Old 03-24-2014, 10:39 AM   #6016
haywood's Avatar
Trader Rating: 48 (100%+)
Default Evo
Did some durability testing over the weekend and the car held up well. For those just building the kit and are concerned about spares this is what I've broke...
1. Bent stock turnbuckle
2. Bent front dog bone
Both happened on the sweeper off the straightaway.
Roche Rapida P12 2015/2016/2017 / Hobbywing / Team Scream / Progressive Rc / Ko Propo / MotivRc / Dri-Fit Mafia /
haywood is online now   Reply With Quote
Old 03-24-2014, 10:49 AM   #6017
haywood's Avatar
Originally Posted by trackout View Post
Just about finishing my awesome new A700 Evo but I have two questions that have come up:
1. The setup sheet shows more holes than exist on the car. So if I am using a setup sheet how do the holes on the sheet align with the ones in the car? ie outermost holes line up and you count inward from there?
2. The camber links seem long and I'm having difficulty tightening them up enough for appropriate camber while using the second from outermost hole on the car. Is there an upgrade/alternate set of camber links to use in those situations?
I switched to the Top Racing balls and open ended ball cups.
Old 03-24-2014, 11:18 AM   #6018
Quantra's Avatar
Originally Posted by oeoeo327 View Post
Hmmm... I was thinking if the bulkheads were located the same distance apart on either chassis, it wouldn't matter since you'd be able to use the top deck if your application requires one. The only thing I hadn't researched is whether or not the FFG bulkheads mount the same distance apart from front to rear, and utilize the same mounting points.
I don't see why they wouldn't align. The lower deck used on the EVO is the same as on the A700L. So you should be able to use the chassis but only with longitudinal motor mount.
Vince Coleman
Quantra is offline   Reply With Quote
Old 03-24-2014, 12:18 PM   #6019
Trader Rating: 14 (100%+)
Has anybody ran without the driveshaft brace in 17.5? Would the shaft oscillations be an issue with only a 17.5 motor?
www.5280Raceway.com | Racing. Elevated.
samsking is offline   Reply With Quote
Old 03-24-2014, 12:23 PM   #6020
MikeXray's Avatar
Trader Rating: 72 (100%+)
Jerry has a FFG car with carbon lower and a top deck, so it does work, the point really is that going with a hard lower deck AND a top deck would likely make the car way too stiff, especially since we're heading outdoors soon. I have not yet tested any of that though, so maybe I'm wrong
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 03-24-2014, 12:36 PM   #6021
oeoeo327's Avatar
Trader Rating: 70 (100%+)
I'm thinking I'll be the guinea pig for this experiment. I use the collars under the top deck screws, so most of the lateral flex is controlled by the chassis itself. The main reason I'm looking to upgrade is to move to a narrower chassis plate.
Founding member of the Solid Gold Racing Team - Mediocrity, redefined...
✯Jackson RC✯Horsham RC✯SJCCR✯
oeoeo327 is offline   Reply With Quote
Old 03-24-2014, 12:46 PM   #6022
hanulec's Avatar
Trader Rating: 23 (100%+)
All chassis holes will be in the same major spots. Major differences thru the years have been recessed holes for the lower arm mounts and the cuts in the chassis for more flex.
Outdoors I'm going to try--
Raceberry hard
C01al
C01l
My hand cut up c01l that I ran all last summer (and at iic)
Testing this stuff is 1/2 the fun...
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 03-24-2014, 08:08 PM   #6023
MikeXray's Avatar
Raceberry hard
C01al
C01l
What top deck did you like last season outdoor, the T cut or just the cutouts?
Old 03-24-2014, 08:15 PM   #6024
geeunit1014's Avatar
T Cut was definitely the best outdoors. The raceberry "hard" chassis is much thinner than the L chassis (2.1mm vs 3mm), so overall I believe it is flexier.
samsking - yes, for 17.5 you can get away without the brace on a L car.
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 03-25-2014, 02:23 PM   #6025
Car for sale?
Zooberg is offline   Reply With Quote
Old 03-25-2014, 03:42 PM   #6026
Originally Posted by Zooberg View Post
Car for sale?
I have an A700L if you are interested. It was only run at IIC and has been in storage.
HawaiiBob is offline   Reply With Quote
Old 03-25-2014, 07:21 PM   #6027
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
Any review how this car perform on low traction track ???
Give the best while u can !
kschu is offline   Reply With Quote
Old 03-25-2014, 07:45 PM   #6028
hanulec's Avatar
excellent! it probably shines best under low bite. the car accelerates on low bite surfaces better than others.
what surface do you run on? carpet? asphalt?
Old 03-25-2014, 08:44 PM   #6029
kschu's Avatar
on asphalt..do it need big changes in order to run in low or high traction track condition ?
Old 03-25-2014, 08:56 PM   #6030
It depends how high "High grip" is. If you mean like prepped nitro track, probably not so much. If you mean like indoor asphalt track where it's more like carpet level grip, probably. But that will be true of any car
Mike Gee
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17195 01-10-2017 05:04 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
