Old 07-04-2014, 05:53 AM   #6676
Originally Posted by moodesmo View Post
Is Leespeed Spur any good? Anyone have tried them with SD1 or SD2?
The spurs look cool and are one of the most symmetrical I have used but...only work with SD1 and for stock classes. They are a little thick so need to be shimmed out also. With the SD2 having to drill the 5mm hole for the rubber damper it weakens the spur considerably as they are cut out like Swiss cheese already and when running in modified I was destroying one every meet
You are probably better served with a different brand spur. Their pinions on the other hand are excellent.
Simon Noton is offline   Reply With Quote
Old 07-04-2014, 06:25 AM   #6677
G-rem's Avatar
Hi all,
I noticed there are other updates for the FFG system with the release of AM43-1 and AM44-1. How are they different from AM43 and AM44?
Oleg, do you plan to do other updated parts for the FFG?
Thanks in advance,
G-rem
G-rem is offline   Reply With Quote
Old 07-04-2014, 07:56 AM   #6678
hanulec's Avatar
Trader Rating: 23 (100%+)
ETS @ XRay's factory this weekend. Viljami won 13.5 last year.
http://ets.redrc.net/2013/06/chassis...jami-kutvonen/
Good luck to all of the runners there this weekend!
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 07-04-2014, 09:49 AM   #6679
G-rem's Avatar
Updated Raceberry chassis? Or new Awesomatix one
I suppose Freddy is using a central stiffner, I hope we will have more detailled pictures during the weekend
Speaking of updated parts, may I re-ask my questions ;-)
Old 07-04-2014, 01:29 PM   #6680
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
I have been running modified lately and stuffed up my gd1 diff. Crown gear loosen itselft and also internal plastic gears stripped. I still can't justify ordering gd2 diff so will try to fix my gd1 and also have another spare gd1. I remember before the spec-r internal carbon gears fits. Can anyone confirm this.
Top Racing Photon EX / Mugen MTX-5 / Tamiya M05 / 3 Racing FGX & F113 / Kyosho RB5
Western Zydney Racers (Mini-Z Racing in the west)
http://www.rctech.net/forum/australian-racing/658918-1-28-scale-sydney-racing.html
danjoy25 is offline   Reply With Quote
Old 07-04-2014, 01:38 PM   #6681
hanulec's Avatar
that is the raceberry v2.1 chassis -- just become available.
i suspect Oleg might be at the race ... so you're questions will have to wait.
i'd recommend you invest in the g05st and g06st gears instead. the spec-r gears as supposed to fit, but as you see you'll need to work on the shimming of the large gear to not have it strip out.
Old 07-04-2014, 03:27 PM   #6682
G-rem's Avatar
Thanks Mike, will wait so
Old 07-04-2014, 05:59 PM   #6683
hanulec's Avatar
i've been getting some questions about the proper way to build up the FCB. i've just cracked open my first one and started documenting the build via instagram photos. you don't need instagram to see the pics, you can browse to them--
http://instagram.com/sidepieceracing
http://instagram.com/p/qDBGkPGY65/?modal=true
Old 07-05-2014, 12:05 AM   #6684
G-rem's Avatar
Nice!
Old 07-05-2014, 04:43 PM   #6685
Trader Rating: 18 (100%+)
GD2 + Shepherd Gears
Just had a chance to build up 2 new GD2 with the Shepherd Gear set.
I was surprised how much fitting was needed to get a super smooth diff action.
Normally standard fare to smooth sand the backs of gears but this is what I needed to do to get the Shepherd to work well:
  • Removed the shims behind the small gears
  • Sand the backs of the small gears
  • Sand the fronts/backs of the big gears
  • Wire brush out the teeth of the big gears
  • Fill and bleed with the shock pump
It wasnt so much the work needed - just that it needed that much fitting. Havent had similar issue with Xray or Awesomatix gear sets.
Difference in experience?
● AWESOMATIX USA ● ABSOLUTEHOBBYZ ● HEBIKI DESIGN WORKS ●
MDawson is offline   Reply With Quote
Old 07-05-2014, 05:56 PM   #6686
EastCoasterVa's Avatar
An Awesomatix driven by Jamison Reichard takes podium on it's first race in a pack of XRays. He placed third in a battle that came down to the last turn.
Watch it in HD on Youtube:
https://www.youtube.com/watch?v=fFX_0lUmxcg
http://www.debbiesrcworld.com/
+ YouTube Video
EastCoasterVa is offline   Reply With Quote
Old 07-05-2014, 06:17 PM   #6687
+ YouTube Video
Nice run Jamison. Debbies was one of my favorite tracks to visit while I was out there.
Old 07-05-2014, 06:33 PM   #6688
Cadman1981's Avatar
Originally Posted by daktulos View Post
Hi!
Another new proud A700L owner!
I am a little curious is screwing the ballstud from under AM18-1 can achieve the same link/roll center setting than AM19 without any shim? Probably not very practical or the ballcup may also hit something
I thought of that after ordering some AM19 to try an outdoor setup.
I know it was already talk about but just to be certain on the top deck screws setting a white dot mean something screwed without any ST09 and a red dot no screw or something with a ST09 under?
Thanks!
Alexandre
Anyone?
Awesomatix A700L
Tamiya Exotek F104v2
HPI Vorza HP 2.4ghz
1990s Futaba FXT stadium racer - Mint condition!
And a bunch of other RC kits for me and my kids...yeah...my kids...
Cadman1981 is offline   Reply With Quote
Old 07-05-2014, 08:53 PM   #6689
geeunit1014's Avatar
All I had to do was not run the shims behind the large gears, no other work needed and they are plenty smooth
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 07-05-2014, 09:09 PM   #6690
From the Shephard gear package - did you used the single big flat washer behind the big gear or the Xray part?
I used the washer from the Shephard package as it was washer for backing the ST31. The GD2 kit doesn't come with that washer.
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 Yesterday 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
