Old 10-02-2014, 02:05 AM   #7201
G-rem's Avatar
Hi there,
new parts available:
- AT04-2: 5mm drive shaft (do not need the ball bearing support anymore)
- SD2: new spur damper. It adds the torsional flex between the spur axle and the rear diff and so gives the "belt drive" properties into A700 shaft transmission.
=> question about it: how do you fix the rear bevel gear (G03) because it seems on the CAD drawing there is no hole to put a screw in it...
Regards;
G-rem
G-rem is offline   Reply With Quote
Old 10-02-2014, 03:38 AM   #7202
Regards;
G-rem
SPR06 wire spring is used for this.
Due to the increased diameter of the pins on SD2 the wire spring holds SD2 much stronger than the front SPR06 holds the main shaft.
One more picture was added: http://shop.awesomatix.com/published...embled_enl.JPG
Oleg Babich is offline   Reply With Quote
Old 10-02-2014, 03:45 AM   #7203
josecarlo1129's Avatar
Oleg, can we still use the SD-1 system to this upcoming SD-2? I cannot see the protruding element on the new AT20-5 to hold the grommets to dampen the Spur.
TIA.
JC
Nitro: On-road 1/8: Motonica P81-RS2/Vox/Savox
Off-road 1/8: JQ TheCar/Vox/Savox
Electric: On-road 1/10 TC: Awesomatix A700 EVO/AE BD/Team Orion/Ko Propo
On-road 1/10 F1: 3Racing FGX + RC9394 Carbon Conversion AE BD/Team Orion/Ko Propo
josecarlo1129 is offline   Reply With Quote
Old 10-02-2014, 04:00 AM   #7204
TIA.
JC
This SD2 variant replaces SD1 system so it can't be used with any current SD1 part except AM12M spur nut.
Optional AT20-6 part that will have the pins for our 5mm rubber collars will be released a bit later.
So the variant of SD2 with AT20-6 installed will have both "dampings": damping of the spur plus the damping of the rear diff.
Old 10-02-2014, 04:12 AM   #7205
Cheers, Oleg. I really like the feel of the SD-2 system as I am racing on asphalt. I will surely wait for that.
Best regards,
JC
Old 10-02-2014, 06:56 AM   #7206
Stogie's Avatar
Ditto for me... already looking forward to trying this out next Summer on big outdoor track Mod racing. Looks like a great design!
Stogie is offline   Reply With Quote
Old 10-02-2014, 07:55 AM   #7207
geeunit1014's Avatar
Originally Posted by Bgilli26 View Post
Thanks guys I'll try am-33 first, then try top deck, one last question do you all suggest 90c 6000 mah, or 90c 7600 mah pack for more equal weight balance ?
I like 7600s for stock and 6000s for mod. My car is balanced at the us weight of 1380 with 7600s.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 10-02-2014, 10:36 PM   #7208
wstuart's Avatar
Trader Rating: 112 (98%+)
Send a message via AIM to wstuart
Would this at all be beneficial for stock on a high bite track. I would imagine in stock you would want as much power as possible getting to the ground. Unless maybe you're on a low grip track.
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Team El Cajon Hobbies
wstuart is offline   Reply With Quote
Old 10-03-2014, 09:20 AM   #7209
hanulec's Avatar
Trader Rating: 23 (100%+)
SD1 wasn't impactful for stock racing. I'll know more about SD1 tomorrow.
I do really like that AT12M though --- as you'll never have a spur gear come loose with it.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 10-03-2014, 01:44 PM   #7210
Trader Rating: 35 (100%+)
Will there be parts for sale at IIC?
XRAY T4 15' MOD:X-RAY T4 15 17.5:T.O.P Rebel WGT:VBC LIGHTNING F1
5280 RACEWAY "Racing Elevated"
MILE HIGH INDOOR CHAMPS April 17-19th 2015 @ www.milehighindoorchamps.com
Losi22 is offline   Reply With Quote
Old 10-03-2014, 01:57 PM   #7211
hanulec's Avatar
yup!
Just started working out the details w/ Ampdraw...
Old 10-03-2014, 02:05 PM   #7212
Originally Posted by hanulec View Post
yup!
Perfect.
Do you think it would be worth doing the a700 to a700l kit. I already have the l chassis, floating servo mount and titanium turn buckles? I run 17.5 and 13.5 blinky with the car.
Thank you
Old 10-03-2014, 02:19 PM   #7213
hanulec's Avatar
Perfect.
Thank you
might not be the worst upgrade... but i'd probably skip past the L right to an Evo. An FFG + am01-1 will get you most of the way. Dampeners might be another good update.
i've seen some VERY fast a700 cars --- like the one piloted by the "God Father" at the Halloween Classic a few years ago.
Old 10-03-2014, 03:01 PM   #7214
E-clip's Avatar
Trader Rating: 39 (100%+)
While on the subject of dampers is there any maintenance required with the Dampers ?
I seen a bit of oil leaking on one of my ???
And what is the difference with DR3 or DR6 ? which would be better for low traction asphalt ?
E-clip is offline   Reply With Quote
Old 10-03-2014, 03:24 PM   #7215
Dampers are zero maintenance, you cannot service them as they are sealed. The oil you see is from the bearing inside. As far as the D3 and D6 I have onlyused the D6 dampers, our track runs from low to medium traction.
HawaiiBob is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17195 01-10-2017 05:04 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
