Old 02-18-2014, 02:23 AM   #5671
I started to upgrade my A700 to EVO.
When I was build the FFG front gear box I search the tape to put on the AM41 and it was not included in the FFG kit.
Is something missing ?
I don't have the right tape at home then I'll not be able to finish the car assembly... I'm disappointed and hope it's a forgetting because if not not delivering this tape is very surprising !
Team Speedpassion driver
http://www.speedpassion.net/en/ourteam.asp
chrispys is offline   Reply With Quote
Old 02-18-2014, 02:59 AM   #5672
I received last week my FFG upgrade set and start my car evolution.
I don't have the tape to fix on AM41 in the kit.
Is-it normal ?
I don't have similar tape at home then I had to stop the building yesterday evening. I'm very disappointed because this is something very cheep and not including it is a strange idea because using the wrong tape can trouble the car handling.
I also have a trouble with the diff cover un FFG gear box. I had to had 0.5mm shims between AM44 and AM46 due to diff. clamping when I screwed AM46.
Does somebody else have the same issue ?
Old 02-18-2014, 03:40 AM   #5673
josecarlo1129's Avatar
Is-it normal ?
Check/read the manual CAREFULLY. The AM56 should be positioned carefully with the chamfered side facing downwards towards AM44 to make way for the diff cover.
Nitro: On-road 1/8: Motonica P81-RS2/Vox/Savox
Off-road 1/8: JQ TheCar/Vox/Savox
Electric: On-road 1/10 TC: Awesomatix A700 EVO/AE BD/Team Orion/Ko Propo
On-road 1/10 F1: 3Racing FGX + RC9394 Carbon Conversion AE BD/Team Orion/Ko Propo
josecarlo1129 is offline   Reply With Quote
Old 02-18-2014, 05:31 AM   #5674
JayBee's Avatar
Trader Rating: 31 (100%+)
AND the kit doesn't come with the tape. You have to purchase that out of pocket.
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 02-18-2014, 05:38 AM   #5675
Jerry P's Avatar
Trader Rating: 44 (100%+)
I built 2 Evo's and the Tape is not included. it is a piece of scotch tape dont know that they sell it in pieces with a backing that can be peeled. Here in NY all i see are rolls of tape the store. The car ban be finished without the tape. It'll take 5 minutes to remove the front gear box, shaft and apply the tape once you have it.
Jerry P
Awesomatixusa - Side Piece Racing - LRP - Sweep Racing Tires - Mike L Designs - TQ Wires - Crispy Critters Raceway
www.awesomatixusa.com
Jerry P is offline   Reply With Quote
Old 02-18-2014, 07:47 AM   #5676
Quantra's Avatar
Originally Posted by josecarlo1129 View Post
A700 Antennae Modification.
Attached herewith are some photos of the customized Antennae holder+rod.
I customized a holder to have the horizontal antennae-rod layout, parallel to the drive shaft and carbon rod. Minimizing body reaming and of course, sleeker, cleaner layout.
Cheers to all.
JC
I like this idea, keeps the antenna out of the way. How did you fix the antenna holder to the steering rack (if I'm correct thinking it is attached there). I also wonder if this arrangement is possible with the alloy chassis + stiffener.
Vince Coleman
Quantra is offline   Reply With Quote
Old 02-18-2014, 08:14 AM   #5677
Hi there. Yeah, thought of a way because I hate any protruding material/element on this very well-thought piece/machine and it is very simple and budget friendly. I used the supplied servo holder (not the floating) to hold the 3.2mm carbon fiber rod with the AT06. I then mount it using the pre-holed slots near the steering rack on the C01EX- my favorite asphalt chassis.
If one will ask if the rod is touching the drive shaft upon vibrations, the answer is no (well based on my testings). The carbon fiber rod is so stiff that it won't reached nor touch the drive shaft upon normal driving conditions. If still doubting about the flexing of the tube, one can reduce the length of the rod to reduce the displacement of the oscillation.
My favorite A700 is neater than before. Hope this helps.
I reckon that Oleg's designing skills are the best and second to none. Evidently, some parts of the car can be re-positioned for possible new use.
Cheers.
JC
Old 02-18-2014, 08:58 AM   #5678
geeunit1014's Avatar
I dont know if you can do this with your airtronics rx, but with my futaba rx's, i just coil up the antenna wire inside of the rx case
Mike Gee
Awesomatix USA/Pyscho Cells Racing/LRP/Sweep Racing/RSD/Middle River Hobbies/Johns Mobile Raceway/TQ Wire/Avid
geeunit1014 is offline   Reply With Quote
Old 02-18-2014, 09:31 AM   #5679
blackshark3's Avatar
Better yet, I am using the Futaba R614FF-E receiver which has no external antenna
blackshark3 is offline   Reply With Quote
Old 02-18-2014, 10:24 AM   #5680
hana166's Avatar
Has Oleg started a trend with the aluminium baseplate..? Others are following his lead !
http://www.redrc.net/2014/02/wrx-stx...chassis-plate/
hana166 is offline   Reply With Quote
Old 02-18-2014, 10:37 AM   #5681
bkspeedo's Avatar
Futaba has done it right, no external antenna required. Not sure why everyone else hasn't done this yet. Most land RC cars don't need the range provided by an external antenna.
Here's another option that has served me well over the past few year's.
Brent Klingforth
Sponsors: Awesomatix USA ~ Roche USA ~ ORCA ~ AVID Bearings ~ R1 Wurks
TQ Wire ~ ProtoForm ~ BSR Racing Tires ~ 2mm Design
5280raceway.com [Operated by - Colorado On-Road RC Club]
MILE HIGH INDOOR CHAMPS April 20-23rd 2017 @ www.milehighindoorchamps.com
bkspeedo is offline   Reply With Quote
Old 02-18-2014, 11:00 AM   #5682
kgombe's Avatar
seems that way, as even Xray has an aluminium chassis
Kijana Crichton
kgombe is offline   Reply With Quote
Old 02-18-2014, 11:05 AM   #5683
I first put the AM56 on the wrong side but I correct it. When I was in the right side I had to add the 0.5mm shims.
Old 02-18-2014, 04:49 PM   #5684
Quantra's Avatar
I have my aerial coiled inside the Rx case currently but I've not tested it on a big track. I'm doing the ICC this weekend which will be a big track so it will get a test then.
I took a look at my chassis with the AM30 stiffener on it and it doesn't look like the above suggestion is possible. Perhaps what I could do is use some battery tape or zip ties to attach an aerial tube to the top of AM30. That's probably what I'll be doing if I get glitches this weekend.
For me it's one small niggle that when I use the prescribed aerial mount position the Rx has to be hanging off the side of the chassis quite a lot. This is how I ended up with the aerial coiled inside the case. I took a big hit on the side and the Rx case cracked open... So whilst it was open I thought I'd try coiling it and moving the Rx to safety, more inboard.
I see the alloy chassis is being copied but I thought the carbon wishbone stiffeners were something that was copying our carbon wishbones some time ago. Just my speculation though. In reality I think it's great that Awesomatix are the ones to be pushing the development of our cars and are emerging as the leaders in chassis design. =]
Vince Coleman
Old 02-18-2014, 08:31 PM   #5685
Adam B's Avatar
Default FFG
Well, I thought I knew what FFG stood for until this weekend. Under peer pressure I installed a FFG set up on my 700L, now I know it means F'ing frustrated guy. The right dog bone would pop out, even after doing the pin fix. The gearbox has more travel to the left then right for sure. The set up didn't have the top deck, would a top deck help solve this also?
Franchise Racing Products * Fantom Racing * Pro One R/C Tires * RC America/Xray * Discount R/C Store * F1 R/C Lab * NORCAR @ The Gate
Adam B is offline   Reply With Quote
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17188 11-13-2016 04:24 AM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
