Old 05-15-2014, 06:40 AM   #6421
Trader Rating: 31 (100%+)
Stupid cell phone double post!
Monti is offline   Reply With Quote
Old 05-15-2014, 06:41 AM   #6422
Originally Posted by cosmokitten View Post
Guys,
Assembled my GD2 for the first time last night with the Shepherd metal gears. First assembled without oil to make sure the fit is good. Everything was OK until I fully tightened the diff halves, then the diff was locked. Triple checked everything, the diff halves spin nicely with the internal gears when separate, they also spin nicely during attachment of each diff halve (ensuring the gears are aligned), but when performing the final tightening of the halves, the diff is locked.
I'm wondering whether I should omit the spacers behind the two larger internal gears? Has anyone else experienced this when assembling GD2 with Shepherd gear combo.
Appreciate!
You can't run the shims behind the large gears. Take those out and it will work just fine.
Monti
Old 05-15-2014, 08:26 AM   #6423
RC Professor's Avatar
Guys,
Appreciate!
I've seen this before as well. To add to what Monti said, the issue I ran into was the bearing on one side not fully pressing onto ST31. There was a very slight interference fit between bearing and ST31 not allowing it to fully seat. Once this was pressed down all the way, it freed up the gears.
RC Professor is offline   Reply With Quote
Old 05-15-2014, 08:58 AM   #6424
Quantra's Avatar
Just seen this...
Servo: http://shop.awesomatix.com/index.php?productID=1011
Open ball cups: http://shop.awesomatix.com/index.php?productID=1017
Long ball studs: http://shop.awesomatix.com/index.php?productID=1023
Saw this on Awesomatix facebook page: https://www.facebook.com/awesomatixRC
Vince Coleman
Quantra is offline   Reply With Quote
Old 05-15-2014, 09:04 AM   #6425
!Mad Max!'s Avatar
Send a message via ICQ to !Mad Max! Send a message via Skype™ to !Mad Max!
Guys,
Appreciate!
Hey,
use these 2 small shims which are by the MG Diff set instead of the big ones.
Whit these its super smooth and runing nicely.
Best Regards
Max
Best Regards Max Mächler
Team Manager Awesomatix Europe
Sponsored by: Awesomatix / LRP / LEESPEED / PROTOform / Wild Turbo Fan / MMP / APaint / MPE Stickers
!Mad Max! is offline   Reply With Quote
Old 05-15-2014, 09:04 AM   #6426
This thing looks really nice
Oleg,
can you tell us the performances of the servo? Will it be available with engraved name?
And will it also be available thru Shepherd or only through the Awesomatix online store?
Awesomatix | LRP
Awesoman is offline   Reply With Quote
Old 05-15-2014, 09:41 AM   #6427
cosmokitten's Avatar
Monti
Great, thanks Monti!
How about filling the gear diff....I read about some extravagant methods to fill the diff up via syringes, extracting the air and sucking in the fluid...what about normal, manual filling of the half diff? How much fluid? I couldn't find any fill limit mark as per GD1 instructions.
Thanks!
cosmokitten is offline   Reply With Quote
Old 05-15-2014, 09:41 AM   #6428
Originally Posted by !Mad Max! View Post
Hey,
Best Regards
Max
Nice, thanks....
Don't these small shims come with the Sheperd gear set? or are they different?
Thanks!
Old 05-15-2014, 09:55 AM   #6429
Looking at the picture, it seems like to me that these shims are the same than the 0.1mm shims supplied with the car kit
Awesomatix | LRP
Old 05-15-2014, 10:56 AM   #6430
Oleg,
Weight: 50.0g
Speed: 0.070secs/60 deg at 6.6V
Torque: 13.20 kg/cm (183.22 oz/in) at 6.6V
Gears: 7075-T6 Alloy
Bearing: 2BB
Case: Alloy
25 Tooth Spline ( Futaba size)
Operating Voltage: 4.8V – 6.6V
Frequency range: 50-400Hz
Engraved name is possible.
The servo should be available through all distributors also.
Oleg Babich is offline   Reply With Quote
Old 05-15-2014, 03:56 PM   #6431
JayL's Avatar
Any idea when the servo will be coming to the USA?
A800 HW XR10Pro HW G2 4.5T|||B5MFL HW StockSpec Team Powers 17.5|||VTA: Awesomatix EVO 1.1 Orca VX3 |||F1:
Xray X1 2016, HW V3.1, Ride XR Tires, D4SS 21.5|||Futaba 4PX|||iCharger 308Duo
JayL is offline   Reply With Quote
Old 05-15-2014, 05:08 PM   #6432
hanulec's Avatar
Trader Rating: 23 (100%+)
will be on order today...
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 05-16-2014, 06:59 AM   #6433
Jerry P's Avatar
Trader Rating: 44 (100%+)
I can't wait to get my servo's.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 05-16-2014, 07:02 AM   #6434
Why? They are not going to help you drive better.
Monti
Old 05-16-2014, 07:12 AM   #6435
Jerry P's Avatar
Monti
I cant drive so I need to look good at least.
Jerry P
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
