Old 09-19-2014, 04:41 PM   #7126
TryHard's Avatar
It's not 'active' it's 'REactive'... It doesn't change independent of other things, just changes the toe-in in REaction to chassis roll. And I'll agree the A700 was the most recent to take advantage of it..
Old 09-19-2014, 04:45 PM   #7127
Moderator
Clegg's Avatar
Associated NTC3 had that quite a long time ago, but pretty sure it wasn't the first either.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 09-19-2014, 05:31 PM   #7128
hanulec's Avatar
Trader Rating: 23 (100%+)
i love how the t4'15 thread is bleeding into here. it is bound to happen.
remember folks -- the L or Evo kits include DCJ front drive shafts, a variety of swap bars, and the suspension basically offers nearly every spring/oil combo.
the awesomatix is missing a spur gear and wheel nuts, nor does it include a floating servo mount (but we got a baller servo).
the 2015 car isn't settled yet. euros has set a direction. worlds will re-test the new designs. iic should also provide a peak into the future. once i'm given the OK i'll share as much as i can. until then --> http://www.awesomatixusa.com/2014/09...rly-ready.html
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 09-19-2014, 08:53 PM   #7129
Trader Rating: 18 (100%+)
The only thing that I found valuable from the T4'15 was the attached nifty graphic.
The new arms look good. Let us know how they work in FL!
● AWESOMATIX USA ● ABSOLUTEHOBBYZ ● HEBIKI DESIGN WORKS ●
MDawson is offline   Reply With Quote
Old 09-20-2014, 02:17 AM   #7130
hana166's Avatar
Funny thing for me is in all my own setups I dial the reactive toe to zero..!
hana166 is offline   Reply With Quote
Old 09-20-2014, 02:18 AM   #7131
hana166's Avatar
If anyone has a photo of AM33-5 please post
Old 09-20-2014, 02:48 AM   #7132
All pictures are available on our webshop pages.
http://shop.awesomatix.com/index.php...hstring=am33-5
And here also: https://www.facebook.com/awesomatixRC
Oleg Babich is offline   Reply With Quote
Old 09-20-2014, 03:44 AM   #7133
Hi,
It's nice to see that the development of the car is going on and there a new parts coming but why not putting more efforts in a lower carbon chassis, alloy is nice but tends to bend easier and is less crash resistant. When you see at the results of some drivers with varius carbon chassis of varius brands like MMP Raceberry and others.
I know that you have to make a choice at one point but there is always a but...
It would be nice if Oleg could explane his thoughts and facts about this choice.
toroloco is offline   Reply With Quote
Old 09-20-2014, 05:21 AM   #7134
hana166's Avatar
Thanks Oleg
So the Awesomatix servo will fit underneath for central position?
Old 09-20-2014, 05:24 AM   #7135
hanulec's Avatar
Thanks Oleg
Yes
Old 09-20-2014, 06:28 AM   #7136
If I do have ARS, what (or is there) is the difference of getting your rear toe-in from the suspension blocks compared to getting it from the steering knuckle arm?
Example:
Setup 1. 3deg rear toe-in from suspension blocks; 0deg toe-in in knuckle arms
Setup 2: 0deg rear toe-in from suspension blocks; 3deg toe-in in knuckle arms
Tamiya - Awesomatix - Orca - Orion - LRP - Protoform - Sanwa - Futaba - NASA - Ride
Minami is offline   Reply With Quote
Old 09-20-2014, 07:45 AM   #7137
The part is one solid piece of material with a ot of screw mounting options.
Old 09-20-2014, 08:25 AM   #7138
bkspeedo's Avatar
Example:
There may be some effect from the arm sweep when using toe blocks. Don't know since the amx doesn't allow you to do both. We'll have to see when the general public get's a hold of the 15 and starts experimenting.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 09-20-2014, 09:07 AM   #7139
Example:
To BKs point, the A700 does have the conventional inboard toe (by suspension blocks). You can find plenty of discussion threads on RCTech - just search for inboard toe vs. outboard toe.
My preference has always been more adjustability with the outboard toe.
Old 09-20-2014, 11:45 AM   #7140
Is there a guide anywhere on the AM33-5 and what patterns of screws to use for different stiffness? Trying to setup for a really low grip carpet race this weekend then high grip the weekend after.
A700 17.5 Stock, USGT, CVTA, RCO Sportsman
WF D06 USVTA
trackout is offline   Reply With Quote
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 Yesterday 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
