Old 04-28-2014, 04:21 AM   #6241
hanulec's Avatar
Trader Rating: 23 (100%+)
Originally Posted by HoJo View Post
Has anyone experienced a wobbly outdrive on the gear diff (not the GD2).
Here's a video of the wobble (visible when the motor is going at low revs)
+ YouTube Video
Any advice on how to eliminate the wobble would be most appreciated. TIA
I don't see it from the video.
Does the issue follow the outdrives or output shaft?
Have u swapped the outdrives left/right?
Did you inspect the parts when unassembled?
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 04-28-2014, 05:50 AM   #6242
oeoeo327's Avatar
Trader Rating: 70 (100%+)
Originally Posted by MikeXray View Post
My car was good on asphalt with the carpet setup, just cut the top deck, and added camber. By the time I was ready to try some shock settings, it rained. I tried running a mazda again, but was consistently slower than the ltc (17.5).
Same here, but tried a little reactive caster in the front -I added 1/2 degree of camber to all 4 corners, and didn't change anything from my carpet setup. Going to try the same suspension setup using the Raceberry hard chassis this coming weekend.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
✯Jackson RC✯Horsham RC✯SJCCR✯
oeoeo327 is offline   Reply With Quote
Old 04-28-2014, 08:36 AM   #6243
dizzy1's Avatar
What's the general opinion of when to run a cut top deck(non evo)? Asphalt? Low-med bite? Tried one yesterday when testing some things and felt easier to drive but no timing loop so not sure if faster.
Also for GD1, are still some running 2 metal/2 plastic middle gears or just all plastic? What part# is correct for metal gears on GD1?
All about that Hot Pockets again! Woot Woot! Tried the Russian rocket but tired of the 'part of the week'. All gold everything '15 only made a weekend, such a numb and overpriced car!
Team Hot Bodies- Hobbywing- Schuurspeed
dizzy1 is offline   Reply With Quote
Old 04-28-2014, 09:20 AM   #6244
oeoeo327's Avatar
Metal gears for GD1:
Outdrive Gears - G05ST 20T Steel Gear x 2
Spider Gears - G06ST 10T Steel Gear x 4
Since switching to metal diff gears, I only use 2 spider gears. If I were driving the car in mod, I'd probably rebuild the diff to use all 4 spiders...
Old 04-28-2014, 10:48 AM   #6245
geeunit1014's Avatar
Pretty much all the time on asphalt you will want to run a t cut topdeck. Only if the grip was super mega high would I think about changing back, but I think there's only a handful of tracks in the world that would qualify
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 04-28-2014, 12:19 PM   #6246
dizzy1's Avatar
For the cut deck are you just cutting out the obvious spots or splitting the whole deck? I went back to Oleg's pic but its not longer available on rctech, anyone have updated pic?
Old 04-28-2014, 12:23 PM   #6247
elee32's Avatar
Trader Rating: 18 (100%+)
Cut all the way through...even the solid part towards the front.
Eric Lee, sponsored by shipping and handling..
elee32 is offline   Reply With Quote
Old 04-28-2014, 12:31 PM   #6248
dizzy1's Avatar
Perfect! Thanks
Old 04-28-2014, 01:19 PM   #6249
http://www.rctech.net/forum/12215235-post3555.html
Oleg Babich is offline   Reply With Quote
Old 04-28-2014, 06:58 PM   #6250
dizzy1's Avatar
Thanks Oleg! Going to get out the dremel!
Old 04-28-2014, 08:02 PM   #6251
HoJo's Avatar
Originally Posted by Awesoman View Post
You should check the inner ball bearings and the O-ring.
If you have any doubt on them, change them.
Thanks all for your response. I have re-checked the inner ball bearing and also the o-ring. There's a fair amount of leak at the moment from that outdrive, so it could be the o-ring. I will have it swapped and hope for an improvement.
PS Mike - I have received the items I ordered. Thanks for your prompt delivery. Cheers
HoJo is offline   Reply With Quote
Old 04-28-2014, 10:10 PM   #6252
SavageCanadian's Avatar
Trader Rating: 58 (100%+)
Send a message via MSN to SavageCanadian
So I got my first evo and have read that it needs a special kind of tape for part of it. Neither of them I can get here I Canada and nor would I at the price so what can be used? For the money this cost I'm less then impressed
Colin Roussel
PRCC
2013/2014 WCICS CTA Champ
Awesomatix | Roche | Trinity/Revtech | SANWA | ORCA
SavageCanadian is offline   Reply With Quote
Old 04-28-2014, 10:13 PM   #6253
hanulec's Avatar
Colin - most of us are running scotch tape...
Once you get past the small things -- like no wheel nuts -- you'll be impressed
Old 04-29-2014, 12:03 AM   #6254
Smile
Titanium chassis will be next Hanulec ??? LoL...... Keep us posted.....
bertrandsv87 is offline   Reply With Quote
Old 04-29-2014, 04:38 AM   #6255
Default Awesomatix EX for sale
Hi guys, im selling my EX. Reason because I got no time. Bought for 689 but selling for USD 5++. Condition is 9.5/10. Extremely hardly used. Please PM if interested as I hardly on RCtech.
Velox8 is offline   Reply With Quote
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
