Old 03-31-2014, 10:11 AM   #6061
Jerry P's Avatar
Trader Rating: 44 (100%+)
Originally Posted by dizzy1 View Post
What upper ballcups and balls are everyone using? I miss the ability to put a wrench thru the ball cup to loosen up the ball to change shims. I see in the pic a few posts up it has what I want.
A few of us are using TOP racing ball cups and balls.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 03-31-2014, 11:35 AM   #6062
MikeXray's Avatar
Trader Rating: 72 (100%+)
Originally Posted by thecaptain View Post
Yes that's what im asking, specifically to that rear castor. I can easily modify the front steering, castor blocks to assume the position of just the c hub in that rear. A dremel and some sand paper would see to that. Now would having permanent castor in the rear. That would affect the rear tires slip angle constantly yes? Yes they are fine tuning options that why I am looking to try these. I appreciate the responses and information, trying to negate my ignorance towards this.
Am I thinking of this wrong, but using a front castor block on the rear will not give you dynamic caster, just static, which is the same as moving a wheelbase shim right?
Even with with A700, if I set rear caster to 2dg, the wheelbase is static, I'd have to use shims under one link to get dynamic.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-31-2014, 11:39 AM   #6063
Trader Rating: 45 (100%+)
Right it would just be static castor, I feel like thats not right, but once again im not entirely sure. I feel like it shouldnt really change the wheelbase, however it would change the tire slip angle. It would make the tire lean(give it castor), which yes would change the wheelbase slightly, and also put the rear tire on an angle. So im not sure, I feel like there isnt a huge data base of information about this specific subject.
thecaptain is offline   Reply With Quote
Old 03-31-2014, 08:02 PM   #6064
hanulec's Avatar
Trader Rating: 23 (100%+)
Originally Posted by bkspeedo View Post
Rear Caster - used to adjust wheelbase, no other effect that i'm aware of.
Rear Bump steer - used to increase or reduce rear toe as the car leans into the corner. I've played with this a little but not enough to say it's beneficial setting. If the link is angled upwards it increases tow in as the arm lifts, link flat less to no toe in change in on arm rise, angled down decreases toe on arm rise.
Reactive Caster in the front - same theory as 12th scale reactive caster. As the arm lefts caster will be removed. Info from 12th scale setup guide.
-Increase the angle Make the car react quicker & offer more steering.
-Decrease the angle make the car easier to drive smoothly into corners.
I personally like this setting and use it on both my cars, gives the car more overall steering through out the entire turn.
I don't know if I "buy" the rear caster only effects wheelbase. I'm pretty sure it effects camber as the car squats. With all of the adjustments on this line of cars -- I just keep rear caster at 0.
I'm a HUGE FAN of the rear bump steer adjustment. Adding more shims between the am23 and ball stud frees up the car in the corners. I much prefer to make that adjustment vs reducing static toe.
Thankfully there are a lot more Awesomatix drivers now -- probably nearly 100 more in the USA -- so as people try things hopefully they will post up here.
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 03-31-2014, 08:28 PM   #6065
geeunit1014's Avatar
Oleg has posted on here before that the other effects besides wheelbase are negligible. I personally think its another good option to play with, shorter WB is more aggressive, longer is smoother. I had 4* caster shortening the WB at horsham in 17.5 saturday
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 04-01-2014, 08:53 AM   #6066
Moderator
Clegg's Avatar
I was also thinking of how rear reactive caster can change quite a few things on the rear of the car mid corner when the suspension is loaded. You are able to affect rear toe gain/subtraction, and you can have the wheelbase actually shorten or lengthen in high load corners via that. Could be a pretty dramatic affect on the car.
Not sure where you'd want any of that, but like the rear bump steer adjustment, its something unique to these cars.
Joe Kelly - JK720.net
5280 Raceway |5280raceway.com | 5280 Raceway Facebook
Clegg is offline   Reply With Quote
Old 04-01-2014, 10:49 AM   #6067
haywood's Avatar
Trader Rating: 47 (100%+)
Default Gd2
Has anyone tried a Gd2 in front with 1-2.5mil?
/ Roche Rapida 2015-2016 / Hobbywing / Team Scream / Rc Painting By Mikey / Ko Propo / MMR / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 04-01-2014, 10:53 AM   #6068
hanulec's Avatar
I've only used a gd1 with 2.5m. I still prefer spools.
Old 04-01-2014, 11:02 AM   #6069
Magnet Top's Avatar
Last month the 2014 Roar Carpet National Champion , Kody Knudtson , used a GD2 with 2.5million in the front to win the mod title.
See his setup here :
http://www.awesomatixusa.com/p/setup-sheets.html
Jake D.
AWESOMATIX -- ORCA -- GRAVITY R/C -- SEATTLE R/C RACERS
Magnet Top is offline   Reply With Quote
Old 04-01-2014, 09:41 PM   #6070
Company Representative
Korgae's Avatar
I have as well,
I like the GD2 ( XRAY gears) with the 2.5M in it.. I have also tried the GD1 but to me It just never felt right on the track, I tried it a few times and every time I did I went right back to a spool, until I tried a GD2.
Awesomatix-Roche-Reedy-Sweeps Racing- ORCA-Sanwa-RCTagz-Avid
WCICS- Competition Director
Korgae is offline   Reply With Quote
Old 04-02-2014, 07:52 PM   #6071
ghoppa's Avatar
Trader Rating: 48 (98%+)
Default Damper chart??
Guys
Local track owner showed me a damper chart which shows all possibilities based on our shocks and had 4 different charts based on Spring and also I or II configuration. He left town for a few days and mentioned it was on Petite RC but I couldn't find it????
Anybody know where I can find it? Love to have it in my pit box!!!!
RCAmerica - Team Trinity - Xray - Revtech - Jgo Paintz
Hobbywing - Hudy - Futaba - P-1 Brand - 702 RC Raceway
ghoppa is offline   Reply With Quote
Old 04-02-2014, 08:15 PM   #6072
bkspeedo's Avatar
Dampner chart is in the back of the manual that comes with your car. If you have not seen this I'm guessing you bought your car used and did not receive a manual. I believe Hanulec has an electronic copy of the manual on is website. Go to awesomatixusa.com. Oleg probably has it on his website as well.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 04-02-2014, 08:56 PM   #6073
ghoppa's Avatar
No. Got the kit brand new the other week. And I saw damper charts that were formatted just like rollout/gear charts based on type of Spring and what measurements are used on the awesomatix dampers.....
Any one know where I can find this????
Old 04-02-2014, 09:31 PM   #6074
bkspeedo's Avatar
Here's an excel spreadsheet i created that i believe has what your looking for. The "SPR01S Chart" tab is a table your describing. Better yet copy this Excel doc to your phone and use it live, you can type in your suspension settings and have it calculate the values instantly. You can also type in the swaybar stiffness and get a full suspension stiffness value.
Brent Klingforth
Old 04-02-2014, 09:51 PM   #6075
Moderator
Clegg's Avatar
So a used kit I just received, has a set of the old A700 dampers. How do they compare to the new ones (R6)? they look nice.
Also what amount of oil leaking from R6 dampers is normal and acceptable?
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
SEO by vBSEO 3.5.0
