROTOform / Wild Turbo Fan / MMP / APaint / MPE Stickers
!Mad Max! is offline   Reply With Quote
Old 10-24-2014, 03:00 PM   #7314
Mikkel_R's Avatar
Originally Posted by !Mad Max! View Post
Hi Michael ,
Best Regards Max
Thanks for the setup Max, I just have a coule of questions. I havent got the aluminium chassis so can I use the same settings and how do you use the 3rd hole in on the top camber links when there is a counter sunk screw there?
Old 10-24-2014, 03:31 PM   #7315
Xpress's Avatar
The countersink in the bracket is recessed. Shims will key into the countersink.
"Desire is the key to motivation, but it's the determination and commitment to an unrelenting pursuit of laying it down - a commitment to excellence - that will enable you to attain the success you seek to beat ass."
-Espo
Xpress is offline   Reply With Quote
Old 10-24-2014, 04:57 PM   #7316
Mikkel_R's Avatar
Thanks. Ive not built the car so learning as I go along.
One more question sorry. What effect do the top links have when they are different lengths, I understand that it sets the caster but what effect does it have on roll. Like if you changed the link length on a conventional car.
As on the front I can match moving both links into the same postion but on the rear without the option part for the rear front link I cant match the rear rear link. Hope that makes sense.
Old 10-24-2014, 05:27 PM   #7317
Cool
The car is already complicated.... Don't make it worse, and build it by the book first, and then try different link positions.....wowww......
bertrandsv87 is offline   Reply With Quote
Old 10-25-2014, 02:49 PM   #7318
ropezz's Avatar
Modeling
[IMG][/IMG]
ropezz is offline   Reply With Quote
Old 10-26-2014, 05:06 PM   #7319
Any of the setup sheets from IIC available yet from the Awesomatix gods?
Also I was looking at Hanulec's sheet from the IIC warm-up at Horsham, any chance those spring/damper settings are reversed on the sheet? Trying to make sense of why it works but it looks like a very soft setup with only 40.xgF/mm stiffness front and back.
A700 17.5 Stock, USGT, CVTA, RCO Sportsman
WF D06 USVTA
trackout is offline   Reply With Quote
Old 10-26-2014, 07:42 PM   #7320
bkspeedo's Avatar
they've been submitted to mike but i think he's been overwhelmed with catch-up from worlds and iic he hasn't had time to post yet.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10911 11-28-2016 07:09 AM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
