Old 10-26-2011, 03:50 AM   #691
No, it's not... Read again Denis's post
Originally Posted by Denis Zuikov View Post
I tried. With ball diff model not stable in corner, i losted 0.3 sec on lap. I use gear diff with LOSI oil 60WT-100WT.
Papi is offline   Reply With Quote
Old 10-26-2011, 04:44 AM   #692
Denis Zuikov's Avatar
Send a message via Skype™ to Denis Zuikov
Originally Posted by bertrandsv87 View Post
Denis you tried the ball diff in the front and rear or only in the rear with front spool/gear diff ??????
(Spool - front, ball diff - rear) - model not stable.
Denis Zuikov is offline   Reply With Quote
Old 10-26-2011, 04:19 PM   #693
When my car is not stable means the diff is too tight or (oil too thick in your case).Did you try a very loose diff setting ?
bertrandsv87 is offline   Reply With Quote
Old 10-26-2011, 07:40 PM   #694
Denis, did you also try the sealed ball diff with slight grease , and no oil ????
Old 10-27-2011, 12:50 AM   #695
No, i not tried ball diff without oil. In gear diff i tried 40WT Losi oil - rear not stable.
Old 10-27-2011, 02:02 AM   #696
You're sure your rear droop is ok ? If Rear is never stable, then check your setup again....
Old 10-27-2011, 02:22 AM   #697
Iím sure he has tested and worked on multiple set-up options for the various track surfaces he races on. Being a team driver he is capable of finding out what does and does not work for him.
XCELL is offline   Reply With Quote
Old 10-27-2011, 03:43 AM   #698
hana166's Avatar
Default inboard toe and weight
Quick question for the drivers, does this car have any inboard toe?
Obviously its infinitely adjustable at the upright but its not the same feeling at all when the mounting points of the wishbone are not parrallel. Also it not easy to change without a new chassis.
There's a lot of aluminium, can it go down to 1350g with a 290g battery?
Cheers in advance
hana166 is offline   Reply With Quote
Old 10-27-2011, 04:57 AM   #699
Velocitygt's Avatar
Cheers in advance
Hi there,
The rear arms have no fixed toe, only adjustable with the links.
I weighed my car with a L/W Mazda Speed 6, 306g battery and 25g balancing weight and it came in at 1353g.
Cheers.
Velocitygt is offline   Reply With Quote
Old 10-27-2011, 05:57 AM   #700
hana166's Avatar
Originally Posted by Velocitygt View Post
Hi there,
Cheers.
Great, thanks for the quick response. Must say I'm looking forward to the build.
Old 10-27-2011, 03:58 PM   #701
Bubblehead's Avatar
What type of diff comes in the kit? 2 ball diffs, 1 spool/ 1 ball diff, 2 gear diffs .
Bubblehead is offline   Reply With Quote
Old 10-27-2011, 04:36 PM   #702
Velocitygt's Avatar
Kit comes with 1 x spool and 1 x gear diff. It's all in the manual that can be downloaded on the awesomatix.com website, Cheers.
Old 10-27-2011, 04:47 PM   #703
The others are extra parts
Electriquement votre...
Drink EARTH water and save lives! in support of WFP
olly986 is offline   Reply With Quote
Old 10-28-2011, 04:13 AM   #704
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
If you guys need more convincing. Hope this does it
+ YouTube Video
Top Racing Photon EX / Mugen MTX-5 / Tamiya M05 / 3 Racing FGX & F113 / Kyosho RB5
Western Zydney Racers (Mini-Z Racing in the west)
http://www.rctech.net/forum/australian-racing/658918-1-28-scale-sydney-racing.html
danjoy25 is offline   Reply With Quote
Old 10-28-2011, 10:54 AM   #705
John.C's Avatar
Trader Rating: 36 (100%+)
Dan - What turn motor do you have mounted and in what direction?
- Middle River Hobbies - The Track -
John.C is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17189 12-09-2016 03:25 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
