Old 06-23-2014, 01:26 PM   #6616
hanulec's Avatar
Trader Rating: 23 (100%+)
Originally Posted by MikeXray View Post
Hey Barry, how did the car handle with too much flex, was it pushy or loose, or just stalling in the corners?
From what I understand -- the stop watch showed the difference.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 06-23-2014, 01:37 PM   #6617
Trader Rating: 54 (100%+)
I just bought a new evo for stock 17.5 racing. Im the first to have one at our newly resurrected track at DRCW. The track has really good traction for asphalt. Looking for a good starting set up and any parts I might want to buy now. Are these the p20 parts noted on previous page? And if yes how many do I need?
http://shop.awesomatixusa.com/a700-p...j590trf0td8jn0
Any help greatly appreciated!
Jamison R is offline   Reply With Quote
Old 06-23-2014, 01:42 PM   #6618
hanulec's Avatar
Just one pack p20. For the front.
Setup wise.. I'd say run mine/Fairtrace from Jackson 2014.
Old 06-23-2014, 02:48 PM   #6619
Awesome. Thanks for the help.
Old 06-23-2014, 03:52 PM   #6620
oeoeo327's Avatar
Trader Rating: 70 (100%+)
The car didn't respond well to steering inputs, and often stalled in the tighter corners unless you applied a little throttle to drive the car through the turn. Unfortunately, doing so didn't allow the car to rotate naturally through the turn, essentially taking away the one big advantage this car has over its competitors. Larger sway bars exacerbated the mid-corner push (while helping minimally with initial steering response), but over the course of a few laps overheated the front tires to the point where the car began to push throughout the entire corner. I decided to try the cut top deck with screws added in the outside holes front and rear, and immediately cut 4 tenths off of an average lap during a 6 minute run. The car responded far better in chicanes, and had more steering.
I switched to an uncut top deck, and the car felt even better. While not quite as fast as Hanulec's EVO, my laptimes aren't that far off...
I was amazed at what 4 screws did for the car - it went from pretender to contender after 2 minutes of work.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
✯Jackson RC✯Horsham RC✯SJCCR✯
oeoeo327 is offline   Reply With Quote
Old 06-23-2014, 04:03 PM   #6621
oeoeo327's Avatar
Agreed... This setup works really well on asphalt, and is a great starting point for a 17.5 setup.
Old 06-23-2014, 09:18 PM   #6622
Stogie's Avatar
Looking at some of those recent set-up sheets, not sure how you guys are getting your cars to work with the rear of the car "stiffer" than the front - 15-20+ gF/mm in some cases (and sometimes even more dampening rear than front)! That just seems completely counter-intuitive to me.
On another note, a couple of technical questions...
1) What is the effect of running the steering rack forward vs. rearward?
2) Under what conditions would you want to use the up-stops, and to what degree can you realistically adjust it?
Stogie is offline   Reply With Quote
Old 06-23-2014, 09:23 PM   #6623
hanulec's Avatar
I'm not sure what you're missing about a stiffer rear suspension. You need to forget everything you think you know about touring cars when you setup an Awesomatix. Lets just say - traditionally you have a 17lb front spring, 14lb rear spring and 350cst oil. When you push down the car's front end and rear end ------- which one is softer??? It is not what you would think based upon those spring rates.
#1 adjusts ackerman. the effect of this is covered everywhere...
#2 up-stops -- beats me. never used it.
Old 06-24-2014, 07:05 AM   #6624
Stogie's Avatar
I tried a couple of those setups and the rear of the car wants to break loose coming out of all but the most gentle corners, no matter how soft I drive it. Went back to my usual ~80gF/mm front, ~70gF/mm rear (2mm dampening gap all the way around) and everything was good again. Must be something weird about Jackson... ? I'm running mod at Leisure Hours, which I would also consider relatively low grip asphalt. Granted, a lot larger track, but cornering is cornering. Bergstrom's setup from Reedy makes a lot of sense, I'll probably migrate that direction with my setup, which isn't too much of a stretch from where I am now.
I'll experiment with the up-stops next time I'm at the track - particularly the ones in front. I'm wondering if I limit the up travel for the front arms to where the chassis down travel stops just short of hitting the setup board... will that make an impact of the occasional ass-happiness of the car under hard braking for a sharp turn? (That's my theory, anyways).
Also... any thoughts on a realistic lifespan of the springs? I have to wonder if they warp or change consistency over time. Just thinking it may be a good idea to put new ones on every 6 months or so?
Old 06-24-2014, 07:37 AM   #6625
hanulec's Avatar
Stogie - the best advise I can give you is have a friend track side with a 2mm and 1.5mm wrench. Adjusting dampeners in and out, adjusting droop, and even considering adjusting the spring settings you can learn a lot. For stock -- I found these base settings after 2 months of wasting time with setup sheets --- and only found useful settings in 30m of track time with wrenches and a friend.
Setting the front/rear dampeners the same way is a great trick to manage getting close to the baseline. If the car pushes a bit on entry ... Soften the front dampener or spring.
For mod -- I'd look at Josh's or Gee's setups. Bergstrom's Reedy setup might work too in mod.
Spr01/s should last a long long time unless you have many board meetings. Spr02 are more sensitive to crash damage.
I've never used downstops. I like my asphalt car to Al ghtlt bottom out at the tightest/slowest corners on the track. I feel like the car is working well then. If it is too much, just add some front dampening.
Remember a larger #mm in dampener increases dampening. A larger #mm in spring (hook) decreases spring rate.
Old 06-24-2014, 09:40 AM   #6626
Styles's Avatar
I have a A700L for sale over in the for sale thread. Lots of spares and electronics to go with it. I've had it up for a while and thought I would mention it in here before I move it to eBay. Hope thats ok.
Click here to jump over and check it out
-Attack this day with an enthusiasm unknown to mankind-
Styles is offline   Reply With Quote
Old 06-24-2014, 03:54 PM   #6627
JayL's Avatar
Would the rollcenter of the Raceberry with AT21 under the arms be close to stock chassis with AT21S under the arms?
A800 HW XR10Pro HW G2 4.5T|||B5MFL HW StockSpec Team Powers 17.5|||VTA: Awesomatix EVO 1.1 Orca VX3 |||F1:
Xray X1 2016, HW V3.1, Ride XR Tires, D4SS 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 06-24-2014, 04:55 PM   #6628
hanulec's Avatar
That is what I believe.
RACEBERRY or C01AL + AT21 equal to C01L + AT21S
Old 06-24-2014, 05:53 PM   #6629
JayL's Avatar
thank you!
Old 06-24-2014, 08:01 PM   #6630
hanulec's Avatar
thank you! you mean this thought, right:
RACEBERRY or C01AL + AT21S equal to C01L + AT21
i had a typo-- corrected it.
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
