Old 09-09-2014, 01:52 AM   #7066
Wazza22's Avatar
Trader Rating: 21 (100%+)
Hanulec is right about the cooling. I run 13.5T Blinky on a big track at 3.37 FDR. I have a good 40mm fan and the motor runs fine.
Old Yokomo's Rule!!
Wazza22 is offline   Reply With Quote
Old 09-09-2014, 06:15 PM   #7067
hanulec's Avatar
Trader Rating: 23 (100%+)
great news! Complete GD2 now available in the latest A700 Evo and other kits.
http://www.awesomatixusa.com/2014/09...s-and-new.html
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 09-09-2014, 08:49 PM   #7068
hanulec's Avatar
i'm swapping a stock/super stock car over to the c01al-s + am33-5 for this saturday. hope to report back some good news over the weekend...
Old 09-09-2014, 09:51 PM   #7069
DesertRat's Avatar
It's official. I have no idea what what this thread is talking about, it's like differential calculus with all the numbers and letters. Next you're going to try to convince some noobie to order some BAL-l00N S.T.-rings, or 500 feet of racing line, elbow grease, and electrical smoke.
I race toy cars for fun. If I need to explain, you'll never understand.
If everything is under control... go faster.
WTB: Carpet racing in Arizona.
It is obvious and intuitive to the most casual of observers that RC racing is better than golf.
DesertRat is offline   Reply With Quote
Old 09-09-2014, 11:08 PM   #7070
gijoe64's Avatar
Trader Rating: 25 (100%+)
Ha! love it
Raymon Robinson
ARC, LRP Go Blue!!
gijoe64 is offline   Reply With Quote
Old 09-09-2014, 11:09 PM   #7071
The smoke is a special order item
HawaiiBob is offline   Reply With Quote
Old 09-09-2014, 11:21 PM   #7072
G-rem's Avatar
Nice! Can't wait for this
I noticed that my C01AL-S I ran last sunday without topdeck and 4 screws on AM30-5 was a little bit bended lengthwise. But once I put C21, it was flat again. So I think AM33-5 is definitely a must-have for C01AL-S...parts are on the way
G-rem is offline   Reply With Quote
Old 09-10-2014, 02:07 AM   #7073
hana166's Avatar
G-rem please sell me your AM30-5. PM me
hana166 is offline   Reply With Quote
Old 09-10-2014, 02:43 AM   #7074
Originally Posted by G-rem View Post
I noticed that my C01AL-S I ran last sunday without topdeck and 4 screws on AM30-5 was a little bit bended lengthwise. But once I put C21, it was flat again...
Please unscrew your AM30-5 and screw it again. Some tension between the chassis and stiffener that probably causes the bending will be eliminated after that.
I don't recommend to use the most outer holes of AM30-5. We have found that the screws in these holes bend the ends of chassis upwards a bit due to some "boundary effect".
Oleg Babich is offline   Reply With Quote
Old 09-10-2014, 04:25 AM   #7075
hana166's Avatar
Does anyone have a good recommendation for a chassis protector? Preferably an adhesive type. Seems the way to go for asphalt.
Old 09-10-2014, 04:54 AM   #7076
Our drivers in Taiwan use 3Mô Anti Slip Bathtub Strips.
This is very durable ~0,5 mm thickness tape applied along the outer edges of the lower deck.
http://3mcollision.com/7645na-safety...ips-59446.html
http://www.amazon.com/Safety-Walk-76...KNFXS8E1E6XCYY
Old 09-10-2014, 06:00 AM   #7077
G-rem's Avatar
Haha, sorry, nope; I think I will keep it, it is collector now
When I realised it, I was using AM30-5 with only four screws: the two closest to AM49 screws and one before the first hole in the front and one before the last hole in the rear. All other holes (but the first and the last) of AM30-5 were screwed with set screws. I will give a try by unscrewing AM30-5 and tightening it again, thanks for the advice
I think the bend is right before the front of AM30-5 or before the fixing point of AM24 (because when I put my upper deck, the chassis was flat again without unscrewing AM30-5), so AM33-5 will solve this problem. And it seems the car behaves better with less longitudinal flex...
I was using AE one with my carbon chassis. Very protective but very hard to remove properly...I tried the Yeah Racing one but it was too much weak...
With my C01AL-S, I'm trying the JConcept one and it seems very protective and easier to remove than the AE
Old 09-10-2014, 07:00 AM   #7078
Stogie's Avatar
... stuff back in stock ...[/url]
Great news! I was logging in this morning to ask what the story is for the ST17-1-S item availability. Good timing.
Hana - as for chassis protector, I started using these this Summer - cheap (2 for $4) easy to put on (and take off when it's time to go back on the carpet):
http://www.tqrcracing.com/shop/produ....asp?p_id=2724
Stogie is offline   Reply With Quote
Old 09-10-2014, 08:34 AM   #7079
TimmyMontoya's Avatar
These work great and are reusable!!
http://www.discountrcstore.com/epic1DESIGNS_Chassis_Armor_s/1328.htm"]
DiscountRCstore.com new distributor of Xray and Hudy
Xray, Hudy, Schumacher, Fantom, Orca
TimmyMontoya is offline   Reply With Quote
Old 09-10-2014, 01:10 PM   #7080
hana166's Avatar
Thanks guys for the replies, much appreciated
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17189 Yesterday 03:25 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
