Old 04-17-2014, 06:41 AM   #6151
Smile
Make sure your plastic diff covers are not rubbing on the gears...
Originally Posted by SniperWJ View Post
guys,any advise on cooling solutions for my evo?
Usually I'm running 13.5t boosted and modify 4.5t with some boost and turbo on my belts Tc
My evo is running 30-40% more temp for the same setup.
Any ideal?
Yiming
bertrandsv87 is offline   Reply With Quote
Old 04-17-2014, 07:08 AM   #6152
bhambrent's Avatar
Hello guys,
I'm still new with the a700l u.s spec, and have some gearing questions. The track I run on is 73x40 it's tight with some 180's. I do not fell that it is coming out of the turn as hard as it can. I'm running a EA killshot with 12.5 rotor 80 spur and 47 pinion.
I want to get more rip out of the corners, should I go with a smaller spur? like 75 or 77?
Thanks for your help,
Half-A$$ Racing - Cooperhobbies.com - Hot Bodies D413 - OneLug Hobbies - Awesomatix - Thunder RC Raceway - SpeedKingz Racing "G SERIES"
bhambrent is offline   Reply With Quote
Old 04-17-2014, 07:28 AM   #6153
geeunit1014's Avatar
Originally Posted by bhambrent View Post
Hello guys,
No, you would want a bigger spur gear, or smaller pinion. I ran 80/44 on a d3.5 on carpet tracks that are bigger than yours so I suspect you are overgeared.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 04-17-2014, 07:43 AM   #6154
oeoeo327's Avatar
Trader Rating: 70 (100%+)
Hello guys,
+1 on the overgearing theory. If you're on a track with a lot of slow corners, you might want to try a pinion in the 40/41 range and work your way up if needed.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
✯Jackson RC✯Horsham RC✯SJCCR✯
oeoeo327 is offline   Reply With Quote
Old 04-17-2014, 09:30 AM   #6155
artwork's Avatar
Trader Rating: 53 (100%+)
I think a lot of us use the stock servo mount to attach the fan to the motor...seems to work very well.
Xray | Hudy | Sanwa | R1 Wurks | Avid | Protoform | Proline | 2mm Designs
artwork is offline   Reply With Quote
Old 04-17-2014, 11:00 AM   #6156
bkspeedo's Avatar
Hello guys,
Your running a 3.5ish FDR which is high for a tight layout on a track that size. Try a 44 or 45 pinion. Make sure your timing is set appropriately as well.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 04-17-2014, 04:27 PM   #6157
Thumbs up
Mike, I got the package today. Thanks - John
Number 49 Lou's Speedway Canada, Honda House www.hondahouse.com
ElliotCanada is offline   Reply With Quote
Old 04-17-2014, 09:13 PM   #6158
bhambrent's Avatar
Thanks for the help guy's,I'm going to have a test day Saturday to get it locked in.
Again Thanks,
p.s. Heat in the motor is only getting to 130 to 135 after 6 min., so its not getting worked to hard. But will try a lower pinion before going to crazy.
Old 04-18-2014, 07:56 AM   #6159
Mart42's Avatar
Hi guys,
I am ready to order my Awesomatix EVO US spec. I would like to know what chassis is the best for 17,5 on med-high grip carpet: Stock-Alloy-Raceberry ???
Did i need the top deck?
Martin
MARTIN LECUYER
Destiny - Xenon USA - SpeedMerchant - SMC - Team Scream - Hobbywing - BSR - SlyGraphiX - Carpy's
martin_lecuyer@hotmail.com
Mart42 is offline   Reply With Quote
Old 04-18-2014, 08:33 AM   #6160
Trader Rating: 14 (100%+)
Hey hanulec any ideas on when the raceberry chassis will be available? I'd like to have one before reedy race.
www.5280Raceway.com | Racing. Elevated.
samsking is offline   Reply With Quote
Old 04-18-2014, 09:16 AM   #6161
Originally Posted by Mart42 View Post
Hi guys,
Martin
I prefer the aluminum chassis for carpet. I do not use a topdeck, but some guys do, its more of a personal preference.
Mike Gee
Old 04-18-2014, 09:22 AM   #6162
Mart42's Avatar
Thanks Mike
MARTIN LECUYER
Old 04-18-2014, 11:37 AM   #6163
+1 to Mikes post. I feel the aluminum CA01AL chassis offers the best corner speed option on carpet. Don't forget to order the chassis stiffener brace, AM30-1 when ordering the chassis as well as AM24! Also its nice to get an extra pack of P06-1 so both chassis can be setup.
Kody
Kody is offline   Reply With Quote
Old 04-18-2014, 01:19 PM   #6164
Hi all,
I've been testing my Evo on a big asphalt track.
I'm using the standard setup for the Evo, which is designed for carpet.
I don't have enough steering off power and my rear end gets loose every time I hit the brakes or get out of the corners. The only difference to the standard setup is my diff oil. I'm running 1000cst.
I'm running non-boosted 10.5 and a Speed6 shell.
Can anybody please give me hints to get the car dialed in? It's really undriveable at the moment
Cheers.
Awesomatix | LRP
Awesoman is offline   Reply With Quote
Old 04-18-2014, 01:44 PM   #6165
hanulec's Avatar
Trader Rating: 23 (100%+)
The goal is mid-may. Fingers crossed -- it will make it for the reedy...
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
