Old 06-09-2014, 02:06 PM   #6541
Full lock I can get around 24-25 degrees,, maybe a degree less, measured on the inner wheel. I am using 1degree toe out and the ackerman is set on forward
I'am using the standard rack with ST24 on it and an Xray servo saver (the old version without the top hole,which was selled with the T3)
Awesomatix | LRP
Awesoman is offline   Reply With Quote
Old 06-09-2014, 02:55 PM   #6542
hanulec's Avatar
Trader Rating: 23 (100%+)
I'm at 20 inner and 30 outer
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 06-09-2014, 03:50 PM   #6543
Trader Rating: 18 (100%+)
What is the steering rack/ackerman/servo saver setup for that?
● AWESOMATIX USA ● ABSOLUTEHOBBYZ ● HEBIKI DESIGN WORKS ●
MDawson is offline   Reply With Quote
Old 06-09-2014, 06:02 PM   #6544
hanulec's Avatar
AS-700L or Sanwa SGR-BLS within AM24 shimmed 1.75mm back
P40K or P40F
Rack back
Forward on AM14
Old 06-09-2014, 06:07 PM   #6545
P40K or P40F
Rack back
Forward on AM14
Thanks gents. Gives me some things to play with.
Old 06-09-2014, 06:16 PM   #6546
hanulec's Avatar
i normally race with 17 degrees of inner wheel on carpet, and 19 degrees of inner wheel on asphalt
Old 06-09-2014, 07:41 PM   #6547
geeunit1014's Avatar
Anyone?
What is the maximum amount of steering throw you can get? Full lock - what steering rack and steering arm are you using?
Dawson, with the rack back, and the links out the outer hole on the steering arm, I am running 27* on the inside wheel
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 06-09-2014, 07:47 PM   #6548
hanulec's Avatar
maybe i have my inner and outer wrong...
Old 06-09-2014, 08:28 PM   #6549
L.Fairtrace's Avatar
Send a message via AIM to L.Fairtrace
Hanulec the rack is back on your 17.5 car. Thats how it was when you gave it to me.
T.O.P Racing - Awesomatix USA - EaMotorsports - BSR Racing Tires - Orca - TQ Wire - Solaris Racing Tires - Side Piece Racing
Horsham RC. Where champions practice Failing. I'm your everything.....
L.Fairtrace is offline   Reply With Quote
Old 06-09-2014, 08:32 PM   #6550
Thanks! Congrats on your run this weekend. Posting that setup?
Old 06-09-2014, 09:28 PM   #6551
JayL's Avatar
If anyone has a Raceberry chassis they want to sell PM me please
A800 HW XR10Pro HW G2 4.5T|||B5MFL HW StockSpec Team Powers 17.5|||VTA: Awesomatix EVO 1.1 Orca VX3 |||F1:
Xray X1 2016, HW V3.1, Ride XR Tires, D4SS 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 06-09-2014, 10:40 PM   #6552
question, im running a spool on asphalt. whats the consensus, spool or diff on asphalt? the car feels good but pushes a tad on entry from the high speed straight slight right and then 180 degree right. im having to tap the brakes to set the car due to the push. i have disabled the front swaybar to counteract the push but im looking for a little more corner entry. upon exit if im smooth its a non issue but if i stab the throttle it tries to hook the car so i lose a little exit speed in trying to counter the hooking. thoughts? should i change to the diff?
dragonracing is offline   Reply With Quote
Old 06-09-2014, 10:54 PM   #6553
Mod or stock?
Tire?
Body?
What are you running in the rear - gear diff (oil?) or diff?
Old 06-09-2014, 11:37 PM   #6554
sorry. scale spec 21.5, hpi d compound tires, protoform zl1 camaro. gear diff is 3000 wt oil. im just thinking that ill try the gear diff in the front. if it makes a difference ill keep it that way. so far i can walk away from the field but i want just that little bit more. last weekend the spur gear nut came loose on me 5 laps in and i was walkin away. ended up walking away in shame. lol.
Old 06-09-2014, 11:57 PM   #6555
Do they make a Special wrench for that nut ???? I put a little loctite on mine....
bertrandsv87 is offline   Reply With Quote
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
SEO by vBSEO 3.5.0
