Old 02-14-2014, 10:22 AM   #5656
Csaari77's Avatar
Trader Rating: 34 (100%+)
Originally Posted by SavageCanadian View Post
4mm
Awesome, thanks. I forgot to measure them last night and I haven't been able to find that information anywhere in my searches on the interwebs.
Half-A$$ Racing - Problem solved, problem staying solved!
Awesomatix - Serpent - Tekin - Futaba - Cooper Motorsports.
Csaari77 is offline   Reply With Quote
Old 02-14-2014, 01:38 PM   #5657
OVA
OVA's Avatar
Trader Rating: 67 (100%+)
I have not failed. I've just found 10,000 ways that won't work
OVA is offline   Reply With Quote
Old 02-14-2014, 06:15 PM   #5658
JayBee's Avatar
Trader Rating: 31 (100%+)
Originally Posted by oldrcr View Post
congrats JayBee, you just hit 6,666 posts.
Woo hoo.
-a
I missed that!
Originally Posted by Difuser View Post
Oleg did you change suppliers for the EVO kit bearings? Gotta say from the first build of my EVO compared to my USA the bearings were much smoother and immediately the car was freer.
JB-- Ceramic, they will be nice no doubt but the latest batch of bearings I got in my EVO were super free right away.
I noticed that as well, but I'll prolly still end up with some
On a side note....
My EVO build is going great. Tons of pieces but such a pleasure to build. BTW, that cf 12mm tranny tool should really come in the kit
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 02-15-2014, 04:25 PM   #5659
haywood's Avatar
Trader Rating: 47 (100%+)
Default Spur Gear
Do Xray spurs work on this car?
/ Roche Rapida 2015-2016 / Hobbywing / Team Scream / Rc Painting By Mikey / Ko Propo / MMR / Dri-Fit Mafia /
haywood is offline   Reply With Quote
Old 02-15-2014, 04:54 PM   #5660
I run RW spurs on my EVO. And all I can say about the car is wow!
Awesomatix a700l+ffg when it arrives!!
Diggity*Designs Dc4 le #11
Schumacher Mi5
2 Schumacher Mi4 cxl*Schumacher Mi1*HPI Savage XS*Schumacher MENACE 21 Schumacher fusion 21
Captain go slow is offline   Reply With Quote
Old 02-15-2014, 06:29 PM   #5661
JayBee's Avatar
I know I've asked this question before and was told that they are the same height. But in fact the AT21's are 6.4mm & the TOP pivot balls are 6mm. Give all measurements a .001/2 either way.
Old 02-16-2014, 01:47 AM   #5662
The height of the ball center is important only.
Overall height of the TOP pivot balls can be bigger due to the increased ball diameter.
AT21 ball center height is 4,1mm
AT21S ball center height is 3,6mm
ST24 ball center height is 3,4mm
Oleg Babich is offline   Reply With Quote
Old 02-16-2014, 02:01 AM   #5663
blackshark3's Avatar
I am using XRay 92T/64P without any problem on my Evo
blackshark3 is offline   Reply With Quote
Old 02-16-2014, 02:11 AM   #5664
JayBee's Avatar
Thanks Oleg and yes, I agree.
And for others info, the ball center of the TOP ball is 4.64mm.
Originally Posted by hanulec View Post
Jb.. That measurement doesn't sound like what I remember. Gotta wait a few days before i can remeasure.
You are correct Mike. I had to re-measure and the ball center is actually closer to 4.30mm
Last edited by JayBee; 02-16-2014 at 11:51 AM. Reason: had to zero out my calipers
Old 02-16-2014, 08:14 AM   #5665
hanulec's Avatar
Trader Rating: 23 (100%+)
FJ / ROAR #2-122945 / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 02-16-2014, 02:44 PM   #5666
Originally Posted by Styles View Post
Here are the manuals for an Evo assembly. The combination is the standard A700L + the FFG/Evo manuals together.
There are some steps that require you to be mechanically intuitive to switch between the 2 and may not be exactly clear when to do so. With that said, read through the A700L manual fully, maybe a couple times before you build.
Thanks !
Team Speedpassion driver
http://www.speedpassion.net/en/ourteam.asp
chrispys is offline   Reply With Quote
Old 02-17-2014, 11:56 AM   #5667
haywood's Avatar
Default Evo Kit
I need to source the 2.5mm wide screwdriver and tranny tool for my build. Both are out if stock at Awesomatix U.S.A. Anyone know of another source?
Old 02-17-2014, 12:55 PM   #5668
Most well stocked Hobby Shops carry the Wiha line of tools. Tower Hobbies shows in stock if your still looking, http://www3.towerhobbies.com/cgi-bin...?&I=LXKN64&P=7
Kody is offline   Reply With Quote
Old 02-17-2014, 02:38 PM   #5669
haywood's Avatar
Thanks... Found the driver local.
Old 02-17-2014, 10:18 PM   #5670
josecarlo1129's Avatar
A700 Antennae Modification.
Attached herewith are some photos of the customized Antennae holder+rod.
I customized a holder to have the horizontal antennae-rod layout, parallel to the drive shaft and carbon rod. Minimizing body reaming and of course, sleeker, cleaner layout.
Cheers to all.
JC
Nitro: On-road 1/8: Motonica P81-RS2/Vox/Savox
Off-road 1/8: JQ TheCar/Vox/Savox
Electric: On-road 1/10 TC: Awesomatix A700 EVO/AE BD/Team Orion/Ko Propo
On-road 1/10 F1: 3Racing FGX + RC9394 Carbon Conversion AE BD/Team Orion/Ko Propo
josecarlo1129 is offline   Reply With Quote
Bendigo..Vic.. On Road Car Club VoneSkip Australian Racing 17189 Today 03:25 PM
Topeka Onroad Racing Aaron P Kansas/Missouri Racing 10912 12-03-2016 08:53 PM
T.O.P. Racing "Photon" 1/10 EP Touring Car keithander Electric On-Road 9053 02-24-2016 07:51 PM
Touring Car Custom Cut Urethane Chassis Protectors!! Rommel Electric On-Road 220 07-07-2013 10:23 PM
The prototype car is on the winning pace number_one Electric On-Road 163 01-12-2009 11:52 AM
Tags
yokomo
SEO by vBSEO 3.5.0
