Old 09-12-2014, 09:54 PM   #7096
Originally Posted by hanulec View Post
a quick build hint for everyone we just picked up the new a700-st17-1-s. when building them, i've found that installing the st13 end first worked best. the st17-1 'cage' is put into a table, and the st16/st13/pin01 assembly is inserted from the top. the st39 'nut' inserted thru the st13 assembly, placed evenly on the 'cage' and slowly screwed on. if you try to force anything, you'll jump the thread. this method ended up being the most predictable for me.
Have had them on for 2 weeks now, if you don't tighten them with a wrench they will loosen. A very small amount of loctite will solve that.
HawaiiBob is offline   Reply With Quote
Old 09-12-2014, 10:34 PM   #7097
hanulec's Avatar
Trader Rating: 23 (100%+)
i used two 3/8" wrenches i got from Loew's
we will see if loctite is needed tomorrow...
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 09-14-2014, 05:55 AM   #7098
G-rem's Avatar
About the ST17-1-S, I lost 2 dogbones and one ST38 last time I hit the track (and first time I used the ST17-1-S)!
So the blue loctite is ABSOLUTELY useful, because even when you tighten them with two wrenches, they can loosen (tested and approved) =/
G-rem is offline   Reply With Quote
Old 09-14-2014, 05:55 AM   #7099
G-rem's Avatar
Old 09-14-2014, 10:33 AM   #7100
Default IIC Build-up
Starting final build-up on one of my chassis for IIC. I'll be running in the stock and spec-gt classes and I tend to like a smoother car rather than charge and swerve. Is the setup sheet from Larry Fairtrace at the 2014 'birds my best starting point?
A700 17.5 Stock, USGT, CVTA, RCO Sportsman
WF D06 USVTA
trackout is offline   Reply With Quote
Old 09-14-2014, 12:05 PM   #7101
Larry's setups are usually a very good start.
Old 09-14-2014, 01:15 PM   #7102
hanulec's Avatar
For IIC .. I think racers are going to want the at21s "low balls" without shims direct to the chassis plate.
A lot of those will be ordered tomorrow...
Old 09-14-2014, 02:18 PM   #7103
will the outdrives from a gd1 diff fit on a gd2 diff?
thanks,
tim
Colorado On-Road RC Club
www.5280raceway.com
www.facebook.com/CORtrack
Driving: Xray T4 2015, T.O.P. Rebel 12, Durango DEX8T, Durango DEX408 v2, Associated B5M, Associated B44.2
rc_speed is offline   Reply With Quote
Old 09-14-2014, 02:28 PM   #7104
hanulec's Avatar
thanks,
tim
Gd1 uses a one piece st07
Gd1 has an option to use st23 and st26 to replace st07
Gd2 uses the st23
Old 09-14-2014, 03:29 PM   #7105
!Mad Max!'s Avatar
Send a message via ICQ to !Mad Max! Send a message via Skype™ to !Mad Max!
Default First Indoor Test
Hi @ all,
did my first indoor test today on our Indoor Track with brand new Carpet. We decided to use the original ETS Carpet which will be used on several Events in the upcoming season. So we have now perfect test conditions
For test today i prepaired 2 cars with same Setup. Only difference was the Chassis. One car with CO1AL and one with the new soft C01AL-S.
I used my ETS MuchMore 13,5T Zero Boost combo and the new RIDE ETS Tires for the 2014/2015 season (#26032)
And i can say I like the new soft C01AL-S more! It offers more steering and at same time better overall handling. Faster direction changes and more overall grip. Lap times were also 2/10 faster and more consistent due the easyer handling with this chassis compared to the C01AL.
I used both chassis with AM30-5. Tested both with 3 screws (front-middle-rear) and with only one in middle. Personally i like it more with 3 screws. Its not so angry on the entry of the corners. Also more stable and consistent during the turns. With only 1 screw it had to aggressiv steering action for me.
But this is a personal thing of the driving style.
So the new C01AL-S performs also very very well on Carpet
Also we tested with different wheelhub combinations. Started with front and rear AM06S like we used in the past and ended with AM06S in front and AM06M. It was awesome how the car performed with this combination.The car was much easyer and smooth to drive. It gave us much better steering feeling and at same point more stable car under throttle action.
Also we can feel a better balanced handling than with the AM06S in front and rear which was a bit more tail-heavy.
I recommend you to test it by yourselfe during your next tests ;-)
Attached the setup here and a picture of our new Carpet Track (Size 28x11m)
Awesomatix EP Touring Car-a700evo-max-indoor-fileminimizer-.jpg   Awesomatix EP Touring Car-10515134_10201546652427864_3572188528867144257_o.jpg
Best Regards Max Mächler
Team Manager Awesomatix Europe
Sponsored by: Awesomatix / LRP / LEESPEED / PROTOform / Wild Turbo Fan / MMP / APaint / MPE Stickers
!Mad Max! is offline   Reply With Quote
Old 09-14-2014, 03:35 PM   #7106
G-rem's Avatar
Thanks for the set-up Max!
Did you try with C21 top deck?
Old 09-14-2014, 06:21 PM   #7107
With the C01Al-S chassis is the center screw hole on the AM08-1 simply not used anymore?
WF D06 USVTA
Old 09-14-2014, 07:23 PM   #7108
hanulec's Avatar
correct!
the front end has been shortened by 1.1mm, and the rear end by 0.8mm.
i ran a Evo + c01al-s/am33-5/am49-3/c21-2 + at21s on saturday in 13.5 and 17.5 blinky tc. we club raced solaris medium tires, and then practiced w/ gravity rc carpet tires. after a bit of tuning, the car showed A LOT of promise. it was just as fast/stable as Larry's c01al/am30-1/c21 + at21s car.
my setup now available at http://www.awesomatixusa.com/p/setup-sheets.html
Old 09-14-2014, 11:10 PM   #7109
!Mad Max!'s Avatar
Hi,
No didn't try with Topdeck so far. Had not enoug time.
Will try this next time.
Next week i will attend at the ETS Pilot Race at the famous Nürburgring ;-)
Old 09-15-2014, 05:13 AM   #7110
is it also possible to change rear outer toe link's to p13-4 & st24 combo ? if I change outer side do I also need to change the inner ones as well to keep the link lenght same as before? I had a problem with popping off during last race, do you recommend or shall I keep the stock closed one and try not to hit anywhere? thanks.
[URL="https://www.facebook.com/cakercshop/?fref=ts&ref=br_tf"]TEAM SHEPHERD TURKEY[/URL]
Duzgit is offline   Reply With Quote
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
