Old 05-18-2014, 08:30 AM   #6436
Trader Rating: 32 (100%+)
I had a good day yesterday in Toledo with a TQ and win in both 17.5 and mod TC.
Monti
Monti is offline   Reply With Quote
Old 05-18-2014, 11:32 AM   #6437
bkspeedo's Avatar
Monti
Nice job Monti
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 05-18-2014, 05:55 PM   #6438
Jerry P's Avatar
Trader Rating: 44 (100%+)
Monti
Great job Monti!!
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 05-19-2014, 06:50 AM   #6439
Originally Posted by bkspeedo View Post
Nice job Monti
Originally Posted by Jerry P View Post
Great job Monti!!
Thanks guys! It was nice to run some asphalt even though it was only 50 degrees with some wind thrown in.
The track in Toledo is a must attend/buckett list type track and if you ever get the chance to go I recomend it.
Monti
Old 05-19-2014, 07:44 AM   #6440
Monti
My congratulations!
Please inform your setups.
Oleg Babich is offline   Reply With Quote
Old 05-19-2014, 01:00 PM   #6441
I sold my A700 with lot of parts.
Details are here :
Awesomatix A700 + lots of parts
Team Speedpassion driver
http://www.speedpassion.net/en/ourteam.asp
chrispys is offline   Reply With Quote
Old 05-19-2014, 03:56 PM   #6442
Question for the awesomatix masses.
Running 17.5 blinky on med traction carpet and trying to find a setup I like. I've looked through the setup sheets on the website and I don't see much for an evo with a 17.5.
Since I have the parts for the L and Evo, is there any advantage to going back to the L configuration?
Ricky Garner
Sponsors: My Wife and AVID RC
Mclarein is offline   Reply With Quote
Old 05-19-2014, 04:19 PM   #6443
bkspeedo's Avatar
I believe Fairtrace's setup for 17.5 from Snowbirds is an EVO. You can also try anyone's 13.5 setups for the EVO, they should work well in 17.5. Check out Kyle's ROAR nats 13.5 setup. You might have to adjust the sway-bars depending on traction and tires.
Brent Klingforth
Old 05-19-2014, 04:27 PM   #6444
I actually tried Kyle's 13.5 setup, just messing around. Because I bought mine used, I'm trying to figure out how to use the topdeck with the evo setup.
And I found a diagram
Ricky Garner
Old 05-19-2014, 04:53 PM   #6445
bkspeedo's Avatar
If your running on lower grip or your tires are on the harder side like the Gravity tires we used at MHIC try more droop. 2.5 - 3mm in the front and 3-3.5mm in the back over ride height. We found harder tires like these need more droop for the car to be fast.
If you start traction rolling back out droop until it stops but go no less than 1mm in the front and 1.5 in the back. Start making other changes like softening the suspension.
Brent Klingforth
Old 05-19-2014, 05:31 PM   #6446
hanulec's Avatar
Trader Rating: 23 (100%+)
Ricky- what is your driving style?
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 05-19-2014, 08:22 PM   #6447
Brent, we run sweep 28's with paragon black, really soft tires especially after a few hard runs.
I don't really know how to describe it (besides crappy). l like the car to roll more than a stiff setup. Larry's birds setup feels better to me than Kyle's 13.5 setup did. I removed the top deck and the setup felt better.
Ricky Garner
Old 05-19-2014, 09:01 PM   #6448
hanulec's Avatar
28 tires + black can paragon. sounds like a lot of grip.
the reason i ask how you drive is that on carpet people can get away with a bunch of different styles (less so on asphalt, in my option). i know larry drives w/ a lot of push brake and focuses on a slow in, fast out approach. kyle uses a drag brake + toss the car into the corner approach. both can work -- but the setups are VERY different.
with such high carpet, it is hard to get a lower roll center than what larry ran. only adding at21s could make it much lower.
Old 05-19-2014, 10:55 PM   #6449
bkspeedo's Avatar
Ya this could definitely be on the higher traction side. Even though I was not running a EVO you could try my Carpet Nats setup. It does require the AT21S arm balls, for me this was key. At home after Nats when I ran very grippe Sweeps this setup was unbeatable even against Kyle at 5280. If you need more steering make the front sway-bar smaller or even remove it. My driving style is more on the less aggressive side. I turn the wheel slower into and through the turn instead of whipping the car around the corner and get on the throttle smoother than most. I'm am surprised you liked the car with out the top deck. Most at 5280 on high traction carpet the top deck on an EVO with the C01AL chassis.
Brent Klingforth
Old 05-20-2014, 12:12 AM   #6450
As of this moment I'm running larry's setup with no top deck, 2k xray diff oil rear, at21s. I tried it with the top deck and it just felt too stiff but that was before I put on the at21s or the 2k diff. The car is pushy into the sweeper but better than it was.
After much debate with my track pals, I drive more like Kyle than Larry. I did try Kyle's setup though and it didn't feel too great. I'm just messing with the car, since I have a couple of different setups that are okay adaptations of other people's setups.
I would like to find that magic base setup, and I don't feel like I'm there. We are two weeks from the start of our summer Electric series and the first race is our only indoor race. That's the deadline for finding that magic baseline.
On a side note, I got the sample back from my father-in-law for my new pit cover. Background material will be grey and less space between the logos.
Ricky Garner
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17196 Today 01:50 AM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
